Question about TORK Digital Interval Timer Ssa100r-24
Tork timer 1103 will not trip off unless lever is
Tork1103  mechanical timer  will not trip off unless lever is manually depressed. I took off the clock wheel cover off and tried to simulate tripping it manually where the pin would hit and it still does not trip off. The clock motor works fine. Any suggestions?
Thanks, L
  • Anonymous Mar 19, 2014
    The clock is working but have no power on out put when timer is tripped
  • 50 Answers
The timer should have came with a dark and light colored tabs. they must be put exactly on the rail that goes in a circle with the time on it.
Posted on Apr 13, 2009
Tork 1103b will not trip on or off switch
Might need new trippers, or the timer mechanism is worn down...
Trippers and clock motors following link:
http://waterheatertimer.org/Tork-timers-and-manuals.html
Jul 27, 2017 | TORK Hardware & Accessories
Tork model 1103. Everything works manually, but why doesn't the dial rotate to trip the on and off switches?
It is common for electromechanical timers to fail in this way. It will have to be replaced.
Nov 07, 2015 | Hardware & Accessories
GE Indoor Outdoor Timer # 15306 the clock is working and the when the time for it to go on it goes on but when the time comes for it to shut off it does not trip the off switch. I then have to shut it down...
1) If analog dial keeps time, I can only guess that OFF tripper is not in position correctly, or tripper is worn or defective, or that manual override lever is defective. Trippers are made of softer metal so they wear down before other parts of timer.
http://waterheatertimer.org/images/GE%2015306%20Mechanical%20Outdoor%20Box%20Timer-24%20Hour.jpg
2) Buy Tork P47 trippers to replace GE 15306 trippers
http://waterheatertimer.org/Tork-timers-and-manuals.html#Trippers
3) Open following link for GE timer resources:
http://waterheatertimer.org/GE-timers-and-manuals.html#15306
4) 15306 is heavy-duty indoor-outdoor version of Tork 1800 series or 7200 series 120Volt analog timer that is sold online and at Home Depot under GE brand name.
http://waterheatertimer.org/images/Tork-1800-600.jpg
5) You can buy new timer at Home Depot and return defective one in new package.
6) The on and off trippers are attached to the analog dial.
Dial rotates as time passes.
Trippers make physical contact with the manual override lever. The ON tripper pushes lever one direction and the OFF tripper moves lever other direction.
The override lever rotates a cam located on back of timer that opens and closes electrical contacts.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 02, 2011 | General Electric GE 56941 24-Hour Outdoor...
I have a Tork 1101. Please advise how to set the OFF time.
Tork 1101 is 24-hour 120Volt mechanical dial timer
http://waterheatertimer.org/Tork-timers-and-manuals.html#1101
ON-OFF trippers are placed on outer edge of dial to set on-off times.
These tripper click on-off lever back and forth.
Trippers wear out since they are intentionally made of softer metal than on-off lever
Frontier lighting carries P47 tork 1101 replacement trippers
http://www.frontierlighting.com/product.jsp?part=3495&process=search&show=&
Make sure these trippers match yours before ordering
Dec 09, 2010 | TORK Hardware & Accessories
I have an Intermatic T103 DPST timer installed now (120v). The clock mechanism has failed. I bought Tork 1103 guts to replace it. The wiring is a bit different. Can u map for me which wires go to which...
T-103 has 120V clock motor with 5 terminals A 1 2 3 4
Tork 1101 has 120V clock motor with 4 terminals L 1 X 2
T103 is DPST and can control one-or-two 120Volt loads, or one-or-two 240Volt loads.
