SOURCE: kid lost password how do you reboot without disk diver?
This is a suggestion but may work. Try to get into the bios and edit the hdd password. I believe you either press DEL key when you power on the laptop or it might be F2, not quite sure. You will have to navigate in the bios to reach the set hard drive password section. Set to blank password and see if it allows you to boot.
Thanks,
Lolita
SOURCE: promlems with my note book
um the only thing i would do is get an ide/sata/miniide to usb adapter and backup all your data to another computer cuz that sounds like a bios setting if u want and u dont have the password disconect the battery and charger and remove the cmos battery that might reset the drive sequrity if it is a bios setting
SOURCE: how can i fix my acer notebook?i cant open bcos
You need to log into the bios and edit the hdd password...
You can press DEL or F2 key when you power ON the laptop... It will take you to the bios setup...
You can navigate in the bios to reach the hard drive password section and you can set the password as blank...
Once you are done press F10 to save the changes and exit out of it...
If it doesnt works, then you can give a try by restoring the BIOS to its factory defaults(using the restore defaults option in bios) which should turn OFF the Bios HDD security feature...
