Question about Hoover 24 in. DT999 Free-Standing Dishwasher
Heater element problems
My heating element has blown...the dishwasher runs fine but doesn't heat. I can get a new element for #60 from Hoover, but where can I find out how to fit it? Bob
  • 641 Answers
Why did you decided that it is an heating element problem,it could be a thermostat issue as well. Check with a multi-meter whether you have power on the heating element tags. In case you have power on its tags, the heating element should be replaced.But in case you can't read any power on its tags, it's probably a thermostat issue. Good luck!
Posted on Sep 11, 2007
SOURCE:
HOOVER AUTO DRY 5050ED KEEPS STOPPING
hi there, I have repaired many of these dryers. It will be a faulty heater element, most likely. They cost about $40. If you get a tradesman to fit it, they will prob charge you about $200 all up. Maybe its better to buy a new dryer for around $300? Good luck.
Lance in brisbane.
Jun 17, 2012 | Hoover Dryers
Dishwasher not heating water already replaced in line heater element no change
Hello
Possible causes;
Incoming Water; Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
Thermostat;The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan; The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
If your dishwasher isn't drying your dishes properly, see if you have selected a heated drying cycle. An air drying cycle doesn't completely dry your dishes. Never overload the dishwasher, as this prevents heat from circulating around your dishes, keeping them from drying properly. Plastic and Teflon
Sep 07, 2011 | Westinghouse Dishwashers
Dishwasher doesn't heat
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker
May 12, 2011 | Dishwashers
Dishwasher stopped heating. PCB is fine with no signs of damage. Is there a resettable thermostat or is it a bung water heater?
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Apr 28, 2011 | Electrolux Dishwashers
Hoover DT 999 shows E3. No hot water & no drying. Do I need a heater element or could it be some other problem?
is your dishwasher connected to the hot water lead? is the heated dry on? or is there a control issue
Mar 06, 2011 | Hoover 24 in. DT999 Free-Standing...
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Jan 19, 2011 | Hoover 24 in. DT999 Free-Standing...
Soap dispenser opens up but soap doesn' talways run out
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
heatman101
Asker
Jan 05, 2011 | Amana Dishwashers
HI TIMES TODAY I HAVE PUT ON MY HOOVER DISHWASHER , IT GOES THROUGH THE CYCLE RIGHT UP TILL THE DRYING THEN THE FLASHING LIGHT THAT SHOWS ITS WORKING JUST STOPS AND THEN NOTHING, PLEASE HELP
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
A bad heating element causes many problems in dishwashers…
heatman101
Sep 08, 2010 | Hoover Dishwashers
I have a Hotpoint Aquarius FDW 60 dishwasher. Crockery was with greasy smear on it. Since then the drying does not appear to be working. Seems the drying element has malfunctioned, can we replace this...
heatman101
Sep 08, 2010 | Hotpoint Dishwashers
Hoover HFI5G10 Dishwasher E8 fault
The replacement heating element may have failed.
Jun 01, 2017 | Dishwashers
Hoover 24 in. DT999 Free-Standing Dishwasher Logo
236 people viewed this question
Top Hoover Dishwashers Experts
Philip Postlethwaite
Vitally Alcher
Are you a Hoover Dishwasher Expert? Answer questions, earn points and help others
