Question about GE 24 in. Profile PDW7800 Built-in Dishwasher
Water won't drain it just sits in still water from the kitchen
  • 81 Answers
Your drain is clogged! Start with a good drain cleaner (I like "Works", but Liquid Plumber is fine). if it doesn't clear with te drain cleaner (for goodness sakes, please follow the directions on the bottle to the letter) then call the plumber.
Posted on Apr 24, 2009
Water sits in bottom
If water does not drain at all then the drain pump could be blocked.
If only a little water is remaining but cycle is complete, then this is normal.
However, do check the kitchen drain is clear and you do not have a garbage disposer (insinkerator) in sink which is full. Normally empty it before you start the dishwasher.
Do you get any alarms (lights flashing etc)
Jan 03, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
Code F2
If you hear the drain pump running but water stays in the bottom then you have to check if the kitchen sink drain is clear. More particularly if you have a garbage disposal unit in kitchen sink then make sure it is working and has been cleared before running the dishwasher. In case you do not hear any drain pump or it is rough and not draining then it may need to be replaced. The drain pump is available from this site.
Jul 22, 2012 | Asko D1776 Stainless Steel Built-in...
Dishwasher won't drain.Leaves several inches of water in bottom of unit after cycle is complete
Check for blockages in the base of the dishwasher under filter etc.
Also make sure the kitchen drain is clear and if you have garbage disposer run it prior to running the dishwasher.
Also need to confirm if the dishwasher pump is actually operating during the drain cycle. If the pump is faulty then it will not drain. Provide full model number of dishwasher if you need further assessment of the problem. Good luck.
Aug 30, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Won't drain. Water sits in bottom during all cycles. Water back up to sink.
Run your garbage disposal and sink water for a few minutes in case there is anything clogging the drain. Also look under your sink in case the drain hose is kinked. That hose might also be clogged but is a difficult job - maybe pro help is needed if you are not comfortable doing it yourself. Last option is that the pump is bad and must be replaced
Jul 08, 2011 | Dishwashers
Blocked kitchen drain
If you have a wet dry vac, remove all the water in the sink. Then take 1 full cup of baking soda and 2 cups of white vinegar. Pour the baking soda into the drain, then pour the vinegar on top. Let it sit for about 20 minutes, then flush with scolding hot water. If that doesnt work then do it again and let it sit for longer. Baking soda and vinegar make a acid that will eat through most anything that goes down drains.
May 31, 2010 | Plumbing
Too much sink water causes flooding from dishwasher.
If you let it sit with vinegar and it worked after for a while that tells me it may be plugged up with grease. Might be worth while trying to clean it out with Drain O a drain cleaner. Make sure its washed clean after. Grease and dirt builds up after a while in all machines. If vinegar works might be worth cleaning more often.
Mar 14, 2017 | Maytag PDB4600 Built-in Dishwasher
No water coming from hot valve on faucets
Have you thought about possible calcium buildup in your hot water tank/pipes? I am helping a friend in Palm Springs CA (California not Canada) and we are going to pour a really huge pile of vinegar into the hot water tank (let it sit for a day) then open up the hot water taps to the kitchen (where we don't have hot water flowing very well), then going to let everything sit for another day. Remove the aerator from the kitchen faucet after letting the vinegar/water solution sit in the pipes for a day, and turn on the kitchen hot water tap. Once all the **** is drained out, you must of course drain out the vinegar/water solution from your hot water tank or you will smell like French Fries (in Canada we put vinegar on French Fries) when you shower for a few days.
If you don't understand what the basic chemistry of dissolving calcium via this method is all about, then please call a professional plumber. Hope this helps, and remember that Google is your friend (sometimes), but be careful...
Apr 27, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Dishwasher water keeps backing up into kitchen sink then taking a long time to drain from sink
Yes, your sink drain needs cleaning -- it's clogged. Pour some bleach into the sink drains and let it sit for a couple of hours. Flush out with boiling hot water.
If this improves the situation but not completely solving the drain problem, try it again.
If that doesn't solve the problem, remove the P-traps on the sink drains under the sink and clean them out.
If that doesn't work, let me know -- we'll try something else.
May 05, 2009 | Dishwashers
GE dishwaher leaks with standing water in bottom
Check to make sure regular dish soap did not end up getting inside the dishwasher. This will create a lot of suds that will overflow onto the kitchen floor. Standing water from not draining can mean the drain hose is clogged somewhere or the check valve has something caught in it. If you remove the front kick plate, you will be able to check those.
http://tclaundryrepair.com/
Feb 26, 2009 | GE 24 in. Profile PDW7800 Built-in...
Water leaking onto floor from refrigerator/freezer
The defrost drain is stopped up. Without taking anything apart, the easiest way to clear the drain is to blow compressed air through the drain tube which is at the back of the Fridge. You'll see it..... it drains water into the drip pan. Hope this helps !
Oct 09, 2017 | Refrigerators
GE 24 in. Profile PDW7800 Built-in Dishwasher Logo
130 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
