Question about Sony Cyber-shot DSC-N1 Digital Camera
Got MY CAMERA WET
My camera fall into the bathtub,while trying to take my baby photos.I allowed dry but since then when I take pics in a well lit enviroment,It come out all whitish and with lines on the diplay what can I do to rememdy this ?
  • autographer Sep 10, 2007
    How do I talk out the lenses
This is probably because water got on back of lense and the particles are blown up in size. You may have to take apart and clean lense on the inside. It could be dryed sudds.
Posted on Sep 10, 2007
SOURCE:
The LCD touch screen is not lit. Sometimes camera does not turn on. It got wet in a heavy thunderstorm.
It's probably fried by the water. Your only hope is to set it aside for a couple weeks, and let it thoroughly dry out, then try it again. But probably you already tried to turn this one on while it was still wet, and that fried the circuitry. If so, you're outta luck. Sorry! Next time something electronic gets wet, do that but don't EVER try to turn it on while it's still wet.Gotta give it LOTS of time to dry out inside in order to have any hope of a recovery.
Nov 09, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
After camera got wet can't see pics
Water and electronics are always a bad combination. Your view screen is probably no longer useable.
Jun 16, 2009 | Canon PowerShot SX10 IS Digital Camera
Memory stick only allows 11 photos
Try and reformatt the stick using the camera.
Apr 06, 2009 | Sony Cyber-Shot DSC-P32 Digital Camera
Camera & sd card got wet
There's no chance of you messing up the memory card further. Once the memory card dried up, you should be able to use an external card reader to look at the pics on it. This type of memory is less susceptible to corruption and therefore it can take a lot more punishment.
Mar 17, 2009 | SanDisk 2GB Secure Digital Memory Card
Shows white lines after the pic is taken with kodak v1003
Check your lens. Clean with soft cloth they sell at most camera stores. If this does not resolve. You should bring it back to the store if its only 3 months they will give you hassle but its worth if for working camera
Jan 16, 2009 | Kodak EasyShare V1003 Digital Camera
Unable to view pics
Copy the existing photos on to your PC, switch off the camera. Remove the SD card and format the SD-card using a SD-card reader, this will clear all the card contents. Now try using it in your Camera again. Ideally, you should be able to save photos on this SD card. Other way would be to insert another SD card into your camera and click photos and check whether those photos are being saved into the SD card(this can be done using display option in your digicam.)
Dec 17, 2008 | HP Photosmart E327 Digital Camera
My Camera in water
Usually when cameras fall in water, the circults gets wet and mostly causes a short-circuit which causes the components to fail. If the camera fell in water without the battery you could try
1. Drying it completly before putting on the battery to test it.
2. Immerse the camera in alchol complety. It basically substitutes water (removes moisture) and vaporises quickly. Dry it completly and test it with battery.
If the battery was in when you dropped it your chances are less. You could dry it completly and show it to a technician ASAP. Make sure no moisture reaches it.
Hope its still under warranty.
Oct 22, 2008 | Pentax *ist DS Digital Camera
Deleted photos on xd card
May be so
Have tried PCInspector from www.Convar.com ?
If you have not, try that one
Aug 09, 2008 | Fuji FinePix S7000 Digital Camera
Photos appear to have lines running horizontally through them.
did the camera get wet? I have the same problem and mine got wet.
Jun 18, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Sony Cyber-shot DSC-N1 Digital Camera Logo
74 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
