Question about Toshiba Satellite M35X-S111 Notebook
Lap top computer power problem
My wife got a digital camera memory card stuck in the lap top. thought we may be able to get it out by loosening the screws on the bottoma and getting to it that way. we saw we couldnt get to it so we screwed the screws back in and tried to turn the computer back on but nothing happened. we get not power at all the battery is full and have also tried using the power cord. the lights come on showing the power cord is working but the computer will not turn on it isnt getting power? any advice would be appreciated.
Screws, if overtightened or replaced with the incorrect size (i.e., too long a screw), can somtimes cause a board to short. Try taking the screws out completely and then see what happens. It's also possible your laptop may have a bad power supply as a result of the case having been taken apart or put together incompletely. If the first step doesn't work have it diagnosed by a competent repair person . Also, you may consider trying one of eBay's "laptop power" repair services postings. Some offer to replace your power supply fitting (rear plug) for about $50 plus shipping.
Posted on Sep 10, 2007
SOURCE:
My memory card works perfectly in my lap top and in my cellphone, but when i try to use on my camera, it says that "this card cannot be read". What can/should I do?
When you use a memory card, it formats itself, using a single memory card on all three things probably isn't the best idea. What you could do, is get the small sd card for your phone, and get the adapter so you can view the pictures from your phone on the computer. Then get a totally new memory card for your camera they are super cheap. I would suggest getting a 2gb or higher. I hope I helped.
Jun 23, 2011 | Nikon Coolpix S3000 Digital Camera
How do you transfer pix on a computer/lap top? Casio Exilim ex-s5 have the plug from the box but no book to -- how to use it with the computer. Plug where in the camera? Camera plugged into the lap top?...
You can download the manual from the manufacturer's web site at
http://support.casio.com/pdf/001/EXS500_e.pdf
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Feb 06, 2011 | Casio Exilim EX-S500 Digital Camera
Cant upload photos from kodak c143 to lap top have downloaded easy share but when i conect camera to lap top nothing happens
Consider NOT connecting your camera to your computer.
Dec 29, 2010 | Kodak EasyShare C143 Digital Camera
Well i am going on a trip tomorrow and i put my memory card into the lap top and put all pix on the lap top and then put it back in to the Nikon and i gray screen came up and said that "momory card is writ...
Some memory cards have a small plastic tab on the side of it that can be set to write protect the card. Check your card to make sure the tab didn't get moved accidentally.
Jul 01, 2010 | Nikon Coolpix 4500 Digital Camera
Can not transfer pics from the camera ( coolprix L16) to laptop.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive.
Jun 05, 2010 | Nikon COOLPIX L18 Digital Camera
My lap top unable to recognized my finepiz digital camera when i hook up with the usb port
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
May 14, 2010 | Fuji FinePix Z10fd Digital Camera
Lens is stuck open while the camera is turned off. Camera will not turn on now and can't get photos off memory card. Any thoughts.
push in on zoom when turning camera on. this is a firmware problem and camera needs to be updated.
Aug 27, 2009 | Samsung L700 Digital Camera
Problem with accesing memory card
After you download pictures you must insert card in camera and format the card. See instructions in book.
Oct 28, 2008 | Sony Alpha DSLR-A100 Digital Camera
Memory Card for digital Camera
After inserting the card, go to my computer and see if it shows the memory card inserted. If so, click it and then when it opens, click copy to location and you choose the location, easiest, my documents and then my pictures.
Dec 26, 2007 | Cameras
Toshiba lap top
possible that keyboard electrical connector or other connector was inadvertently disconnected. must open case and investigate further.
Sep 04, 2007 | Toshiba A105-S4054 Notebook
Toshiba Satellite M35X-S111 Notebook Logo
52 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
