Question about Polaris Pb460 Polaris Booster Pump Replacement Impeller
My polaris booster pump will not come on. when i turn it on the motor makes a humming noise but wont start
  • Anonymous Apr 29, 2009
    itried this solution with no luck...shaft turns easily,but still get humm with no pump action. Any other ideas
    New Friend:
  • 77 Answers
Does it have a century motor? If so, remove the shaft cover plate at the rear and try rotating the shaft with a very thick slotted screwdriver or substitute until it turns fairly easily. Often some mild oxide develops around components that just needs to be disturbed.
Posted on Apr 14, 2009
Are there any other booster pumps that I can use to run my pool cleaner? I had a Polaris bp4-60 for 7 years, it finally failed. Replaced it with same model. Ran for few mins then shuts off then restarts....
I think Polaris should refund the purchase price on these pumps. I changed the breaker, the whip, and upgraded the outlet (using 110). The dealer exchanged it for me, but would not give me a refund, and I had the same issue with the second motor. I used a Hayward 6060 pump as a replacement. Everything works fine.
Jul 04, 2014 | Polaris Pb4 - 60 Booster Pump
Humming booster pump
turn off then try to turn back of motor 9/16 wrench turn acouple of times then try if not working bad pump
Oct 04, 2013 | Polaris Pb4 - 60 Booster Pump
Pb4 booster pump is trying to engage. It has a humming noise every 10 to 15 minutes but will not engage
turn off try spinning the back shaft of motor then try if still doesn't work need new pump or motor
Sep 01, 2013 | Polaris Pb4 - 60 Booster Pump
I have a Polaris PB4 booster pump, installed late July 2006, vacuum was running for an hour tonight but I noticed it wasn't moving across bottom of pool normally--wheel was skipping. I shut things down...
The click is the internal thermal overload. Since the pump wouldn't start it overloaded and opened the circuit. Either there is something jammed in the impelller locking the pump up or you have a motor problem. IF it a capacitor start motor, you could have a bad capacitor. Or if it has a starting switch it may not be operating. Start off and be sure the motor turns freely. If you replace capacitor be sure it is same voltage and MFD as the old.Check all wiring connections.
Aug 18, 2010 | Polaris Pb4 - 60 Booster Pump
I have a Polaris LR51044 pump that is not working. When I turn it on it "hums" but won't pump water. I live in Baton Rouge, La. and we have had freezing or below freezing weather for the last 2 days. The...
Usually when a polaris booster pump hums it means 1 of 2 things; either the starting capacitor needs to be replaced (its located under the black hump on top of the motor) or the pump is bad. Most likely the starting capacitor needs to be replaces. This is where you should start since the capcitor is only $20-$30. Get a new capacitor from a local pool store, shut the power off to the motor, remove two screws on each side of black hump on top of motor, remove two wires from starting capacitor and install wires on new capacitor, replace cover and turn the pump on. If that doesn't work you will need to replace the motor.
Jan 09, 2010 | Polaris Pb4 - 60 Booster Pump
The polaris booster pump motor does not start. I hear it humming. I took the end cap off and turned the shaft without a problem. I took off the capacitor and tested it and it works. What should I check...
I my name is Juan and I was a pool repair tech in california and if your capacitor is good and your motor turns freedly with your hand then is time to replace your motor for a new one if you planing to do this make sure you replace the water seal is a good time to do it
Jun 16, 2009 | Polaris 380: Polaris Booster Pump
Polaris Pb460 Polaris Booster Pump Replacement Impeller Logo
847 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
David Spradling
David Spradling
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
