Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
U3 2GB Cruzer Micro wont work on my vista laptop.
When i put the flash drive into the USB port it says "please insert software for U3 Cruzer Micro" When i purchased the Cruzer it said that it did not need any software. The Flash drive refuses to work without the software.Any help will do thanks.
  • 8 more comments
  • Anonymous Nov 22, 2007
    Yes, I have the same problem
  • Anonymous Nov 30, 2007
    notify me
  • Anonymous Dec 27, 2007
    have the same problem here - says i need a driver cd when i dont really need it or so Sandisk says
  • Anonymous Jan 07, 2008
    Exactly the same problem, U3 Cruzer Micro 1.0GB flash drive that won't work on my new Toshiba Laptop.
  • sukisen Jan 09, 2008
    I am using VISTA as the operating system. while plugging in my scandisk 2gb cruzer, I getting a problem like unable to find the drivers.
    Any body pls. let me know what can be done now? will it be good to re-use again or just throw away?
  • Anonymous Feb 17, 2008
    It did not work in my laptop I don't know what is the problem
  • Anonymous Mar 24, 2008
    same cruzer micro usb flash drive wont work on my laptop either ! without software that apparently it did not need ! running vista
  • jimmieanna Apr 05, 2008
    exact same problem, i have spent the last hour with dell, they don't know how to help
  • ImShaune Apr 06, 2008
    I have the same issue with my Sandisk Cruiser Micro 4gb. I've tried all the suggestions listed below. The issue seems that Vista does not even recognize my flashdrive as a flashdrive. After downloading each suggested software I get a "cannot find device" or "insert a u3 compatable device."
    My flashdrive works great on XP... Strange that its no dice, whatsoever, with vista.
  • bloderme Aug 06, 2008
    My scandisk is in the usb port but the red light does not flash on. How can I install my divice on my gateway computer?
Dont install the link above. it erased everything i had on my flashdrive....muther fuker...now i;m pissed
Posted on May 13, 2008
Hi there, I found the solution (for all 4GB flash drives).
Initially when I plugged in my PQi 4GB flash drive with Windows Vista,
there was an error message involving " Can not find the drivers needed ... "
Simply download & install "Windows Vista Service Pack 1"
it is about 444 MB in size.
The whole process might take about 2 hours to install,
but it is worth it.
These are the links where you can find your download:
http://technet.microsoft.com/en-us/windowsvista/bb738089.aspx
OR
http://www.microsoft.com/downloads/details.aspx?familyid=090DEAF6-2EAA-4AAA-8B3B-2E199DB4A97D&displaylang=en
It works perfectly... good luck now...
Posted on May 03, 2008
Just give up
Posted on Apr 03, 2008
Did not include one .ddl file...said it was missing when i tried to download it from suggested file folder.
Posted on Dec 27, 2007
    Problem Solver:
  • 13 Answers
Try to uninstall the U3 software from your Flash drive by going here http://www.u3.com/uninstall/
After uninstall it will not ask you for any software and it will not create another virtual drive.
Posted on Mar 12, 2008
    Problem Solver:
  • 6 Answers
I had the same problem.' Download this: http://www.sandisk.com/Retail/Default.aspx?CatID=1411
Posted on Sep 11, 2007
SOURCE:
I would like to transfer photos' from laptop to cruzer using Window Vista! How to do that?
Hello..
Insert the Cruzer and allow your computer to acknowledge it. You will know this by going to "My Computer" and double clicking. You should see that the computer has assigned a drive letter to it. Double click that drive letter for the Cruzer. With that window left open, find were your photos are. Open the folder were the photos are located. With both windows open you can now drag the photos over to the Cruzer and drop them into the window for the Cruzer.
Good Luck
Jan 12, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
My usb 4gb flash don my computer only reads in a secure K with 1m
See http://www.maxell.eu/FAQ2/FAQ.html
Venture USB contain two partitions - one named 'Public' and the other 'Secure'. Unfortunately we have noticed a compatibility problem between these drives and some computers running Windows Vista. In these cases only one drive is showing in 'My Computer' - usually the 'Secure' drive. As a result you are unable to access the user manuals and software which are in the 'Public' drive and cannot alter the partition sizes to allow access to the entire capacity.
Please follow the below instructions to resolve the problem:
1. Connect the USB to the computer
2. Please unzip and run the attached program
3. After completion please unplug the USB
4. Re-insert the USB to the USB port
5. You should now be able to access both drives.
Please click here to download the program and instructions
Dec 28, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Can't open my sandisk cruzer 16gb
Dont worry about being prompted, that is an OS option and you may of turned off by accident. When you insert the flash drive into your USB port, does th elight on the drive ligh up? If not your flash drive may of gone bad.
If it does light up, click on "My Computer" and see if it shows up there.
Apr 03, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Sandisk cruzer micro
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Oct 24, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk flash drive
Strange... Vista does seem to have a problem with everything Sandisk...
Anyway, this should be all you need:
Launchpad Installer
Launchpad Uninstaller
Mar 19, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk 4GB cruzer micro usb flash hard drive
try removing off the launchpad program from the pen drive through an XP system with this software and then try inserting it on the vista as an ordinary pen drive.
Mar 17, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk flash drive
Is the account that your tying to access the drive with an Administrator account? If not, Log in as Administrator and try to access the new drive. If you ARE using Administrator privileges on the vista machine, the problem lies in the U3 smart driver. Try downloading and installing the drivers for the XP SP2 os on scan disks website, If vista rejects the install package off of the scan disk website, let me know and i'll extract the drivers and build an install for them for you.
Nov 29, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk flash drive
Vista has not been out long enough for any company to state that there product is compatible. I would check there website to see if they have updated drivers that will make the sandisk usb drive compatible. This may fix the problem!
Nov 24, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
2,178 people viewed this question
Top SanDisk Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
