Question about Stoves 720EF Electric Double Oven
How do i change the element on my bottom fan oven (stoves 720ef
  • 250 Answers
The manufacturer's handbook tells you how to do it (it is at the back). I have scanned my copy and it is on my BT digital vault, so if you want a copy, post here an email address for you and you can have a copy.
Posted on May 09, 2009
Just moved, can not get stoves double oven to work light and fan comes on both ovens but no heat
On the main oven, does the circulating fan at the back of the oven start to rotate when you switch it on and does the fan oven neon illuminate as well.
For the top oven, the heating element is not very big so the oven takes a long time to warm up. Does the top oven neon illuminate when you switch this on as well?
Aug 02, 2011 | Stoves 720EF Electric Double Oven
Hi, my Stoves 720EF is 16 years old. We have had no problems until today when we noticed that the main oven was not heating up. The light and fan come on, but no heat. The timer is not set. We have...
Peter
ISOLATE MAINS POWER BEFORE WORKING ON ANY APPLIANCE
It sound like an element problem, but, you need to investigate, before we can go ahead to define the exact problem, the varistate control is working because the fan operates.
Remove the ovens, remove the rear and may have to remove the top, or sides, remove the bottm fan, you should be able to vue the element, look for Black Grey burnt blow out, not carbon or food spots, if you see or feel a rough spot on the element, it probabily is blown. Replace heating element. Seach in whitegoods.co.uk for part, you will need model and serial numbers.
Hope this has been helpful
John
May 17, 2011 | Stoves 720EF Electric Double Oven
Oven fan not working
If you select the function on the selector switch which turns both the fan forced fan and the oven element on at the same time and the fan does not work, but the oven element does then the fan forced fan is faulty and requires replqcement.
Feb 25, 2011 | Stoves 720EF Electric Double Oven
Can i slow cook in my oven, does it have aslow cook facility i have lost my manual, if it does please explain what to do. thanks
No, there is no slow cook. The bottom oven works as a normal fan assisted oven and the top oven relies on elements concealed in the floor. The top oven takes a long time to warm up.
Oct 30, 2010 | Stoves 720EF Electric Double Oven
The fan oven has stop working can i fix the problem
If the fan is working o/k, then you need to replace the oven element located at the rear of the oven compartment behind a removeable cover.
Oct 03, 2010 | Stoves 720EF Electric Double Oven
Bottom oven is not working even though the top one is 720EF model
When you turn the bottom oven on, does the fan start to run in the oven? Do the oven lights come on? Does the main cooling fan switch on? Does the oven control knob illuminate? Does the thermostat neon illuminate?
As a guide, the power/control for the bottom oven is via the main switch on the front panel. Power then goes from the switch through the thermostat to the the oven/element/fan. The lights go direct from the switch.
I hope this helps.
Sep 17, 2010 | Stoves 720EF Electric Double Oven
My Stoves 720EF oven blows the trip when cooling fan stops
The fan timer printed circuit board controls the cooling fan and there is also a resistor on the terminal block of the cooling fan. One or both of these could be suspect. If the fan still runs, then the resistor hasn't gone open circuit and is still providing continuity. The only way to prove out the circuit board would be to change it, but that could be expensive especially if it doesn't cure the problem.
Aug 23, 2010 | Stoves 720EF Electric Double Oven
Grill trips my electrics on Stoves 720EF
I had problems with tripping and it was a faulty RCB on the consumer unit. But it wasn't just one appliance causing the problem.
Have you isolated it to the top or bottom oven. If it is the main oven, then it could be anything associated with the operation of that component, i.e. the oven control knob,the oven thermostat, the element, the element fan, the overheat thermostat all could have insulation that is breaking down that could cause this problem.
Before you go and buy anything and if you have the time and patience and confident enough and know what you are doing, I would remove the oven from the cupboard, take off the top and back covers, note the wiring for the element, take the leads off the element and run the oven with the element disconnected and see what happens. That should prove whether it is the element or anything else.
BE CAREFUL.
Jun 06, 2010 | Stoves 720EF Electric Double Oven
Stoves 720EF - main fan not working
When you say the main fan, do you mean the background cooling fan or do you mean the circulating fan in the bottom oven?
Do you have the handbook for this oven as the wiring diagrams are included in it. If you haven't, you can take a copy from my BT Digital Vault - all I need is an email address to register you.
Looking at the diagram, the power for the cooling fan comes via the timer board. If, as you say, the fan doesn't work at all, the timer board could have gone faulty.
Nov 15, 2009 | Stoves 720EF Electric Double Oven
Bottom filament on bake not working but broil and
FAULTY ELEMENT OR THERMAL SWITCH. HAVE IT CHECKED OUT BY AN ELECTRICIAN.
Sep 07, 2009 | Stoves 720EF Electric Double Oven
Stoves 720EF Electric Double Oven Logo
158 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
