Question about McCulloch Garden
Drive cord has jammed
Chainsaw working ok then suddenly stopped.followed procedure for restart but drive cord will not release
  • 666 Answers
Loosen the four bolts that hold the starter housing on. If it does not release then you will have to disassemble starter and find and repair problem.
Posted on Apr 12, 2009
I had a paper jam. I pulled the paper out. Now it will not print saying that the carriage is jammed, it says to open and unjam carriage but it is all the way to the right and I can not unjam. How do I get...
Try reset your printer by following this procedure to reset it,
1. Without turning the unit off, unplug the power cord from the back of the product.
2. Press and hold # and 6 keys.
3. While holding those keys plug the power cord back in.
4. Wait until the screen goes blank before you release those keys.
5. Follow on printer screen instructions.
Or
. Turn the printer power off.
2. Press and hold GO.
3. Turn the printer power back on and continue to hold GO until the Attention light turns on.
4. Release GO.
5. The device lights will begin cycling from front to rear. The cold-reset process will run until completion and the device will go to the ready state. This should fix the problem..
Sep 16, 2011 | HP PSC 750 All-In-One InkJet Printer
Paper jam
Or
4. Release GO.
Sep 16, 2011 | HP Office Equipment & Supplies
Ryobi plt2543. was using it and was working fine then suddenly it stopped tried to started it again and couldnt because it had jammed and could not pull the cord out. what would be wrong?
first i would take sparkplug out and see if you can pull rope. if you can, it must have leaked fuel into the cyl. if you still cant pull rope, you need to take starter off and see if it is broke. if not broke motor must be locked up. i hope this helps.
May 04, 2011 | Ryobi Garden
What do i do when it says hard disc system is corrupted on my ps3
Ok try to follow these steps in order to restore your hard disks structure again.
Step 1. Turn the PS3 off into standby mode (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it, then beep again 5 seconds later and then beep once more and turn off. When the console turns off, release the power button.
Step 3. Press and hold the power button again. It will beep when you first press it, then beep 5 seconds later, then there will be 2 quick beeps together. When you hear these 2 quick beeps release the power button.
Step 4. The PS3 will start up asking you to connect a PS3 connector via USB and press the PS button. Do this and then go onto the next step.
Step 5. A menu will then load. Choose option 3 "Restore File System". The PS3 will restart and may report that your hard drive is corrupt, ignore this and click on "OK" to continue. Let the PS3 do its thing and hopefully when it restarts all will be well again.
If this procedure does not work, follow steps 1-4 again but on step 5 choose option 4. If this does not work try again but with option 5.
If none of these procedures work then I am afraid it looks like your hard drive may have become faulty. This will mean you will have to purchase a new one.
I hope this helps and thank you for using FixYa
Aug 20, 2010 | Sony Playstation 3 (PS3) Console
Chain saw chain stopped moving
Was it running and shut down and was froze or when you went to restart it was frozen? Two things I have seen cause this other than a seized engine. One - chain bound up. Remove side cover and inspect chain mechanism. Two- the pull cord is bound up. Remove the pull cord cover and inspect.
Jun 15, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Chainsaw jammed
Remove the starter assembly from the side of the engine
and inspect the cord path--look for kinks in the cord or maybe it got wound on the spool incorrectly. It should be possible to pull it through while off of the engine. Good luck!
Apr 09, 2010 | Garden
My chainsaw quite suddenly. i restarted it but
1. The kickback brake, if equipped, was triggered to stop the chain.
2. The chain is jammed with saw dust/debris (it doesn't take much)
3. the bar sprocket is damaged.
4. The chain guide teeth are damaged and not sliding through the bar guide groove smoothly
5. The chain is adjusted too tightly.
6. You are out of bar oil and friction has stopped it/damaged the bar and/or chain
7. The motor sprocket clutch is damaged.
That should cover all of the basics to look over.
Nov 04, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Blowing out gas at the start. Drained and filled with fresh gas mixture. Cleaned spark plug and srayed carb cleaner in hole. Pull choke pull cord , blowing gas out of carb. Stuck float? Buy carb kit from...
No floats in chainsaw carbs. Severly flooded most common start problem with chainsaws. Read and follow the start procedure in your manual. Don't use choke on flooded engine (may set fast idle, set then turn off)!
Extreme Flooding by Dolfoff
Please follow this link, http://www.fixya.com/support/t3226410-no_spark_new_plug_but_continues_flood cursor down to “Best Solution”, while there click the “Was this helpful? [Yes]” button
Start Procedure
Cold:
  1. Ignition on/off to on
  2. Set compression release – optional step even if saw is equipped with a compression release
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls)
  4. Set compression release – optional step even if saw is equipped with a compression release
  5. Push (open) choke pull starter until it starts. (usually first pull)
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) - Don’t pull with choke closed.
  4. Push (open) choke, pull starter until it starts. (usually first pull)
Hope this helps
Lou
Oct 31, 2009 | McCulloch Garden
Printer jams. gray foam released in paper path.
1: Remove Cartridge
2: Unplug the AC Power Cord
3: Hold down the RESUME button
4: Release RESUME after plugging in the AC Power cord.
5: Press the RESUME once within 5 seconds and release the RESUME .
6: Press and HOLD RESUME for two seconds or more and release it.
7: Press and HOLD RESUME for two seconds or more and release it.
8: Unplug AC Power Cord to set data.
Try this I found it doing a search on your machine, that foam was called a blotter, and it should work without it, good luck
Dec 19, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
Chainsaw electric motor jammed
Remove the chain, then see if it will turn over by hand. Does it have a chain-brake??? Frankster016
Oct 18, 2008 | Electric Chainsaw Sharpener
Garden Logo
101 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
