Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
When starting up my printer for the setup we got message error code 3802 and it says call service
I called the kodak help line
Posted on Apr 13, 2009
Why will my printer not print. shows error 3802. just prints blank page. do have ink.
Error: "Printhead Failure" (105-3802) - Kodak
support.en.kodak.com/.../error%3A-printhead-failure-(105-3802)
KodakAug 25, 2010 - How do I resolve the error message "Printhead Failure" (error code ...If you are not prompted to calibrate the printhead, turn off the printer, wait ...
Error: "Printhead is missing, not installed correctly, or has ...
support.en.kodak.com/.../error%3A-printhead-is-missing,-not-inst...
KodakAug 25, 2010 - How do I resolve the error message "Printhead is missing, not installed correctly, or has come loose" (error code 105-3513) on my ESP or HERO All-in-OnePrinter? ... If the printhead and ink cartridges are not installed in the printer, install them: ... If the error continues, restart the printer and try to print.
Jan 18, 2016 | Kodak ESP5 AllInOne InkJet Printer
Error code 3802
  1. Upgrade your printer firmware to the latest version
  2. If your printer firmware is already up-to-date:
  3. If the error continues:
  4. If the error continues,
for more help visit https://cbrtechsolutions.net or
CBR Tech Solutions
Jan 19, 2014 | Kodak Office Equipment & Supplies
Printer showing error code 3802, says to go to kodak. com/go/aiosupport
I am new user of Kodak printer and i used to get error code 3802.
The main cause of the error 3802 is improper installation of printer driver. To get rid of this error you always ensure that properly install the printer driver.
I was looking for the solution and then found this using google. I found this link helpful.
http://printersupportsnumber.weebly.com/blog/kodak-printer-error-code-3802-its-cause-and-solution
Any other suggestions are welcome.
Thanks in advance.
Jan 20, 2012 | Office Equipment & Supplies
Printer will not clear the Error 3802 , what do I do?
Hello and Welcome to FixYa!
Error 3802 generally occurs in the Kodak Inkjet Printers.
To solve this error Turn the printer off and then turn on, this problem is solved by doing this mostly.If the problem still there then remove the ink cartridges and the print head and after few minutes put it back in the printer .If you are still facing this then do it again almost five times & if still your problem is not solved and you still get error code 3802 then probably your KODAK EASY SHARE 5500 All-In-One Ink Jet Printer is in need of servicing by a service professional.
I hope this solution helps you
Don't hesitate to let me know if you want any further assistance.
Thank you and Keep using FixYa!
Aug 17, 2011 | Kodak EASYSHARE 5500 All-In-One InkJet...
Getting problem code 3802
Hello thanks for using Fixya
Error 3802 Mean Print head Failure
Turn the printer Off and On, This problem is solved by this mostly.If the problem still there then remove the ink cartridges and the print head and after few minutes put it back in the printer .If the problem still there then do it again almost five times & if still problem not solver and you get error code 3802
then it is probably that your KODAK Esp 3250 Allinone Multifunction Printer is in need of servicing by a service professional.
So go to the KODAK Service Center
Your problem will be solved.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial in your words for appreciation "if it is helpful"
THANKS
Keep Using Fixya
Feb 28, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
Printer wont copy error code 3802
Hi,error 3802 Means Printhead Failure
All You need to do is turn the printer Off and On
And if the problem still there
Remove the ink cartridges and the printhead
Do it again for (5x)
And if the problem still there,
i will suggest you contact their customer care for further assistance.
Apr 16, 2010 | Office Equipment & Supplies
My kodak E 9 showed the message "detected new printhead, put plain paper in the try and press start." I did that and then this came "Error Code 3802."I have disconncected power, etc. and the thing starts...
through my experience this is a printhead error message. Make sure that the printhead is seated correctly in the printer. If the error persists all you need is a new printhead. Contact Kodak under 1-800-421-6699 or go through the Interactive Step-by-Step Solutions tool under www.kodak.com/go/itg. Choose All-in-one printer - Print quality - Problem is not listed and follow the steps, then you come on a site where you can order a new printhead for free.
Mar 07, 2010 | Kodak EASYSHARE 5500 All-In-One InkJet...
What is error code 3802?
"Printhead failure" - #3802 Solution (from Kodak website):
  1. Open the printer access door.
  2. Disconnect the power adapter from the printer.
  3. Wait 30 seconds to allow the printer to reset.
  4. Connect the power adapter to the printer. Turn the printer on if necessary.
    • After the printer completes powering up, the message "Printer access door open" will appear.
  5. Close the printer access door.
Feb 16, 2010 | Kodak ESP 5 Printer
"Printhead Failure" (error code 3802)
To resolve this error:
  3. Remove and install the printhead two times.
  4. Wait 30 seconds to allow the printer to reset.
  5. Connect the power adapter to the printer. Turn the printer on if necessary.
  6. Close the printer access door.
If error condition continues, contact Kodak for printhead replacement.
Best of Luck
Nov 17, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Error 3802
printer can not talk to printhead... power off. wait. power on
Sep 16, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
77 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
