Question about Canon FAXPHONE L80 Laser
Check paper size comes up all the time. Also pulls anywhere from 4 - 10 blank pages through at once.
Pulls multi papers through at once when receiving a fax or when printing a fax confirmation. Tried to call tech support and got now help. This unit is less than 30 days old. Tech support said nothing wrong with machine because he had me make a copy with only 4 pieces of paper in tray and it only pulled one page that time. I was told it had to be our paper. I have bought 2 different kinds of Copy paper 20lb. We fan the paper prior to using it. I don't believe it is the paper. I bought this fax because it had the capacity to load 100 pages (per manual). Tech suggested we load 10 pages. Not going to work when I receive faxes that are 50 + pages at one time. It also them flashes check paper size all the time. Any help would be greatly appre.
  • 2 more comments
  • Anonymous Nov 07, 2007
    i am having problems trying to delete entries from a group dial or delete a group dial number that i have entered. I have already tried to clear the number like the manuel says and even though it says that it is already deleted the number reappears on the group dial list. how can i delete entries
  • Tamakia Nov 09, 2007
    fax states file in memory check paper size
  • WBarnett Dec 14, 2007
    We just purchased the Cannon L80 Faxphone about a week ago and we have the same problem with it saying rec'd in memory/change paper size. We have to go through the steps to change back and forth from letter to legal size until all the pages are printed from memory. Any help on this would be greatly appreciated. 12/14/07
  • Anonymous Jul 23, 2008
    The fax machine loads received faxes to memory and says to check paper size. It won't print when I try to reset it.
  • 163 Answers
Dear sir pleaz select the correct paper size in the user data programing of your machine
Posted on Sep 21, 2007
SOURCE:
Hp deskjet D1660 Pulls papers non-stop and output is blank. New tricolor cartridge just put in. Pulls papers uncontrollably. please help
first check it right side feeder assay latch is ok or not if it is broken then only continues paper pulls out ...
Apr 22, 2014 | HP Deskjet D1660
Reading no paper paper tray is full
Instructions
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
I'm getting ghost images on multi prints to the point it is unreadable, is this the drum or fuser?
The only way to tell is to start a print and power off when print is still inside. If you see the ghost before the fuser it's the drum, if clean before the fuser, it's the fuser. You can also open the back door and look at the fuser roller with a light, the fuser roller should be clean but if the roller has images it's time for a fuser.
Feb 19, 2010 | Brother DCP-7020 All-In-One Laser Printer
Paper pulls in crooked with left side not pulling into the printer and then does not print at all
This problem comes from the paper wheels. There are small size wheels that feed the paper into the machine. Once one of this wheels is slipping either you change just that wheel or you change the whole set of wheels. So I would take it to a repair shop to see how much it will cost. Other wise time to buy a new one. Good luck
Jan 03, 2010 | Lexmark X2350 All-In-One InkJet Printer
P3150 printer runs but doesn't print
Are you saying that the printer prints in B&W but not in color, or only that it will print a test page with B&W? It might be that the color ink cartridge is dry.
Apr 20, 2009 | Lexmark P3150 All-In-One InkJet Printer
Pulls in multiple sheets of paper
you must not use thin paper. you should use thick paper so that it will only pull one paper at a time...
Apr 18, 2009 | HP DeskJet 940c InkJet Printer
ADF Pulls paper but prints a blank page
The wire ends have different sizes to avoid to connecting it to the wrong port. It will only fit to the right one.
If the copy prints a blank page, try copying again with the document facing up on the ADF.
Hope this helps!
Mar 03, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Pulls through too many pages at once
In the scanner where it pulls the paper in, there are rubber pads that hinder the paper feed from pulling more then one sheet. Those wear out and need to be replaced.
Feb 06, 2008 | Xerox DocuMate 262 Path-Through Scanner
Print out blank pages after clearing a paper jam
Have you checked the obvious things? Such as pulling the tape off the new cartridge? Also make sure the transfer roller under the toner cart. is in securely.
Jul 04, 2007 | Canon imageCLASS MF6530 All-In-One...
Canon FAXPHONE L80 Laser Logo
404 people viewed this question
Clive
Clive
old marine
old marine
Ekse
