Take the unit off of the tub and see if there is a seal there,if there is a seal there try putting some silicone caulking around the seal or where the seal would be and then put the unit back together but don't over tighten the unit until the caulking is cured(24hrs) and then tighten the unit back up and this should seal it back up,unless the water is leaking past the actual switch itself,then you will need to replace this switch!Good Luck!!
SOURCE: Leaking pipe in a jacuzzi hot tub
The only product I know of which will do what you ask is an item called Plast-Aid Acrylic and PVC repair kit. Google it and you will find the website. It is about $20. and it works like a charm. good luck
SOURCE: My jacuzzi works fine but the air button seems
Lots ot time a small spider nests in the tube or switch body. If you can detach the tube at the switch and run a pipe cleaner down to clear the web, that might help. also look for cracks or holes in the tubing.
