Question about E-Machines T2792 PC Desktop
No power to the CPU
Hi, I have checked all the cords and the surge protector all are in working order. Everything plugged to the surge protector works except the CPU. I made sure the power cord is secure, still dead. Although I did hear a ticking sound inside the CPU, maybe it was the harddrive trying to kick. My Wife's computer. it is about 3 years old. Do I need to take it to Best buys or someplace like that? Is the Geek squad expensive?
  • Anonymous Dec 11, 2007
    Machine will only stay on for 30 seconds, then orange light stays on but it will not boot up.
Cfsdsdws
Posted on Dec 09, 2007
Thanks, I found the problem, I opened it up and vacumed out all the inside and blew out all the dust around the fans. then turned it back on and it worked. So thanks for all your help. Dennis
Posted on Sep 11, 2007
  • 89 Answers
Well look check thing in order first check the power cord the one which is pluged to the Power supply then check power suppy see if it is working try to smell it may be it had gone . then check the power switch see if they are working then see if there is leds is on that's how it goes .
Posted on Sep 10, 2007
SOURCE:
My stereo just quit on me there was bad weather but it was on one of those power surge cords it is a pioneer stereo fm-am digital synthesizer tuner
If it was plugged into a surge protector, check the surge protector warranty. There are A LOT of surge protectors that will cover damage to items plugged into them through their warranty system. I've had full home computers and TV's replaced by surge protector companies to avoid having a hit to homeowners insurance.
Aug 16, 2016 | Pioneer Audio Players & Recorders
We had a power outage, now pixma Mx410 won't come on, any ideas?
Is pinter plugged into a power strip? Try plugging directly into wall. Make sure wall outlet is working correctly, try another item in plug in. Does printer have a power module or brick that is plugged into printer? That power module is there to protect your printer during a power surge, it may need to be reset. Is there a light on that brick or power module? If so, does it light up? If not, could be a bad power module. There is no such thing as "reset" button, so don't look there...It will have to be reset in a series of ways for an "external" module.
  1. Disconnect the power cord from the rear of the printer.
  2. Unplug the power cord from the wall outlet, power strip, or surge protector.
  3. If the printer uses a power module with a detachable power cord, disconnect the cord from the power module.
  4. Wait 15 seconds.
  5. If the printer uses a power module with a detachable power cord, reconnect the power cord to the power module.
  6. Reconnect the power cord to the rear of the printer.
  7. Plug the power cord directly into a wall outlet. Do not use a power strip or surge protector.
  8. Check to see if the power module or the power cord has an indicator light and if it is on
For an internal module:
  3. Wait 15 seconds.
  4. Reconnect the power cord to the rear of the printer.
  5. Plug the power cord directly into a wall outlet. Do not use a power strip or surge protector.
  6. Check to see if the power module has an indicator light.
Not sure if this will help you..but worth a try.....
Jun 15, 2014 | Canon Pixma MX410 All-In-One Printer
A power surge fried my Epson Home Lite projector HDMI port......how much does it cost to repair or is it pretty easy to buy the part & fix yourself?
I have lost many things to power surges; sometimes it's only the electric cord (can be replaced), sometimes it's the battery (for lap tops), sometimes it's the electrical socket itself (try plugging into a different one). Worst case scenario the whole thing is fried (not all power surges are equal) now that I have everything plugged into surge protectors I only see them fry (beats losing another computer) try plugging it in without the surge protector or extension cord (if you were using one).
Oct 17, 2013 | Video Game Consoles & Games
Olevia 37" no picture
check the TV power cord first., try to plug any other appliances on the same surge protector or outlet, like electric fan, electric iron., see if's work., if it does, probably the power supply of your TV is in trouble.
May 09, 2010 | Olevia LT37HV 37 in. HD-Ready LCD...
