Question about Radio Communications
Screen lock has been activated somehow on 1 of 2 transceivers
Model: TP-326PMR Transceiver ( E0681"! in O" Serial No. 21015810 Owner's Manual does not mention any "screen lock". Most functions are locked and a key symbol is displayed between vox and ctcss. What do I need to do to deactivate lock?
    Problem Solver:
  • 19 Answers
Hi 'fairfa' your problem can be solved by finding the manufactures contact address (ie Fax, email etc) and present them with the problem which they should be able to answer, sorry I am not to sure on the correct answer on this one. let me know the answer to this one please I am interested.
regards John.
Posted on Apr 17, 2009
Where Is the anti theft module
Passive Anti-Theft System (PATS) Transceiver module is around the key lock cylinder behind or under the plastic cover on the upper steering column'
Passive Anti-Theft System (PATS) Transceiver Removal
  1. s4h~tr~en~file=ani_caut.gif~gen~ref.gif CAUTION: Electronic modules are sensitive to electrical charges. If exposed to these charges, damage may result.
    Disconnect the battery ground cable, Refer to Section 414-01
  1. Remove the ignition switch lock cylinder.
    1. Insert the ignition key into the ignition switch lock cylinder and turn to the RUN position.
    1. Push the ignition switch lock cylinder release tab with a punch while pulling out the ignition switch lock cylinder.
    2. If equipped, remove the tilt wheel handle.
    3. Remove the upper and lower steering column shrouds.
      1. Remove the screws.
      1. Remove the upper and lower steering column shroud.
      2. Remove the lower instrument panel steering column cover.
        1. Remove the lower instrument panel steering column cover.
        2. Remove the instrument panel steering column opening cover reinforcement.
          1. Remove the bolts.
          1. Remove the instrument panel steering column opening cover reinforcement.
          2. Remove the anti-theft transceiver module.
            1. Remove the screw from the bottom of the transceiver module.
            1. NOTE: Only apply pressure or leverage below the key cylinder lower rib.
              Disconnect the electrical connector and remove the module.
Dec 24, 2014 | 2006 Ford Taurus
Why does my kenwood TH-K2 fm transceiver will not transmit
Users Manual (download if you don't have it)
TX I
NHIBIT
You can inhibit the transmission to prevent unauthorized
individuals from transmitting, or to eliminate accidental
transmissions while carrying the transceiver.
1 Press [MENU].
2 Turn the Tuning control to select Menu No. 25 (TXI).
3 Press [MENU].
4 Turn the Tuning control to select "ON".
5 Press [MENU] to store the setting or [PTT] to cancel.
"TX INH" appears and an error beep sounds if the
transceiver tries to transmit while TX Inhibit is ON
May 11, 2014 | Kenwood PB-34M, ,TH-22AT,TH-42AT,TH-79A,...
Audiovox FM transceiver model GMRS1072CH free manual
https://www.cbo-it.de/de/produkte/blueoptics/transceiver.html
Please this site you will find the information about transceiver product.
The BlueOptics and BlueLAN brands include Optical Transceivers, Active Optical Cable and Direct Attach Twinaxial Cable Solutions, MPO / MTP Solutions, SAS Solutions, Stacking Cables, Twisted Pair and Fiber Optic Patch Cables, PLC Splitter, Multiplexers, Demultiplexers, As well as other data center and cloud solutions.
Apr 07, 2012 | Radio Communications
Arc mouse transceiver is damaged can I buy just the transceiver
I cannot find any where on internet, to buy just the transceiver. I recommend contacting microsoft support they should sell replacement products or know where you can get a replacement transceiver.
Mar 17, 2011 | Microsoft ARC Mouse
Where can i find a microsoft 2.4ghz transceiver
https://www.cbo-it.de/de/produkte/blueoptics/transceiver/qsfp.html
The BlueOptics and BlueLAN brands include the following products: Optical Transceivers, Active Optical Cable and Direct Attach Twinax Cable Solutions, MPO / MTP Solutions, SAS Solutions, Stacking Cables, Twisted Pair and Fiber Optic Patch Cords, PLC Splitters, Multiplexers, Demultiplexers, as well as other data center and cloud solutions.
Apr 12, 2010 | Microsoft Multimedia Keyboard/Wireless...
Does not transmit
Model #? Name?
black box? make sure the tx rx are reverced on both ends.
Jun 21, 2007 | Black Box (IC109A-R3) Transceiver
Radio Communications Logo
79 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
