Question about Philips Philishave Cool Skin HQ6760/HQ 6761
Fault hi My shaver when switched on shows the shaver head symbol in red. Also the droplet symbol has lit orange. Any suggestions as to what I do to resolve the problem.
  • Anonymous Dec 13, 2007
    not showing full charge when re charging red light only
    Genius:
  • 1,153 Answers
Open to check blades spin easly.
Posted on Sep 10, 2007
SOURCE:
2007 vw jetta automatic door locks lighting
I'D HAVE THE COMPUTER CHECKED OUT BY A QUALIFIED AUTOMOTIVE TECHNICIAN
Jun 23, 2013 | Cars & Trucks
A red light is on at the lower-right corner, with a shape of the heads. does it mean it is time to relace the heads? how does the machine know?
It's menas that you change new replacement heads. That philips arcitec 1060 electric shaver replacement heads is Norelco RQ10 shaving heads.
Jul 30, 2011 | Philips arcitec 1060 Electric Shaver
The red light showing the shaving head remains on and the shaver discharged the shaver is one year old
Philips suggests changing the heads every 12 months. The indicator is instructing you that it is time to change them. You will find replacements for model 1060x at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-rq10-arcitec-replacement-heads-p-353.html
Dec 01, 2010 | Philips Arcitec 1060X
Where do I find the meaning of various lights on the dashboard?
hi, all lights the first and important battery light this shows RED when the alternator NOT carging:
the oil light shows ORANGE LOW on oil:
the engine managment light shows when engine sensors detect faults shaped like an engine ORANGE light
head main beam BLUE when ON MAIN BEAM
indicator FLASHING GREEN light
hazard warning RED light
brake fluid low light RED looks like this ( )
brake handbrake ON RED light looks like this ( )
side light GREEN looks like a star
most of the important lights are RED or ORONGE gerry
Sep 10, 2010 | 2007 Toyota Sienna
After using the shave a digital red symbol of the head shows up at the bottom of the shaver. What does this mean? Thanks.
Digital red symbol of the head shows up. It's menas that you should change new replacement heads, that Norelco Arcitec electric shaver replacement heads is Norelco RQ10 shaving heads.
May 21, 2010 | Norelco Arcitec Electric Shaver -...
Red light at bottom flashes even when razor ids fully charged. What can causrethis?
When the battery is almost empty (when there are only 5 or fewer shaving minutes left), the battery symbol lights up red.
Make sure that the battery does not have a memory effect. What I suggest is taking the shaving head unit off and running the shaver till empty, then recharging. Check if the red light is still flashing.
There's also a head indicator at the bottom of some shavers.
To remind you to replace the shaving unit, the shaving unit symbol flashes (all types) and you hear a beep when you switch off the shaver (RQ1090 only). This happens at the end of 7 successive shaves to remind you to replace the shaving unit.
Without knowing what model you have it's difficult to diagnose further.
May 23, 2010 | Norelco Arcitec Electric Shaver -...
What is the red blinking light showing the head mean?
Hello. That is a reminder that it is time to change the head, to maintain optimum shaving. It will blink the next 7 times you turn on the shaver. Here is the manual if you want to read more about it. http://download.p4c.philips.com/files/1/1050x_22/1050x_22_dfu_aen.pdf
ps kindly rate my answer as very helpful. thank you. Joe
Mar 29, 2010 | Norelco Arcitec Electric Shaver -...
Red L.E.D light won't stop flashing
Shaving head check indication After two years of use the red shaving unit symbol î will flash for 30 seconds during 7 shaves to indicate that you should check the condition of the shaving heads. This indication is based on an average shaving time of 3 minutes per shave. When the shaving head symbol flashes, all other symbols and lights are out. When the shaver is switched off, the shaving unit symbol disappears. When the red shaving unit symbol starts flashing, you should check the shaving heads for possible damage. If the shaving heads are damaged in any way, they must be replaced in order to obtain optimal shaving results
Nov 20, 2007 | Health & Beauty
Philips cool skin shaver fault
The shaver head symbol means the motor isn't starting, which all the support info assumes is because the heads are too gunked up with hair and congealed moisturizer etc, so clean it. In my case it was because the motor had seized - I completely dismantled the razor and turned the cog attached to the motor spindle by hand while turning the razor on, which was enough to free it up and kickstart it - you'll need some torx screwdriver bits - remove the battery cover (it may be a bit sticky since it is wedged against a rubber seal that it may have stuck to, but it does just lift off, there's nothing to snap), remove the black plastic retainer underneath that which hides a couple of screws holding the head assembly (you may need to prise the battery up to get at them) - undo them and you should be able to pull the head assembly off and push the motor up from underneath to free the plate holding the three cogs driving the head - beneath that is a big cog attached directly to the spindle, spin that by hand while starting the razor and it should hopefully spring back into life since you'll have freed the seized spindle.
Sep 10, 2007 | Philips Philishave Cool Skin HQ6760/HQ...
Philips Philishave Cool Skin HQ6760/HQ 6761 Logo
573 people viewed this question
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
xxxxxx xxx
Robert McClure
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
