Question about Lenovo 3000 N100 Notebook PC
Lenovo 3000 N100 frequent reboot problem
Hie,
Facing problems wit my lenovo 3000 N100 laptop. Apart frm the known battery issue (already faced it), the system reboots very often, probably in every 15 mins (if m lucky can last upto 30 mins :) ). Happens even when no other application is running. This random shut-down has lead to xp crashing a couple of times as well.
Wud appreciate if any advice or help on this. Please let me know if you need any specific details to address this issue.
Thanks.
-Shekhar
How to install webcam driver in lenovo 3000n100 ,windows 7 xp
how to download webcam driver for lenovo 3000 n100 for win 7
Feb 20, 2011 | Lenovo 3000 N100 Notebook
I got black screen a few seconds after reboot my LENOVO 3000 N100, type 0689 - 2BS, Laptop run normally without screen light, I need to flash screen in order to read it. I tried unplugging the battery and...
Hi. I think the LCD screen of your laptop needs a replacement because I think the backlight on that LCD is already busted thats why you need to point a flashlight or some sort of light just to see the display. Powerdraining your computer wont work because this already a hardware issue with the LCD, that's why when you switch display with your monitor it works fine. I would suggest replacing the LCD of that laptop or try calling Lenovo tech support if your laptop still under warranty so that they would replace it for free. This is no. to contact for your Lenovo laptop US/Canada 1-800-426-7378, Australia 1-300-880-917. Hope this Helps
Feb 28, 2010 | Lenovo 3000 N100 Notebook
My Lenovo N00, 3000 notebook came with a 10.8
boot up holding f8 key load last known good configuration. your computer should not know jack about the battery. but with computers you can never tell they are finikey
Jun 24, 2009 | Lenovo 3000 N100 Notebook
My lenovo laptop model no is 415227q and when i am downloading my audio driver than ask for media driver. plz explain me how to solve this problem. thank's.
hi,
1. Download the driver and the windows xp hotfix from consumersupport.lenovo.com.
2. Save them on the desktop.
3.win RAR should be installed in the system then extract the driver by right clicking on the folder downloaded.
4.install the hotfix first and then run the setup of the extracted driver.
5.If then also the issue is not resolved then go to devicemanger>audio device on hd audio bus and right click on that>update driver>give the path of the extracted folder.
If facing the issue come on chat.
Mar 05, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Lenovo 3000 Notebooks : N100 Power Failure!
Hi.. I have a temporary solution to your problem. I had the same problem. Remove the battery and the ac adapter from the laptop. Just reconnect the ac adapter without the battery and switch on the lap. Presto.. Problem solved.. It doesnt power off anymore unless u remove the ac adaptor. Usefull if u hav needed files n want 2 create a backup. Still i havent found out a permanent solution to this problem. I suspect its a motherboard fault
Jan 22, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Problem with integrated webcan Lenovo 3000 N100 notebook
Buy external webcam; troubleshoot this problem was westing our time.
Nov 06, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Display
open the tower take out the ram and then put it back and then restart the system and check whether you are facing the same issue or not and try to restart the system in safe mode.
Sep 07, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Battery problem
SreeSatya,
Laptop batteries have a limited lifespan. When they reach the end of that life, this is how they behave. How old is your laptop?
I just replaced my Toshiba after three years. Unfortunately, laptop batteries are not cheap. You can find batteries for your system here:
http://www.atbatt.com/laptop-batteries/b/Lenovo/m/3000_N100_0768.asp
Jun 06, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Computers & Internet Logo
286 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
rey francis basa
rey francis basa
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
