Question about Kitchen Ranges
I have recently bought a Belling E 622 cooker. Being visually impaired I have a job seeing when the knobs are at off. They have an indentation and if these were painted white, I would be able to see them. Otherwise, the cooker is fine.
5 Suggested Answers
  • 1462 Answers
SOURCE: I have a Belling 755
almost certainly the thermocouple is faulty
Posted on Oct 08, 2008
  • 3 Answers
SOURCE: old belling classic cooker,oven door catch has
my oven done the same so i bought some strong magnets and put one in each corner.
its fine now.
Posted on Nov 04, 2009
  • 72 Answers
SOURCE: correct cable size for belling cooker fitting
If this is a fan assisted oven then a 2.5mm twin and earth is sufficient, but please consult the manual and let me know the wattage, or contact a qualified electrician.
Posted on Dec 27, 2009
FitzOriginal
  • 842 Answers
SOURCE: I have a belling gas
When the oven lighting mechanism lights the gas, the flames heat a temperature sensor that, once hot, increases the pressure in the sensor's copper pipe and opens a safety valve to allow gas to continue to flow without you holding down the button (It's made like this so, if your flame gets blown out, the sensor cools and cuts off the gas supply, making it safe from gas leaks). These sensors occasionally fail, and very sensibly "Fail safe" - No pressure in the sensor pipe, the valve won't stay open and there is no gas to the burner once you release the button.
If you take a look inside the oven at the back where the burner is, you will see the sensor, usually the bit that is in the flame is cylindrical, about an inch long made of metal about 3 or 4 mm thick, tapering at the end. It will be held in place by a nut that fits on a thread at the base of the sensor. Running from the sensor is a copper pipe that runs to the cutoff valve. Unbolt the sensor and withdraw it from the hole it is mounted in, trace the copper pipe back to the valve (where it is usually screwed into the valve with a 10mm connector that looks like a car brake pipe connector. Unbolt from the valve. These sensors are widely used on most gas appliances (Boilers, gas fires, cooker hob burners and patio heaters all use the same kind of sensor). You should be able to get a replacement from any gas appliance service agent. If you go into a shop, take it with you. The only thing you need to do is make sure the replacement you get is long enough. If you are offered one that is slightly longer, that
Posted on Jul 22, 2011
Why are cooker knobs melting on my belling gas cooker
could it be the pan you are using is too big for where the burner/ knob is located
Jul 19, 2015 | Belling Kitchen Ranges
We have just moved house and have been left a Belling Platinum Dual Fuel db2 Cooker and cant get the ignition to work. Can anyone suggest what we should do?
by cooker,do you mean a stove? is it gas?is the gas knob in the "on" position?is the stove plugged in?
i clean out apartments to get them ready for new tenants. if the ignition clicks on,but the burner isn't lighting,it might be dirty. i soak the burners in hot water overnight. scrub with a wirebrush.poke a needle in all the openings & on the ones in the stove. dry thoroughly & see if it works.
if the ignition isn't clicking at all,one of the components in the electrical box might be broken.i wouldn't mess with gas or electric.call your gas & electric supplier or a repairman to find out what's wrong & see if it's worth fixing or not.
Mar 30, 2015 | Belling Kitchen Ranges
I have a Belling 335 everything still works apart from the actual oven part? What could this be and is it fixable??
check your timer,if it has a programm set(by accident)the oven will not work until this has been cleared,if your not to sure then switch cooker off at the cookers main switch on the wall.leave for a few mins and switch back on this should clear any set programm,good luck.
Nov 13, 2012 | Belling 335 Electric Kitchen Range
Belling oven stopped working
It is most likely the element needs replacing although it could be the oven thermostat.
I would try a new element first, it is not a complicated job to change the element but you need to switch the power off at the wall before you start work.
If you are unsure or in doubt about carrying out the work seek professional help.
Dec 22, 2009 | Ovens
Old belling classic cooker,oven door catch has
its fine now.
Sep 03, 2009 | Belling 644 Electric Kitchen Range
Belling G755 Cooker oven wont stay lit
I'll give this a go! With a cooker like this, you depress and then turn the control knob, press the ignition button and continue to depress the control knob for a few seconds. This is because a device called a thermocouple is heated by the flame and you have to continue to depress the control knob so that sufficient gas flows to heat up the thermocouple. If the thermocouple does not get hot or stay hot then the gas valve is automatically closed - stopping the gas. The thermocouple is a 'flame failure' safety device. If the gas gets cut off then the flame goes out and the thermocouple goes cold switching off the gas valve automatically. However, you are having to try and manually keep the gas going for a good five minutes. I would think that there is either a problem with the thermocouple or the gas control valve! Tony www.birminghamelectricsltd.com
Jun 18, 2009 | Belling Solitaire G755 Gas Kitchen Range
Replacing faulty regulator for hotplate
Remove hotplate and oven control knobs. Under the 2nd and 5th knobs is an extra screw which holds on the front cover. Unscrew these and free the cover then access is gained to the screws (2 on each edge) which removes the plate to which the regulators are fixed.Remove the faulty regulator by unscrewing it from the plate,(2 screws) It is an easy job then to install the new part taking care to put the correct wires on the correct terminals. Reassemble, job done!
Jan 11, 2009 | Belling Cooktops
Kitchen Ranges Logo
73 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
