Question about APC (BE500U-WEB) (BE500UWEB) UPS System
Squealing noise Hi, my backup just started making a squealing noise, what could be causing that? Joanne
  • johnl2009 May 11, 2010
    What model backup unit?
  • Anonymous Mar 29, 2014
    when i plug in my backup hard drive there is a squealing noise coming from it
    Problem Solver:
  • 6 Answers
Depending on the unit, thats either telling you the battery is dead, the power is out, its overloaded (too much or too large equipment) or there's another problem with the unit. If you have the cable that should have come with the unit, you can connect it to a computer and install the software for a diagnosis.
If you unplug or turn off everything connected to it and it still squeals, the battery is probably dead, but it may be that something is wrong with the UPS itself, and you should send it back under warranty, or get a replacement.
Posted on Apr 29, 2009
Bear tracker squealing noise when trying to start after running it goes away help please it sat for a year before got rear end fixed
Joe, do you mean a bearing track?
If so, a bearing -or track - usually makes a grinding or knocking noise, not a squealing noise.
If a car stands for a long time the brake rotors can corrode a bit and the pads can stick. Sometimes, when the car is first used after standing, you may hear a rubbing or squealing noise from the wheel. That's the pads sticking to a rusty rotor. The noise may wear off after a few miles when the pads 'polish' the corrosion off the rotor.
The other thing that causes squealing from a wheel are the brake shims. Try cleaning things first.
Mar 14, 2016 | Cars & Trucks
WHAT IS THE LIKELY CAUSED OF A LOUD SQUEALING NOISE COMING FROM THE ALTERNATOR SERPENTINE DRIVE BELT SYSTEM ? IS IT THE ALTERNATOR OR SERPENTINE BELT?
serpentine belt is getting old and hard and the cold weather was causing it to slip
check belt condition ( small cracks across the grooves = scrap and get a new one) and check tension
Jan 22, 2016 | Cars & Trucks
Battery b/u squeals after unplugging everything from it and have also uplugged the unit from the wall
Hi Robert,
The UPS will beep/squeal if the power isn't turned off to it before it is unplugged from the wall. But the other thing that may be causing the noise is a bad battery. Replacement battery price is $26.00.
Reply or call if you need more help with this -- 407.380.9200
Sep 20, 2013 | APC (BE500U-WEB) (BE500UWEB) UPS System
Apc battery backup makes squealing noise, then the power light comes on, why
When there is no power coming into the UPS it will indicate so by 'squealing', during this time - the UPS is on battery. When power returns to it, it turns back to building power and the power light comes back on.
If you need UPS, Surge, or Power Related help contact Daniel @ Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/
Jul 23, 2013 | Computers & Internet
Engine squeal when starting
Hi JoAnne,sounds like your belt is squilling,here's a link to the belt adjustment or removal.
Dec 22, 2012 | 2005 Kia Sportage
I have a coleman heat pump and the indoor unit sometimes makes a squealing noise on start up. It does not make the noise when using regular heat. (no compressor) any ideas?
What you are hearing is the refrigerant going through the expansion valve...sometimes they will squeal as the pressure builds...depending on the valve the refrigerant has to push open a check valve and that will cause a noise...
The noise does not mean that you have a problem, and it will not hurt anything... nothing is broken, it just can be annoying...
heatman101
Mar 31, 2011 | Heating & Cooling
It doesn't happen everytime but the first time I start my Honda Pilot in the morning it makes a squealing noise. It's a one time squeal and stops. Had the alternator belt replaced and 3 days later the...
the noise is the alternator belt, what maybe going on is you need an alternator. it could be that there is a bearing that is ceasing up when it cools down and when you start it up it takes a min. to get spinning and this is causing to much drag on the belt and making it squeal.
Mar 11, 2011 | 2009 Honda Pilot
Squealing noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
98f
Jun 27, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Loud squealing noise
The noise is most likely the serpentine belt. Check it's condition and that of the belt tensioner. It sounds like the belt is slipping, causing the squealing noise u describe. As the belt warms up, it's getting a better 'grip' and the noise stops. Turning on the heat also turns on the a/c in newer cars, this added drag on the belt (one more component to turn, the a/c compressor) would explain why it happens when u turn on the heat. Is the belt original? If yes, it's time to change it, and check the belt tensioner to make sure it's doing it's job of keeping the belt snug on all the pulleys. Let me know how u make out.
Dec 13, 2008 | 2003 Nissan Pathfinder
Unexplained squealing noise.
That usually means that the belt is loose. If it is loose it will make noise on start up and go away, but while running normal, if u make the pullys work more such as A/C, or something, you'll cause it to slip again, thus making it squeal and make noise. Another idea is if you only have one belt (a serp. belt) then if the tensioner, which is not adjustable by hand, is going bad could maybe cause this noise if the belt is slipping from not enough tension. An experienced tech would be able to tell if a tensioner is bad just by pulling on a belt and seeing what tension the belt has at the time. Hope this helps, good luck
Nov 07, 2008 | 1995 Honda Passport
APC (BE500U-WEB) (BE500UWEB) UPS System Logo
2,318 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
