Question about Craftsman 24 Hp 48" Deck Yard Tractor
I have a Craftsman mower with 17 hp Kohler engine(CV4905) .I thought the battery was bad because it is a 2003,but when I jump it off now it dies when I remove the cables.Can anyone please tell me what to do and where anything I need to replace is located on the engine? Thanks so much
  • 5 more comments
  • ma8cla Apr 12, 2009
    Not yet because since I can jump start it to get it running I was puzzled about why it would not stay running after I remove the cables.I was wondering if something bigger was at cause for the dying after dissconnecting of the cables?
    The mower will start if I jump it off but as soon as I disconnect one of the cables, either pos. or neg. it shuts off.It has been letting me jump it off and mow but yesterday while I was mowing it just shut off and now when I jump it off it dies when I remove the cables.Thats why I was wondering if something in the charging part was amiss.I dont know.Plus I dont know where there might be a fuse to check because I just came back in from looking for one and didnt see one.
    What now
    The battery is bad so Im going to get a new one on Monday, but its suppose to rain the next couple of days so I will let you know what transpires after a new battery is put in when it stops rainning.Thanks for all your help.I do appreciate it.
    Thanks
  • Anonymous Apr 14, 2009
    I dont understand what you are asking.Im confused.Can you explain in a differenr way?
  • Dennis Yachimec May 11, 2010
    Hi
    If you have a battery charger put the battery to charge for a couple of hours and then try to start the lawnmower. Please let me know if this works.
    Hi make sure battery cables and battery posts are clean. hook up booster battery and test battery voltage with out starting mower, should be about 12.5 volts. now start eng. and see if voltage comes up to 13.5 or higher, if not you got a bad fuse or broken wire between eng and stator.
    Hi
    Did you replace the battery?
  • 137 Answers
Do you have to plug the battery in in order to recharge it?
Posted on Apr 13, 2009
Kohler cv15s
Your battery may bad. Unhook it,check voltage, charge it 24 hours. Check voltage, should about 12 volts. Let set 24 hours, check voltage , if not 12 volts, no good.
Aug 20, 2013 | Craftsman Garden
My 19.5 hp briggs and stratton engine is geting fuel and spark and the starter seems to act right but it does bind at times i have rotated the engine by hand and it does get pretty hard to turn in
try and jump start it with your car to see if the battery is weak if still struggle to crank try and jump direct to the starter motor if struggles direct to the starter then the starter appears to be bad
Aug 14, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 17.5 hp kohler engine
see if your loosing spark when it dies maybe the coil is going bad
May 14, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My craftsman gt5000 25 HP kohler ran then engaged the blades and it died now it will not even turn over I tried to jump start it and it acts like it has no power to key switch or maybe problem with...
OK. there is a inline fuse, it is usually on the red cable leaving the battery, if will be close to the battery, follow the cable until you see the fuse. sometimes they are located under the plate of the the transmission(middle between seat and steering wheel) Hope this helped Tim
Mar 19, 2011 | Craftsman Garden
Electrical schematic
i need a diagram for the ignition switch on my craftsman mower
....7 prongs all labeled with letters sure what 3 are for not other 4
Apr 10, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My craftsman mower with a 26 hp kohler dies when choke is in
carb dirty, jets partially plugged, float sticking. Not so uncommon problem and is caused by the fuel left in the carb over the winter gumming up (going bad). You can attempt to clean this on your own if you are somewhat mechanically inclined. Search small engine repair and it will give you a generic breakdown of the parts in a small engine carb. If not the, to have someone overhaul a small engine carb will run you about $120 including parts (at least around VA).
Apr 04, 2010 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
2 mowers 19.5 hp and 27hp kohler, both die when you let off brake
Sure sounds like an elusive safety switch to me. There's usually one on the seat, the blade control, and the brake.
Jun 04, 2009 | Garden
Kohler engine wont recharge on tractor
Either the stator went out or the voltage regulator is faulty and must be replaced
May 29, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Missing oil dipstick
Hello:
You can Purchase a New Dipstick from your Local Small Engine Service Center or Online.
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 24 Hp 48" Deck Yard Tractor Logo
750 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
