Question about Toshiba Satellite 2540CDS (PAS254U-S2CW8) PC Notebook
Need to add more memory
How can i add more memory to a 2540cds or 4010 cds toshiba satellite laptop. is the board soldered or a slot
Toshiba satellite 4010 CDs asking for password windows 98
Download UBCD or Hiren or use OFFLINE NT password recovery tool and reset the password.
Dec 06, 2012 | Toshiba Satellite 4010CDS Notebook
I have a toshiba CDT 1625 laptop, and it's RAM capacity is set at 191Mb,I was wondering if there was a way of increasing the capacity? I can get more RAM for it, but the machine itself won't recognize more...
Click here for disassemble it another model but as well as your model for gathering the experience
  • Toshiba Satellite 1605, 1620, 1625, 1640 CDS/CDT Series Notebook Computers System Type: Laptop ;
  • CPU: AMD K6-2 Processor
  • Standard Memory: 32MB or 64MB (soldered) ;
  • Maximum Memory: 160MB or 192MB
  • # of Memory Slots: 1
.Regards
Shibuda
Jan 06, 2011 | Toshiba Computers & Internet
How can I increase memory of toshiba Satellite A105
A RAM expansion slot is located on the bottom of the laptop behind a small panel. Remove the panel to get access to the RAM slot/s. It may have two RAM slots, if it has only one the the 1st RAM slot will most likely be located under the keyboard.
If the laptop has two RAM slots on the bottom of the laptop and the 2nd one is empty then you can add anothe RAM module. Try to get the same make and model as the original to double your RAM..
If both slots are occupied then you need to replace the existing RAM with larger capacity RAM modules.
Sep 02, 2010 | Toshiba Satellite A105 Notebook
I need to increase the ram in my toshiba sattelite 160 laptop I only have a half gig I heard that the memory is fixed on the laptop and might have to replace mother board
Your laptop comes with a memory module that is soldered onto the motherboard and is non-removeable. You have one slot where you can change out the memory module. You are capable of putting one (1) GB module in that slot. Below is the specs for that memory module.
  • Maximum Memory: 1280MB
  • Slots: 1 (1 bank of 1)
  • Standard Memory: 256, 512, or 768MB (256MB non-removable)
  • USB Support: 2.x Compliant
  • DDR PC2700
    Nov 26, 2009 | Toshiba Satellite A60 Notebook
    Satalite m35x-s161 how to replace the keyboard?
    Toshiba Satellite How to remove keyboard and upgrade memory modules. This post was written by cj2600 on April 28, 2006
    Posted Under: Toshiba Satellite A20/A25 --> toshiba-satellite-a20-a25-memory.jpgRemoving and replacing memory on a Toshiba Satellite A20 or A25 notebook is not as easy ad it should be. Both memory modules are located under the keyboard. A laptop keyboard has to be replaced in order to get access to the memory modules. Before you remove the keyboard do not forget to remove the laptop battery or you can damage the laptop. Be careful when you remove the keyboard securing strip; do not bend it too much. To remove the memory module from the slot on the system board, release the latches on both sides and the memory module will pop up. It will stay at a 30 degree angle to the system board. Firmly grasp the memory module and remove it from the slot.
    Oct 31, 2009 | Toshiba Satellite M35X-S161 Notebook
    Toshiba a60 on board memory faulty
    i found this page on that problem.
    http://www.laptoprepair101.com/laptop/2007/04/27/toshiba-satellite-a60-a65-problems/
    hope it helps
    Aug 18, 2009 | Toshiba Satellite A60 Notebook
    Toshiba A75-S211 memory
    I'm showing a base memory on that unit of 256 so your max upgrade is 1gb to 1.2gb total.
    1GB (1x1GB) Toshiba Notebook 2.5v PC2700 DDR333 SODIMM
    Apr 14, 2009 | Toshiba Satellite A75-S211 Notebook
    Adding memory to Toshiba A75-S211
    you buy the memory here for a great price or anywhere online instructions are on the page
    it replaces the 512
    http://cgi.ebay.com/1GB-DDR-333-for-Toshiba-Satellite-A75-S211-Memory-RAM_W0QQitemZ250353026446QQihZ015QQcategoryZ158897QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
  • Memory Card for Toshiba Satellite A75-S211 Memory RAM- Designed and Optimized
  • Toshiba Satellite A75-S211 Memory RAM Memory Upgrade -Easily installed
  • More Memory Equals - More Speed for your APPS
  • The Toshiba Satellite A75-S211 Memory RAM has a memory card slot or slots, that allows you to add more memory to your Toshiba Satellite A75-S211 Memory RAM, giving you enhanced performance and speed. You will see the Immediate speed increase in your computers performance.
    Stop waiting for programs, and functions to happen, STOP WAITING!!! Start enjoying technology as you should.
    We work directly with our memory card manufacturer to insure perfect compatibility with the Toshiba Satellite A75-S211 Memory RAM. Only using the highest quality memory chipsets for our memory cards, so you are assured compatibility and performance. All of our memory cards are Designed and Optimized for Toshiba Satellite A75-S211 Memory RAM . Technical specialists have personally verified our memory cards compatibility with the Toshiba Satellite A75-S211 Memory RAM.
    Worry Free Installation: Just Follow these Steps Desktop and Laptop instructions below.
    Desktops
    1. Unplug Power cable
    2. Remove Case
    3. Slide memory card in Open slots- the memory card will only fit in one way
    4. Snap the side clips in place
    5. Close Case and Power Up
    6. You are ready to go.
    Laptop
    1. unplug and remove Battery from laptop
    2. Open memory compartment on bottom using Philips screw driver
    3. inset memory in open slot, if no open slot remove current memory by pinching metal clasp on side of memory
    4. Close compartment and power up you are off and running.
    Jan 26, 2009 | Toshiba Satellite A75-S211 Notebook
    Can I add another 512MB of memory to my A105 satellite toshiba
    i dont know as much about laptops but you should be able to get the 512MB. to replace it look on the bottom on the laptop there should be somewhere down there that you can open up the to put it in.
    Nov 22, 2007 | Toshiba Satellite A105 Notebook
    Toshiba Satellite 2540CDS (PAS254U-S2CW8) PC Notebook Logo
    Top Toshiba Computers & Internet Experts
    k24674
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
