Question about Maytag MTB2156GES Top Freezer Refrigerator
Refrigerator not woking
The refrigerator(Lower part) does not working. When I open the door, the light doesn't light up and the compressor doesn't start. The top freezor is still working.
  • 121 Answers
The frezzer is what make the refridge cold it is possable it is going bad also check the plug,breaker,then locate the defrost timer and advance it see if the compresser come on
Posted on Apr 13, 2009
I need to repair my GE profile refrigerator
The first thing you need to determine is if the compressor is coming on. If it isn't then the problem is in the lower section, PCB, start relay or capacitor or compressor. If the compressor does come on, then it sounds like your main board is the problem.
Jan 19, 2012 | GE Profile Stainless Bottom-Freezer...
Frigidaire gallery refrigerator ice maker doesn't turn off...no plastic signal bale arm?
Good day!!!!
When working properly, the thermostat turns the compressor on and off. Once the thermostat turns the compressor on, it will run until the temperature inside the refrigerator is lower than the setting of the thermostat. Make sure that the refrigerator has enough air clearance on all sides. Refrigerators with a condenser coil grid on the back of them need room to radiate the heat away from the coils.
Verify that the door light switch is working properly. Push the switch with your finger to verify the light is turning off. If the light stays on, it will actually warn the interior of the refrigerator. Fix or replace the switch if it is faulty.
Modern refrigerators that have a lot of storage and large freezer compartments run for longer periods of time. They also start and stop very frequently to maintain an even temperature. This is especially true if you have just put a lot of warm food in the refrigerator, or if it is very hot and humid. It can take several hours to get back to the cool temperature you have it set for after putting a large amount of food in it.
If the compressor is not shutting off when the temperature inside the refrigerator is cold enough, you may have a bad thermostat. You may also have the temperature set too high in the refrigerator. Try adjusting the thermostat to a lower temperature. If this turns the compressor off, you had it set too high. With the help of a refrigerator thermometer, you can find a more ideal setting that will keep your food cold, but not so cold that the compressor is always running. If raising the temperature setting doesn't help, it may be a problem with the thermostat and you will need to replace it.
If your thermostat is working properly, there's a chance that you have low levels of refrigerant in the sealed system. If this is where the symptoms lead you, you need to contact a professional appliance repair person. Only an EPA certified technician can legally work on a sealed system. If you attempt to do work on this system, you will void the warranty.
If this is a new refrigerator, it will run for a long time, almost constantly, before it gets cooled enough to stabilize the interior temperature. Allow up to 24 hours for it to stabilize. The refrigerator should be at least one half to two thirds full. This will help to maintain a stable temperature inside the unit. The cold items inside will help to keep an even temperature inside after the door has been opened and closed. Some people prefer to keep a lot of stuff in the refrigerator as ballast, even jugs of water. This helps to maintain temperatures inside so that when the door gets opened and closed often, it doesn't need to run as much to maintain the temperature inside.
I hope this information will be helpful...Thanks for using fixya...
Aug 31, 2011 | Refrigerators
Woke up this morning and the fridge was not working, It is like there is no power on to it. I checked the breaker and it was not tripped I did reset it to check but still nothing.
If there is not lights or anything in the refrigerator, then you aren't getting power. Start out checking the outlet - if you don't have a multimeter to check it, use a hair dryer plugged in to that outlet to see if it will work. If it doesn't then it is between that outlet and the main circuit breaker box or even a bad circuit breaker.
If it does work or you have lights in your refrigerator it is probably either the starting capacitor, start relay or compressor.
LG refrigerators are more sensitive to power fluctuations than other models and we have had to replace a lot of starting caps and relays - but sometimes it is the compressor.
Hope this helps!
Jun 22, 2011 | LG Refrigerators
Freezer is cold, but refrigerator is warm. The fan is running, but I don't feel cold air coming into the refrigerator compartment. There did not appear to be a large amount of frost anywhere, but just...
If the freezer is cold the compressor is Ok. Now if its a two door fridge . Open both the doors while the fridge is On. Press the lower door switch ( the lower light should turn off and you should hear the fan humming sound come on ). While holding the door switch pressed close the freezer door, you should see cold air come out of the slits in the back of the lower compartment. If not icicles have blocked the passages due to the non working of the heating coil.The heating cycle is controlled by the timer switch located near the compressor at the back. Unplug the fridge and remove the timer switch.Note the color of the wires and mark on the old switch. Replace and it will work.Only frost free fridges have heating cycle
Mar 07, 2011 | Refrigerators
The lights on the refrigerator side have shut off and a nose from the bottom of the fridge starts as soon as you open the door.
Pull off the rear access panel covering the compressor in the lower rear of the fridge. Have someone open the door and you may hear the sound in a control panel mounted on the left hand side of the opening. If so you need to replace the control board.
Mar 03, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
WAS WORKINIG FINE NIGHT BEFORE WOKE TO IT NOT WORKING FRIDGE AND FREZER BOTH I DID HERE THE FREZER FAN RUNNING STILL. THE COMPRESSOR TRIES TO GO ON BUT SHUTS OFF RIGHT AWAY.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Aug 31, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I opened the door on GE Profile side by side refrigerator this morning. Not only was the the refrigerator not blow cool air. It was actully blowing hot air, it was like opening the oven. The temperature on...
Check if it is still under warranty - I think that it is usually 2 years.
When in this condition, was the compressor still running ?
There was one issue that occurred occasionally on some models - the fridge door has a height adjustment so you can level the 2 doors up. Sometimes, it drops a bit too much, and on models with the fridge door light switch on the top (not the side), it meant that it wasn't turning off the light. Some have 2 lamps (commonly 40W or more each), so you effectively have 80Watts or more of heating running constantly. If your (exact) model has the door switch on the side, this is Unlikely to be the issue.
If the compressor was not running, I could say something like "it might have got stuck in a defrost cycle", but this DOESN'T really fit with the operation of these fridges (no defrost elements in the fridge side).
Does this help in any way ??
Dec 10, 2009 | GE Profile PSW26P Stainless Steel Side by...
Refrigerator door will not stay closed
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Sep 25, 2009 | Sub-Zero Bottom Freezer Refrigerator
Whirlpool side by side refrigerator door not closing by itself. Ideas?
Jul 12, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer works but the refrigerator doesn't
Usually means the defrost timer isn't working often enough....there is a small hole that is open between the freezer side and fridge side that will clog with ice ....you need to defrost this hole....its at the bottom of the freezer just inside the door....try this first but you may need a new timer also.
Jun 13, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Maytag MTB2156GES Top Freezer Refrigerator Logo
172 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
