Klipsch 2.1 subwoofer
I have the klipsch promedia 2.1 system for my computer. I noticed that the right speaker does not work unless I plug both positive wires into the left side of the subwoofer. Any suggestions?
5 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: wiring for Altec Lansing avs500
Hi, from a very old Altec ACS48 : Green - right speaker Red - left speaker Black - common, ground White, Yellow & another Black - power switch Orange - Led indicator Below is the pin layout
Posted on Jul 30, 2007
billspeer
  • 180 Answers
SOURCE: left computer speaker is unpredictable
Take no offense but after 8 years, you got your moneys worth. Unless you're good with the soldering iron and schematics, call it a great investment and update your speaker system. I imagine your computer is newer than the speakers and you can take advantage of some 5.1 surround sound! It's really great if you do any gaming,too.
Since you'll probably be getting rid of them anyway, you might want to crack it open and see if there's any loose wiring that can be fixed.
Thanks for using Fixya.com. Please rate this tip accordingly. I wish there was a better solution but I usually get 5 years out of mine so I feel jealous. :-)
Posted on Jan 11, 2009
satavlad
  • 405 Answers
SOURCE: We have the Klipsch ProMedia Ultra 5.1 Multimedia
Amp plate on the back of the sub has to be replaced. Contact klipsch for parts.
Posted on Oct 25, 2009
  • 48 Answers
SOURCE: Does my Harmon Kardon HK595 subwoofer need to have
does the sub have a power supply, ie a power cord, if it does this is do able if it does not, then it has no amp for the sub and would require that
Posted on Jan 16, 2010
I never used my 10sw klipsch subwoofer and it's not working.
Check the cone surround - unless it is a rubber butyl surround, the material self destructs in air after about ten years and the speaker will stop woofing.
Apr 05, 2015 | Klipsch Audio Players & Recorders
Poor volume when hooked up to tv output
These aren't designed to be driven by the audio output of a TV.
Feb 16, 2014 | Klipsch Promedia 2.1 Thx Certified...
Lost sound in left channel?
I presume you are playing a stereo cd. Plug some other device, like headphones in to see if the computer is putting out stereo. Use the same plug as the speaker system is plugged into.
I presume you have swapped the speakers to test them.
If the speakers work, and the headphones work, it's the amp.
Nov 26, 2013 | Klipsch Promedia 2.1 Thx Computer Speaker...
Klipsch Synergy Sub12 Subwoofer Speaker
If it's a new model you should send it back.
If it's not then it sounds like the thing that does all the work has gone. It will be found on a heat sink. Try replacing that.
Jan 25, 2013 | Klipsch Synergy Sub12 Subwoofer Speaker
Crackling when i manipulate the volume control... little or no audio out of the speakers intermittently
control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers if you have tried this you might try
control panel,administrive tools,computer management,device manager,sound,right click select properties to either troubleshoot,uninstall,rollback driver or select system devices from the device manager scroll to speaker right click to update driver,disable,scan for hardware changes or select properties to troubleshoot,then select driver to uninstall,rollback,uninstall then reinstall
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
Nov 01, 2010 | Klipsch ProMedia Ultra 20 2 Speakers
How to hook up speakers to emachine t3638? i have the klipsch 5.1 set
The EMachines T3638 comes with High Definition Audio support and you should be able to connect a 6 speaker system (1 subwoofer and 5 speakers).
I believe they are color coded as well. I believe the speaker set you are referring to is the Klipsch ProMedia Ultra 5.1. Is that correct?
Below is the a link to the connection instruction manual. It is a pdf document that you can print out. The instructions for installing the Speaker set is on pages 3 & 4 under Signal Connection and Speak Connection.
http://www.klipsch.com/media/products/owners-manuals/ULTRA51MANUAL_ENGLISH.pdf
It should be pretty straight forward, but send me a note if you have any questions about the process.
MO
Jul 13, 2008 | Computers & Internet
Klipsch subwoofer
its all about impedance matching...did you check to see that the new yamahas would drive from the system, before installing them? sounds like you will need to possibly add a matching transformer or other device on this one.
Mar 09, 2008 | Gem Sound SUB-650M Speaker
Klipsch subwoofer
how are you connecting the sub to you amplifier?
Dec 11, 2007 | Gem Sound SUB-650M Speaker
Klipsch Speakers 4.1 died suddenly
Humm. Plug some earphones or another set of speakers into the computer and see if you get sound. That will at least point you in the right direction. And not to insult your intelligence but make sure the speakers are plugged into the green port.
Nov 10, 2007 | Audio Players & Recorders
282 people viewed this question
 Grubhead
Grubhead
