Question about Memorex MVD2042 DVD Player
It just stopped working
I own a memorex mvd2042, have had it about two years. Today I went to turn it on. The standby light comes on when you plug it in but nobody is home. None of the front panel lights come on and it doesn't respond to the remote or the buttons on the front. There is currently a dvd trapped inside. What do you think? Should I just by a new one or hope it decides to come back. Mel
Re: it just stopped working
All, I **w have a second one of these DVD players in my possession, and have found, again, a bad capacitor (C411) in the power supply section. Replacing this discrete component (it is a 1,000 µF, 16V electrolytic capacitor; replace the part with a 1,000 µF 25V (or higher voltage, keep the capacitance, the 1,000 µF, the same, that still fits onto the board) electrolytic capacitor part) has fixed my, will **t power on, suddenly **n-working DVD player, into a working one. Replacing this capacitor with a higher voltage part is probably a good idea: the 16 volt part seems to it a bit undersized, as the top of the can has bulged, a sure sign the maximum voltage of the capacitor has been exceeded for an extended period of time, boiling the electrolye inside and bulging the can.
Total cost was less of this repair was $1.59 and that was at Radio Shack (Part Number 272-1032) for a 1000µF, 35V (20%), Radial-lead electrolytic capacitor. And it fits in the same space as the one removed.
A **te of general use for troubleshooting these types of consumer electronics (read: CHEAP!), assume the least expensive parts went into them, and k**w that the most expensive parts are **t the IC's but the discrete components, and, usually, the most expensive of those compenents are the capacitors. Start there, and look for bulging, leaking and/or corroded parts. These parts should have very flat tops and strainght sides with ** discharge. Any deviation indicates a bad part. This can usually be confirmed with a multimeter continuity tester; they are usually shorted and do **t hold any charge.
J. Roebke.
Posted on Mar 10, 2008
  • 3 Answers
Memorex MVD 2042
Red Light on front On but Dim,and No functions work.
I found the top of the µF 1000, 16V capacitor on the power supply circuit board bulged up and it also seemed like it was warm compared to all of the other components. (The unit had been plugged in for about a half hour). I got the Radio Shack 1000µF, 35V capacitor (Part Number 272-1032) and soldered it in place of the µF 1000, 16V capacitor. One hint I would add for others new to this type of repair. There is a positive and a negative terminal on those capacitors. So make a note of which way the old capacitor is installed and put the replacement in the same way.
Posted on Jul 26, 2009
Thanks to J. Roebke! You "Fixed It!"
I also have the Memorex MVD2042 dvd player that just stopped working after a few years. Standby button was lit (red) but it would not power on. Tried pressing Standby button and unplugging power cord per manual, but still nothing.
Read J. Roebke's post. Glad I did!
I opened the case and found the 1000uf 16V capacitor on the power supply bulged on the top. Went to the "Shack", got a 1000uf 35V capacitor for under $2. A little soldering time later, and it works fine!
CAUTION - for those who don't know, all capacitors store electricity. So if you try this, be VERY careful. You could get shocked or worse. Or let someone a little more familar with electronics do it for you.
To remove a disk from the player, if you choose not to fix the player, open the case, look at the left side of the disk drawer and find a white gear. Gently turn it with a small screwdriver, back and forth until it begins to move. It should eventually unlock the drawer and allow the drawer to be pulled out so the disk can be removed.
Posted on Dec 15, 2008
I had the same issue, opened up my unit and found the same cap, (C411) bulged out
Posted on May 24, 2008
Thanks to the solution posted by JRoebke I was encouraged to try to troubleshoot my MVD2042 DVD player. Opening the thing I found the power supply was dead and 3 caps were abnormally warm. I replaced all 3 of them, but had trouble finding ones with such tiny footprints with the same values. The manufacturer obviously cut corners using caps with under-rated ripple current, no wonder they blow! The larger one was a 2200uF 10V, which I replaced with a 1000uF 25V. The smaller ones were both 470uF 25V which I replaced with the same value but larger case (Digi-key P10274-ND). Works great now.
