Question about JVC MX-GT88 CD Shelf System
Lights everything seems to be on, but no sound
Just got this unit from a friend that had given up,no sound, just a little static when it is plugged up. Everything lights up and seems to be ok, but no sound on anything
    Problem Solver:
  • 3 Answers
Make sure the speakers and everything are hooked up correctly and try to use the different functions if you have an aux cord use it with an mp3 player or ipod and see if it will play music if you've already done that well then i dont know what to tell ya
Posted on Feb 25, 2010
My denon avr-985 has no sound coming out of it why could this be
Go though your menu on the reciever, Look for the speaker functions for your front end rear speakers ,It was probably turned off. Was it working before you got it from your friend,
Sep 20, 2012 | Denon Avr 985 7.1 Channel 945 Watt...
Sound - audio is not working on anything..which one is the sound board to replace?
Is the audio problem present on all iputs? Your problem could be the power supply or the A/V board. Proper troubleshooting would need to be done to verify which one it is. I would lean towards the A/V board.
Sep 03, 2012 | Sharp Aquos Lc32d62u 32-inch 1080p Lcd...
Powers up, all lights buttons seem to work, but no sound
This can happen. Lightening causes static charge that can be picked up by speaker wires. It is possible ONE of the amplifiers has failed.
To check, have the room quiet. Turn on the amp. After 5 to 10 seconds there should be a nice solid 'CLICK' from inside the amp. If there is no click, the unit is in safety mode. You will need a service shop.
Apr 17, 2010 | Sony STR-DE835 Receiver
No sound from speakers. Everything else OK.
If headphones work then so does the amplifier. When did this problem start? From what I can find it almost sounds like it thinks you have headphones plugged in, which would disable the speakers.
Apr 24, 2009 | Audio Players & Recorders
Static Noise from guitar amp.
I take it you have made sure that both the cable to the distortion box from the guitar and the cable to the amp are both good. From the description you give, it sounds like there is no signal getting to the pedal. If the cable is good, then the next likely suspect would be the input jack on the fuzz box. Try wiggling it a little with the guitar cable in place to see if it is loose. Some input jacks are unbelievably cheap and flimsy. A crackling sound (static like) is almost always a bad connection. If it was the output jack, I would think that the guitar signal would come through a least a little bit, but you might want to try wiggling that one, too, if the input jack isn't the culprit.
Another possibility to check is the battery, but this doesn't seem as likely. Some effects units devour batteries, especially units that use 9V batteries. I have a multi effect pedal that kills a 9V in about an hour.
Jan 22, 2009 | Epiphone Les Paul Studio Electric Guitar
Screen won't turn on
when the computer boots does the screen light up? if it does the first thing you need to try is when you turn the computer on is to option boot. That is done by holding the option key while turning the computer on. after it boots you will see the the hard drive listed on the screen it will be a icon, if there you should be able to boot up. If the computer does not boot and your hard drive is still listed you most likely have a logic board aka mother board issue.
Jan 11, 2009 | Apple iBook G4 Mac Notebook
Phillips 42PF9631D 42
Do you hear a clicking sound when you try and turn it on? If so how many clicks? Also do you have and sound from the unit static or anything?
Oct 08, 2008 | Televison & Video
Got a marantz 2220B Stereo Receiver. Everything works but getting some unwanted static after the unit has been on for an hour or so. Any ideas? THanks
Hi mdpagan
There are lots of mechanical switch contacts to these old girls. Go about wriggling and tweaking with all the controls and switches on the amp. You may find one of these to be the source of static. These sorts of problems can be sorted out with a squirt of CRC2-26 into the switch or control that is noisy. If it is not this, it may have a leaky capacitor or noisy transistor. the mains switch can produce strange static also when they get a little tired.
I am more than happy to answer any other questions you may have about it, just give me a hoy :) If you are still unsure, or have problems, then before you give a rating for this advice, please get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Jun 11, 2008 | Marantz Audio Players & Recorders
Can't get my durabrand uc-280 computer spreakers to work
Returned the durabrand uc-280 to Walmart! Plugged the existing speaker into the correct hole in my new sound card. Problem solved!
Feb 16, 2008 | Audio Players & Recorders
Screen
Sounds like a hardware problem with the screen. Try switching the video driver temporarily to one of the Microsoft standard drivers (like VGA STANDARD) and check if the problem is any different. If it is, then it is a software driver problem. If the problem is the same, switch the driver back and try this.
These solutions may damage your machine, so do so at your own risk.
Get the machine running normally and then try the following tests, watching for the static on the screen to change (get better, get worse).
- Tap lightly on the sides of the screen unit
- Open and close the screen unit lid to the full extent in both direction
- *Very lightly* twist the base of the computer one way and another - lightly, just enough to put a little pressure on the case
- *Very lightly* twist the screen unit slightly by the corners - lightly, just enough to put a little pressure on the case
- Tap on the corners of the computer's base unit like knocking lightly on a door
If any of these physical tests change the static on the screen significantly, you have hardware troubles. If this is the case, either take it for professional repair, or, at your own risk, try this.
It is very likely that you either have an electrical short or that the ribbon cable connecting the screen to the motherboard has come partially unseated. Find a friend who knows about taking things apart, tell him you think this might be the problem, and ask him or her to help you lovingly disassemble the machine looking for possible hardware problems. Remember to do anything like this with the machine completely unplugged and the battery out, and as a last resort on a machine you need but cannot afford to fix.
Final hint: if tapping or twisting the screen lightly changes the static, you probably have a ribbon cable or other hardware problem *in the screen unit*, while if you have changes in the screen when you knock on the base unit, it is likely where the video signal cabling enters the motherboard.
Good luck.
Nov 16, 2007 | Toshiba Satellite M115-S1061 Notebook
JVC MX-GT88 CD Shelf System Logo
132 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
