Question about Bunn 10 Cup Home Coffee Brewer
Water leaks out from underneath coffee maker
About 1/2 cup of the water I pour into the coffee maker leaks out of the bottom of the coffee maker...any suggestions?
  • 2 more comments
  • justmine4me Apr 18, 2009
    water leaks out from bottom, it isn't being overfilled as I have used less amounts of water, however it does seem to differ in amounts regardless of how much water is put in
  • swwebb May 17, 2009
    I have 10 oz.s of water leaks out from the bottom of my BUNN.
  • eaglebeck212 May 22, 2009
    Water sometimes leaks from a small hole under the right side of top just behind the grounds basket.
  • Anonymous Mar 25, 2014
    leaks at bottom . i drained pot ,added 2 cups of water ,which poured out w/in seconds . can this pot be fixed ?
    Scholar:
  • 192 Answers
Well they don;t give these away for sure. Lets see if we can help you out. ? are you over filling it.This happened to me because I was reading the fill line wrong. {got new glasses} . If not may be you could try makeing less. But if only 1/2 cup comes out and no more, that wouldent indacate a leak in the tank, if there was it would all leak. Try backing off on the coffie and water, and see if it still leaks. if it does get back to me. DFD
Posted on Apr 13, 2009
Why does the water I put in the maker run out the bottom
Sounds like it has a leak in the tank or the hose. Unplug the coffee maker and turn it over. See if you can remove the bottom cover. Make sure the coffee maker has not been on and is cool to the touch!
Underneath will be a tube and heating element. Make sure the tube is connected to the water reservoir and that there are no holes or cracks in anything. It could be that someone dropped it and cracked the plastic somewhere.
Oct 02, 2014 | Bella 13600 Coffee Maker, 12 Cup
Leaking underneath
You are not alone having the water leak in your SS-700. For better understanding what caused that leak please read the review on Cuisinart SS-700:
http://www.cuisinartfoodprocessordeals.com/cuisinart-ss-700/
Nov 22, 2011 | Cuisinart SS-700 5-Cup Coffee Maker
I put in 12 cups of water but only get 4 cups of coffee. what is wrong
Are you sure 8 cups of water is a lot to LOOSE it has to be somewhere i am used to loosing 1/2 cup in the grounds if i make 8 or more cups i have 2 of these coffe makers one in each house the only times i ever loose more is when the filter isnt properly seated and it flows around it and makes a major mess get your coffee maker into a good light and pour water into the filter(coffee maker off) with the carafe out fill it about 1/2 way no water should leak thru then slip the carafe into place the filter should empty if the water flowed when the carafe was out your filter basket and holder arent seated or the valve on the bottom of the holder is clogged and/or held open
Dec 26, 2010 | Cuisinart DCC-1200 Coffee Maker
What could be causing our Bunn to leak water from underneath at all times? when I put water in to brew, it's about 1 to 2 cups short of the fill line, for example I pour in 8 cups and get about 6 to 7 cups...
A leak is usually caused by a bad seal/gasket. If you will call customer service at 800-352-2866 with the model and date code we will be happy to assist you with this.
Sep 25, 2010 | Bunn NHB Coffee Maker
Water leaking out the bottom of the coffee maker
If it leaks DURING brewing, you may have to decalcify it (aka, run through a cycle of 4 cups vinegar, fill to the top with water, 2-3 times and see if it helps).
If it leaks before you even start brewing a pot of coffee, something is broken on the inside of the coffee maker, and I would recommend contacting Waring--they may be able to get you a replacement coffee maker (and if you're under warranty, usually a replacement would be free!).
Their phone number (according to their website, www.waringproducts.com ) is 1-800-4WARING (1-800-492-7464)
Good luck! :)
Aug 27, 2009 | Waring Pro WC1000 Coffee Maker
Bunn coffee maker leaking from underneath the bottom
Please get the model and the date code from the bottom of the machine and contact customer serivce. Depending on the date code, there might be a seal kit available or the machine can be replaced at no cost if 3 years old or less. If it is over 3 years old and the seal kit isn't available, the machine will be replaced at a reduced price.
Apr 29, 2009 | Bunn 10 Cup Home Coffee Brewer
Water not being forced through the cup
I've seen a few coffeemakers that have a gravity valve on the inlet side of the brew chamber. If this valve has become stuck open, then the hot water may be perking back into the reservoir instead of out to the coffee.
Feb 20, 2008 | Keurig B50 Coffee Maker
Bunn 10 Cup Home Coffee Brewer Logo
788 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