Posted on Sep 03, 2009
Mine blew out an inducter, L50, on the board in the center rear of the unit, rtght next to the white 5 - wire connector. I'm going to try to replace it if I can find a number on it - all the inductors (marked L**) seem to be plain black cylinders. I'll post if it works.
Posted on May 27, 2008
    Problem Solver:
  • 7 Answers
If you cant get it to work will you be will to sell the remote let me know needs one bad cant play my mp3 on it anymore email me at
Posted on Dec 31, 2007
0 characters
3 Points
Unplug power cord, wait 30 sec. Plug back in. Worked 4 me
Mar 20, 2011 | Memorex MVD2042 DVD Player
Red light on standby and set won't turn on why? and what can I do?
The quick answer is to try unplugging it from the wall for 3 mins and then plug it back in. Brown outs in power seem to mess up the logic controller on this model. If that doesn't work, you can have a technically inclined friend open her up (UNplugged) and check the fuse to see if has burned out. These can be picked up at Lowe's for around $1.00 and just snap in place. Make sure you have the right value fuse so there is no fire safety issue. Let me know if this doesn't work :)
Jun 15, 2010 | Memorex MVD2042 DVD Player
DVD player won't turn on. The red standby light is on. But the player does not work. I've tried unplugging it for 30 seconds but no change
If you didn't have any or have a good power strip the internal power supply could have gotten damaged, if it is under warranty get it replaced. And make sure you have a power strip for electronics at a mininum.
Mar 15, 2010 | Memorex MVD2042 DVD Player
Memorex DVD player won't work
the standby light switch is your on/off switch as well......
Nov 18, 2008 | Memorex MVD2042 DVD Player
Memorex Dvd player gets stuck on HELLO screen randomly
well. i had the exact same problem but i unpluged it pluged it back in, same prob hello screen so how i fixed my problem i punched it an it shut off an went on standby an worked ever since..4 any of you with anger probs like me it mite work atleast it did for me lol
Sep 28, 2008 | Memorex MVD2042 DVD Player
Stuck in Standby
FOr the MVDP1102 Memorex 10.2 portable DVD Player:
I had the same problem. If you open the disc door there is suppose to be a plastic arm underneath the right side of the lid which when you close the lid, with the movie disc in, this arm will press through to a switch inside the machine and that will set the player in load/play mode. Memorex did not have parts for this player, so I unscrewed the bottom and one black screw inside where the lazer light is. This will allow you to handle the bottom back side and see underneath where the screen is you will find the switch. I rigged up a pin wire and did some small drilling. I was successful, but it wasn't easy. Most times I just fail and toss. I thing my son just open the disc door too much and that's how the piece was broken.
Apr 05, 2008 | Memorex MVD2042 DVD Player
try unpluging and plugging back in
Jan 15, 2008 | Memorex MVD2042 DVD Player
Memorex dvd player model # mvd2042
I'm having an identical problem with my very new "Memorex DVD". After trouble shooting everything suggested in the manual, I'm on my way to buy another "new" dvd player. Definately will not be Memorex.
Jan 04, 2008 | Memorex MVD2042 DVD Player
My dvd player stopped working and all i want to do at this point is remove my rented dvd.
If you just want to take out a DVD here's what to do:
1.Take off the top cover:
- remove five screws on the back (indicated by little arrows)
- remove two screws on each side (there are only two, this should be obvious)
- when looking at the back of the unit, slide it up and towards you.
You should now be able to see your DVD. However there is a piece covering it.
2. Take off the top of drive:
- remove two screws, (one on each side). They are very small (probably black) and on the top of the cover, on the far left and right. They might be hidden under small rubber squares. If so, just peel the squares off.
- The cover should come right off.
- lift out the disc
3. Reassemble
good luck,
Oct 25, 2007 | Memorex MVD2042 DVD Player
Memorex MVD2042 DVD Player Logo
1,716 people viewed this question
Top Memorex DVD & Blu-Ray Players Experts
Jonathon summesfield
Are you a Memorex DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