I have a gateway desktop computer. Recently moved
Before you actually replace the power supply, check some other things first:
1. Wall socket
2. Power strip/surge protector
3. Power cable
4. On the back of the computer, where the power cable plugs into, is the red switch set to 115? It should be 115.
5. Make sure that the power cable is not connected to a regular extension cord. Power cable must plug directly into a surge protector that is not daisy-chained to another power strip, surge protector, or normal (household) extension cord. Surge protector must be directly plugged into wall socket.
If none of the above solve the problem, open up the case and ensure that all power connections are secure. Also check ALL other components' connections. Any loose connections can cause problems for you.
If everything is secure and the problem persists, replace the power supply.
Nov 27, 2009 | Office Equipment & Supplies
Last night I turned-off my PC througg Windows and when I pushed the power button this morning nothing hapened. There is no sign of "life" from the PC.
Check the power source to the computer (both ends of the cord), if a surge protector is in line with the power , remove it and plug the computer straight into the wall. also check the wall plug with a lamp or something to ensure power there. make sure the switch on the power supply hasnt been changed to the 220v side.
If no power at the wall- check your breaker box in the house
If it works plugged straight into the wall- check the surge protector
If power at the wall and plugged straight into the computer (no surge protector) and nothing lights up when you turn it on- have your power supply checked.
Oct 08, 2008 | Acer Computers & Internet
Compaq Desktop won't start after city wide power failure
Dear! format your system and istall drivers after individual reboot ..
by khalid (Kashmir)..
E-mail:[email protected]
May 05, 2008 | Compaq Presario S6300NX PC Desktop
Surge Protector
Surge Protectors are devices that usually you plug your equipment to.. and it protects it from Voltage Spikes that would otherwise destroy the device without it.. saddly not all Surge Protectors are the sam.. some are completely useless..
If you are really serious about protecting your PC not just the hardware but also the data and your work.. might as well invest on a UPS(Uninterrupted Power Supply) unit.. it has everything a surge protector can offer and more..
Apr 28, 2008 | MSI 845E Max2 LR Motherboard
TV won't turn on after power outage
LOT OF TIME WHEN YOU LEAVE IT OFF FOR THE NIGHT DISCONNECT POWER CORD DEFECTIVE SURGE PROTECTOR IS NOT GOOD FORE EVER PLUG TV IN THE WALL WITOUT THE SURGE PROTECTOR IF IT GOOD CHANGE THE SURGE PROTECTOR FOR NEW ONE CHEERS
Jan 17, 2008 | Hitachi 60UX54B/55K 60" Rear Projection...
Compaq intel pentium 42.8ghz512mb
How old is your computer? Did you recently have a power outage or anything? Most the time if a computer won't turn on, something in it went bad OR an outlet is bad. Try this:
1. Make sure that the power switch is on, the switch in the back (on the power supply itself) is turned on, and everything along those lines is functioning.
2. If that doesn't work, and it will not power on AT ALL, make sure the cords are plugged firmly in place, including the surge protector and/or the power cord itself.
3. Try resetting the surge suppressor and/or plug the computer into a different outlet in the surge suppressor. Try other items in that surge suppressor (or even in the wall outlet, if that's what you're plugged into) to make sure that the outlet itself is working.
4. If your computer is plugged directly into a working wall or surge suppressor outlet, try a different power cord.
5. If your surge suppressor works, your wall outlet has power to it, and you are using a known-good power cord in the computer, you will have to go into more in-depth investigation as something inside the computer likely went bad. It could be the video card, motherboard, CPU fan, power button, or the power supply itself. Start by testing the video card and the power supply by (one at a time) swapping out a known-good component for the one you suspect may be bad. If it won't turn on after that, try swapping out the next and try it again. If it still will not work, it could be something more serious such as the motherboard or power button.
it could be a bad power supply or a bad motherboard. Other problems might cause issues, such as a bad video card.
Jan 16, 2008 | Computers & Internet
Open Questions:
See all E-Machines T2792 PC Desktop Questions
E-Machines T2792 PC Desktop Logo
140 people viewed this question
Top E-Machines Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
