Question about KitchenAid KEBC107 Electric Single Oven
F2e1 error message
Help! need to reconnect keypad keytail. where is it located?
    Problem Solver:
  • 3 Answers
It is the only ribon cable coming off of the control panel to the control board. This error could also indicate that the control panel is bad.
Posted on May 14, 2009
I get a F2E1 code on my whirlpool stove oven display. What does it mean?
Roy,
Check this link and scroll down to your problem code. Says that the keypad cable is unplugged.
Whirlpool Fault Codes AppliancePartsPros com
Apr 21, 2015 | Whirlpool Ovens
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
My oven gives error code f2e1, how do i solve it
F2 E1 means that the keypad cable is unplugged.
Gain access to the control panel and keypad. Check keypad connector for firm connections. Keypad connects to the control board. Press CANCEL. If error code returns after 60 seconds, the keypad needs to be replaced. If your control board and keypad are incorporated as one unit, then the control board needs to be replaced.
Feb 14, 2011 | KitchenAid Ovens
E1 f2 showing on whirlpool oven... it use to say e2 f6 so I changed the circuit board. Someone here mentioned putting a piece of paper in with the keytail (connector ribbon). I did that but still...
ok, the paper worked for me for about two weeks, then the problem happened again. the next fix i tried was to unplug the keytail (the ribbon connector) from the slot on the control panel. there is a clip in each side of the black plastic receptacle (the place where the keytail plugs in on the electronics control board). pres them inward to separate the top portion of the receptacle, which I think helps to clamp the keytail into the bottom portion. the top and bottom fit tightly together, so you might need to use a small screwdriver at the joint to pry them apart, however, I did not fine it necessary to remove that clamp in order to remove or replace the keytail on mine.
once the keytail is free, clean it well with a mild cleanser (I used a slightly soapy dish sponge) and dry it with a clean paper towel. FYI, one side of the keytail has the exposed wires which make contact with pins in the receptacle on the control board. the exposed side is on the inside surface of the curled keytail ribbon, the outside surface is translucent plastic insulation (you can feel that the outside is smoother than the inside because the inside has the contact wires exposed).
next, use sharp scissors to carefully trim a small uniform strip (roughly 1/16 of an inch or less) off the end of the keytail. then plug it in again (remembering to use the top portion of the receptacle to secure it in if you had removed it). doing this provides a fresh spot on the exposed wires to make contact with the pins in the receptacle. my theory is that over time the wires wear out at the points where they make contact with the pins. trimming the edge allows you to insert the keytail deeper into the receptacle and therefore, the pins will contact the wires in the keytail at a new, unworn spot. it's been over a week now and so far, it seems to have fixed the problem on my stove. if I get the error message again in the future, my next step will be to try paper trick again (at least as a temporary solution), but I doubt it will be necessary any time soon.
by the way, I sent the touchpad part back to sears after I figured out I didn't need it and they refunded $15 less than I'd paid. $13 and change was for shipping, so the other dollar plus must have been a miscalculation or a restocking charge or something, but I didn't bother following up to find out. I also had to pay about $3 to ship it back to them via USPS because I didn't hear the UPS guy when he dropped it off on the doorstep, so I wasn't able to simply refuse the delivery.
Nov 18, 2010 | Whirlpool GBD307PD Electric Double Oven
Err F2E1 stuck/shorted key
The control panel is either faulty and needs to be replaced. One can be purchased at repairclinic website or partselect.
Or you can dismantle it, and clean everything with rubbing alcohol and a cotton swab
Apr 27, 2010 | Ovens
My oven is showing E1 F2, when I'm cooking something and the door locks and will not open till it cools down
E1-F2
Keypad cable unplugged
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Oct 08, 2009 | Whirlpool RBS305PDS Electric Single Oven
My whirlpool wall oven displays E1 F2
F2-E1 - Touch Pad (Keypad) Cable Unplugged -
Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
It appears your timer/clock has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^^^^^^^^
Sep 12, 2009 | Whirlpool RBS305PDS Electric Single Oven
Oven preoblem kitchenaid ykers807sp "err f2e1 stuck/shorted key " showing
If you've determined the keypad on your Kitchenaid oven, range, or wall microwave is faulty and youre searching for an obsolete part, http://www.FixYourBoard.com has replacements by Ledgestone Technologies. These units are backed with a 2 year warranty. Save your $ and save your oven from the landfill. We have you covered! Call 512-355-1108 for more information and to order. We're happy to help you solve your problem!
Jul 17, 2009 | KitchenAid Architect Series KEBC107KSS...
E1 F5 error message when try to activate the self clean
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Dec 07, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Kebc207 oven error code E1 F2
This is information from the Tech Sheet.
Fault Code F2 - Error Code E1: Code Explanation: Keypad keytail not connected. Recommended Repair Procedure: 1. Check keypad connector for firm connection. 2. Press CANCEL. If error code returns after 60 seconds, replace keypad. 3. Replace control.
Jul 15, 2008 | KitchenAid KEBC207 Electric Double Oven
KitchenAid KEBC107 Electric Single Oven Logo
407 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
