Charger light won't go on when plugged in. Tried reset button nothing happened.Charger light won't go on when plugged in. Tried reset button nothing happened.
AnonymousMar 28, 2008
I tried the reset button and it still will not go onI tried the reset button and it still will not go on
whal I was driving with tom tom pluged into the lighter, all of the sudden it quit working and the screen went blank and I have not been able to start it again, the green led comes on when it is on the charger.whal I was driving with tom tom pluged into the lighter, all of the sudden it quit working and the screen went blank and I have not been able to start it again, the green led comes on when it is on the charger.
You can't post conmments that contain an email address.
If you have a tom tom from the GO models
they hace a reset button you can press with a pin were the mount fits.
When you plug in the charger the green light should come on to say it is chargeing.
Try the car adapter to charge the tom tom
try this it worked for me , hold down the reset button on the bottom of the tom tom down for 15 seconds then when done hold down the power button for 5 seconds , the tom tom will reboot from bios , as i said it worked for me good luck
Go to TOM TOM´s homepage http://www.tomtom.com/services/ Connect the GPS unit to the PC using the USB2 connection. You will be given the possibility to restore the unit´s files. This takes a while, but it solved the problem for me.
I had some problems with the 920. It started to not turn on. The it just died completely. After opening the case and testing the battery. I concluded the battery was dead and Un-chargable.
Which is most likely the case with yours.
Try this first. Then contact customer support.
Check that the battery is charged properly. Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
Remove the SD card If your device uses an SD card, remove it.
Reset your device. Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
Turn your device on. Press the On/off button for at least 5 seconds.
Insert the SD card If your device uses an SD card, insert the SD card
Unless you are good with electronics. Then id change the battery myself. I used a cell phone battery.
It has worked for the last year.
Sounds like your firmware is corrupted. I have fixed a few 910's with this same problem. If you have the Tom Tom Home program installed, try to reinstall the firmware using Tom Tom's website.
Make sure you always select to disconnect the device before unplugging it. You might have unplugged it from the PC while it was still writing data. This will certainly corrupt the firmware.
in that case you will have to take off 4 screws on back the navigation system easily take the back piece apart and unplug the battery wait couple a seconds then plug it back it should work
where is reset button on 300 gps
green light is on but the screen is blank... charged all ways but no help
only the "tomtom go" screen shows up and hangs!
turns on no screen