Tork 1101 is SPST can control one 120Volt load
Common ground between these timers one 120 Volt load
Changeover for one 120 Volt load:
White wires T103 terminal A go to Tork terminal X
Black wire T103 terminal 1 goes Tork terminals L and 1 (there is brass connector plate that connects L and 1 - if connector is missing, jumper between L and 1)
Black wire on T103 terminal 2 goes Tork terminal 2
If Load requirement is greater than T1101, Grainger sells T103 clock motor for $16
http://www.grainger.com/Grainger/INTERMATIC-Time-Clock-Motor-1PNK1?Pid=search
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
How to wire T103
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T103
T1101 wiring manual
http://waterheatertimer.org/pdf/110111021103WIRING.pdf
Dec 02, 2010 | Intermatic T103 Indoor 120-Volt 40-amp...
My Tork 1103 timer is used at my office building to set the lights outside for security. My maintence person sets them, then all of a sudden they are wacky and come on at the wrong time. I would like to...
http://waterheatertimer.org/pdf/1103INSTALLOP.pdf
This is probably very similar to your timer.
The Tork 1100 series is electro-mechanical timer.
Lift and rotate dial to set current time.
Line up current time with the word Time located to lower right of dial.
The trippers are black and silver.
I think the black is OFF and silver is ON
Clock motor rotates dial as time passes.
Trippers contact a lever.
Off tripper pushes lever one way.
On tripper pushes lever other way.
The manual override clicks back and forth as trippers move lever.
To check function of timer, click manual override
Common problems:
1) Clock motor is not rotating dial
2) Trippers get stuck on lever and can't move lever because timer is dirty or worn out, or clock motor is bad.
3) Trippers are worn down and won't trip the lever.
Replacement of these timers is simple
Check out the functions and problems and then answer this post and I will help more if needed
Oct 21, 2010 | TORK Hardware & Accessories
I have a TORK 1103.. I have read and re read all wiring diagrams..my problem is.. it now turns on.. but doesnt click off.. unless i manually do it myself.. Im pretty sure i have all the wires connected to...
Tork 1103 controls 2 loads
Your wiring is OK ... if the dial rotates and the tripper turns ON the load, then your wiring is correct
It sounds like you forgot to put the OFF trippers on dial?? Or the OFF trippers are worn out.
Dark trippers = OFF
Light trippers ON
Look at the trippers up close ... as they arrive at the manual override, they make contact with a mechanical lever ... the motor then pushes the dial forward and the trippers flip the manual override lever on-and-off.
Is the manual override broken? I doubt it.
Are the OFF trippers worn down?
Oct 06, 2010 | TORK Variable Cycling Timer 8601
Timer keeps time, but sticks at tripper points
1) Clock motor needs replacement:
Link below shows timer and wiring manuals.
2) 120Volt Clock motor sells for $43 at Frontier lighting
http://www.frontierlighting.com/product.jsp?part=10431&process=search&show=&ID=,Photo.Cells...Time.Controls,Replacement.Motors
3) New Tork 1103 sells for $55. Just swap out insides without changing box.
4) Intermatic crossover for Tork 1103 shows Intermatic T103 timer.
Amazon sells T103 for $50
http://www.amazon.com/Intermatic-T103-120-Volt-Mechanical-Switch/dp/B000LDIDBY
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Oct 01, 2009 | TORK Digital Interval Timer Ssa100r-24
I don't know how to set the timer to come on a 7 pm, off at 11 pm. It is a tork 1103 electromechanical timer. Directions lost years ago and new homeowners (myself) do not know how to set the timer. Anne
See T1100 Tork timer on following link:
To set this timer, rotate clock dial clockwise until current time lines up with the word 'TIME' located at 5 o'clock position.
Place black and gold P47 trippers at times you want timer to turn on-and-off.
As time passes, the dial rotates. ON tripper flips a lever that turns Load ON, and then later, the OFF tripper flips same lever and turns Load OFF.
Jun 06, 2009 | TORK Digital Interval Timer Ssa100r-24
TORK Digital Interval Timer Ssa100r-24 Logo
1,005 people viewed this question
Top TORK Hardware & Accessories Experts
Craig Butler
Craig Butler
Andrew Taylor
Andrew Taylor
pawnpower
Are you a TORK Hardware and Accessory Expert? Answer questions, earn points and help others
