Question about Archos 104 MP3 Player
Stopped working completly.
My cousin got one of these for Christmas a bit back and not to long ago the ON light obviously switched on, but he is not able to use any of the buttons, the screen wont turn on and it just dosnt seem to work.
  • Anonymous Dec 09, 2007
    it stop
The archos 104 will turn on but i cant use any others buttons to work . nothing happens thank you ve
Posted on Oct 07, 2008
RESET IT
Posted on Jun 01, 2008
SOURCE:
Are Muslims in Sweden demanding no Christmas decorations?
as the islamic faith does not recognize christians then any such festivity is an abomination to the islamic faith
this is the cry of muslims around the world in that they are offended by christian beliefs but strangely they use the christian justice and freedom systems to enforce their outrage.
Oct 29, 2016 | Computers & Internet
What else can i do to solve compression pressure in the sump on a Hyundai H100 2012 2.6D bakkie? oil was blowing from the dipstick now pouring from the crank rear main seal.
First thing ,,,Is to remove dipstick and run engine [now how much back pressure have you got] if none ,ok .what is the oil pressure when cold,and when hot , should be very little differance, what ring gap did you give the rings when they were fitted. and was the rear main seal a good fit or loose fit ,,,and as for fitting new oil rings AGAIN and that stopped the pressure in the sump from blowing out the dip stick hole well THE compression rings are the ones which should have been checked for the correct gap and at -003thou per inch per bore,as the oil rings are only oil scrapers, and compression rings are for Compression is what you have a lot of in the sump.
Let me know how you get on,
Dec 17, 2014 | Hyundai Cars & Trucks
Hi, there! I have a WESTPOINT no Frost NF 120 and couple of days ago the fridge just stop working. The freezer is ok still working as usual, but the lower part is completly worm. The compressor is working,...
It's the Timer ..a device found on the left of the compressor at the back ..a few wires goes insinde. it has a watch gear mechanism..and a miniscule ant can stop it ..
May 14, 2011 | Refrigerators
My Clapper Plus works fine, except that when it is off, some current still leaks through. I have Christmas tree lights plugged into it. When the Clapper Plus is off, the lights are dim, but are still on.
You obviously have a faulty Clapper. They are supposed to work just like a switch...ON or OFF. If you are getting dim lights, it is bad. Take it back where you got it or call the company.
Thanks for using Fixya.
Wayne
Dec 11, 2010 | As Seen On TV Clapper Plus
I have a Hotpoint HE63X extractor hood and the bulb blew yesterday when I pressed the button to switch it on. This has also stopped the extractor from working. All other appliances are operational and...
I've got the bloody thing in bits as I write - I had the same problem as you - and it's the switch itself that has blown! From al the carbon in the swithc unit I would say we were luck the thing did not catch fire!
I'm looking for spare parts now to see if I can get a new switch or a complete unit of switches. The problem will be, it is one new switch, or a new board it all requires soldering.
Just to confimr, there is not a seperate fuse for the lights - perhaps there should be.
Nov 01, 2010 | Microwave Ovens
My infinity ps210 stops putting out any bass. It was working fine a few days ago but it just stops working without any obvious reason. I bought it fourteen months ago from amazon and I've hardly used it....
Hey. I have two PS210's One popped and stopped working 9 months in to it. Under warranty the technician said that Infinity produced these speakers wit ha known heat related problem. Some part burns up. He replaces them all the time. You can expect about a year's service as my seconf one just popped and died. It costs about $153 to fix it here in phoenix. Will never buy Infinity again from what I know
Sep 04, 2010 | Infinity PS210 Subwoofer
Is there any reason why a single letter key would stop working on a computer purchased new for Christmas and used for less than a week? There is nothing beneath the key, it's been taken off and put back on...
maybe the ribbon cable that connects the keyboard to the system board is not fully inserted. I have had this problem in the past and its only solveed by completely dismantling the laptop and even then its not 100% certain thats what thet problem is
If you used it for less than a week its obviously still under warranty , just backup all the important data and get it exchanged
Jan 04, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Heat won't switch back to cool 2003 turbo bettle
If you can get in there ,the little flap probably just fell down,like mine and my cousins. I cut a short piece of half-inch pipe to prop it back in place two years ago. He glued his three years ago . Both still work .I think I took the glove box out first then the panels on the sides of the front of the console to access.
Dec 23, 2008 | 2003 Volkswagen New Beetle Convertible
Archos 104 MP3 Player Logo
535 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
Harrie
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
