Question about Frigidaire GLEQ2152ES Electric Dryer
Dryer keeps stopping error code e68 - Frigidaire GLEQ2152ES Electric Dryer
  • Anonymous Apr 26, 2009
    I have the same problem -- dryer stops halfway through the cycle and shows e68 error code.
    President:
  • 373 Answers
E68 error refers to "Current leakage to ground on heater or fuse opened".Problem with the fuse.Try getting it replaced.This can be done by any local repairman.Need not be a technician from Frigidaire,as they charge a lot for servicing. Good luck with the machine.Please do post results and comments.
Posted on Apr 12, 2009
SOURCE: My Frigidaire Electric Dryer keeps giving an error code
If your dryer is the same or similar to mine (Model AEQ6000ES2) then error E68 is a stuck key on the keypad. This may be mechanically stuck or the membrane contacts. The simple solution is to replace the keypad.
I found this information by searching for "Frigidaire Model AEQ6000ES2"
Posted on Mar 30, 2009
SOURCE: Frigidaire Affinity Dryer (model LEQ7000ES0)
right now i took the whole bottom apart from the main brain and so far is working good is not turning off now it may work on your too
Posted on Jun 22, 2009
jyackle5
  • 8197 Answers
SOURCE: PLEASE HELP! Dryer cuts off and gives an E68 code.
e68 code
this is a fault code that means there is a stuck key on the board you may have to remove the control panel and check the keys if this does not work you may have to replace the panel or control board
Good luck
Posted on Oct 05, 2009
hunter19_46m
  • 7482 Answers
SOURCE: I have a frigidaire dryer that it run few minutes
E68 is a stuck button check all of the buttons if you can't unstick you will have to replace contol.
Be sure to unplug your dryer before starting any work on it.
You can replace it, just remove the top and then the screws holding the panel, slide to one side and lift out, lay it on a table or on top of the dryer and swap the panel. Good Luck, I hope this helps
Posted on Nov 27, 2009
Testimonial: "Thank you so mutch, you are so good."
jyackle5
  • 8197 Answers
SOURCE: E68 error message
The code is for a stuck button on control panel. You will need to replace the control panel
Posted on May 16, 2010
What does code E68 mean?
Hello Erik;
My name is Peter. I am a retired field service appliance technician.
The code E68 appears when one of the buttons on the keypad is stuck in the down position. This is a common error with several different Frigidaire dryer models and tends to occur when the dryer is five or more years old. You may be able to un-stick the offending key manually. If not, you will need to replace the entire keypad.
Dec 08, 2014 | Frigidaire Dryers
Frigidaire affinity LEQ6000ES2 error code e68...dryer will not start
Good Afternoon David,
I understand that your Frigidaire Affinity dryer, model# LEQ6000ES2, is showing you an error code of E68 and will not start. I also see that you have changed the thermal limiter. Looking at what the E68 error code means, a key or button stuck, there could be something else causing the code to come up. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance, determine what is causing the E68, and repair your dryer. Hope this is helpful.
-Best Regards-
WP
Jul 04, 2014 | Frigidaire Dryers
What do i do when my fridgidair electric dryer displays error code e68
Good Afternoon Friend, this is Z. Thank you for your post!
If you are getting an error code E68 on your Frigidaire dryer, it usually indicates that one of the keys (buttons) is stuck closed (active). Let's try entering a "Function Test Mode" and perform Key Test to determine which button is at fault. To perform the "Function Test Mode": Press and hold the START and CANCEL button at the same time for 10 seconds. The stuck key should blink. Carefully free the key and perform the test again after proper diagnosis. If button is free but the error code still exists, the electronic control will more than likely need replacing after proper diagnosis. If you do not have a professional connection, you have the option to visit the manufacturer website to find a service provider in your area. Hope this helps!
May 22, 2014 | Electrolux Dryers
Frigidare AEQ600es2 does not heat. Reports error code E68, but all buttons seem to work.
You will nee The error code E68 is a stuck button error code. I recommend checking each button to make sure it loose in the plastic console. The button should rock side to side a little bit. If all the buttons are loose you can try to reset the unit control by unplugging the dryer for two minutes. If the error code comes back you will need to replace the unit control.
Apr 17, 2012 | Frigidaire AEQ6000ES Electric Dryer
Was receiving E68 code on Frigidaire GLEQ2152ES1, replaced circuit board and am still receiving the e68 error code. What else will cause this error?
Hi yoyosam66...
Your e68 error code means:
Please take time to rate me
E68 - Push button does not function
Cause:
Push button held too long or wedged in the control panel. Solution:
Press buttons lightly and release.
Disengage button.
Aug 17, 2011 | Frigidaire GLEQ2152ES Electric Dryer
E68 error message
May 16, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Mar 23, 2009 | Frigidaire Electric Dryer
Hi, I am getting an error E68 on my dryer
Hi have you tried putting less into the machine as this could be a simple over weight problem
Oct 27, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
1,254 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
