Question about Neff B1421 Electric Single Oven
I had to replace the fuse for the oven (b132wogb/01) when i put it back on the temperature wuld not rise above 50 i have no instructino book how do i get the temperature to work
    Sergeant:
  • 228 Answers
THE FUSE BLEW BECAUSE YOUR OVEN ELEMENT HAS SHORTED OUT NEEDS REPLACING
Posted on Oct 30, 2009
I have a New World Double oven, dual fuel range cooker - NW 90DFD0 The main oven isn't heating up.
Hello Ally;
My name is Peter. I am a retired field service appliance technician.
You may not have a problem. Normally your oven will rise about 40 degrees F. above the set temperature and then shut down, until the oven temperature falls 40 degrees F. below the set temperature, then the oven turns back on.
Your oven temperature is controlled by you oven thermocouple.
You also have a high temperature limit switch, which turns the fan on when you go too far above the set temperature to vent the oven. This may be bad.
Mar 10, 2016 | Ovens
I dont know how to use the oven properly. when i need to bake or roast something i want to put in my own temperature, but there is no option for me to do that. when i turn on the stove all i have is the...
There should be a plus/minus sign OR a up/down arrow to adjust the temp.on the control/touch panel. The default setting is usually 350 and can adjusted up or down accordingly,the display starts at 120 and is supposed to rise as temp. increases.
The bigger issue though is to have it serviced and see why it doesnt rise above 200
Gene
Aug 04, 2011 | KitchenAid KEHU309 Stainless Steel Dual...
Teperature i snot rising above 100, why?
Assuming your Thermador is electric, and it is only warming up a little, this is usually one of three things:
1. Heating element - with oven power disconnected, check that the elements resistance is in spec. Usually around 20 ohms.
2. Thermistor - this senses the temperature of the oven. Again, check the resistance. Depending on your model, it should be around 1050ohms at room temperature.
3. Electronic Control Board. These can be rebuilt quickly and reliably at www.fixyourboard.com. Some are still available to buy online.
Hope that helps
May 21, 2010 | Thermador SMW272 Electric Double Oven
Kenmore built-in oven set at bake tempature does not set just keeps rising got F2 code
HI. This error code will occur when the control board senses an oven temperature above 915F-935F
Once this type of temperatures occur, this will generally weld the relay contacts on the main board. This will damage the board, and it will require you to have it replaced, asap. If these temperatures never reached the sated thresholds, i would advise to Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace the sensor if found to be defective. Check door lock switches for damage, as well.
In most cases, this will be a failed control board. To confirm, simply preform a resistance test on the sensor. The normal ohm readings should be 1100 ohms at room temperature.
If the oven temp sensor dose not test out at 1100 ohms at room temp, replace the sensor.
Jan 06, 2010 | Kenmore Ovens
Oven Temperature rises above setting
You may or may not see the error code.
The temp probe is less expensive and is most likely your problem.
If you choose to replace it and the problem remians your ERC will have to be replaced.
ERC electronic range control
Mar 12, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven temperature increases 50' after original temperature is reac
What it needs is a new oven thermostat fitting, much cheaper solution than buying a new oven, it is a fairly straight forward repair, if you require more details let me know.
PLz rats my solution.
Thanks.
Jan 03, 2009 | Whirlpool RBS305PDS Electric Single Oven
Neff B1421 Electric Single Oven Logo
219 people viewed this question
Top Neff Ovens Experts
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
