Question about Olympus FE-310 Digital Camera
Hi, I have buy Olympus fe-310 in oct 2008, from the beging its shock me battery problem, I have purchased too many battery and its takes maximum 15-20 pic and message battery empty. where is the problem tough to find. no reply from service center. if any one having any solution for this, please reply me on pushkar.rawat@gmail.com.
  • Anonymous Apr 21, 2009
    Hi I have the same problem and not only me every user of FE -310. Olympus people need to resolve this. But unfortunately this model has been discontinued, so don't expect anything from olympus.
    As for the solution try using Ni-Mh Batteries. Available from only Sanyo and Panasonic brands.
    This was the solution given to me by the service center people.
    Problem Solver:
  • 6 Answers
After wasting many hours searching for someone that had the recommended Panasonic 1.7v batteries in stock (versus the standard 1.5v battery found everywhere) and trying a couple of suggestions to improve the battery / terminal contact, I decided on trying the solution provided by blackduk on this thread (http://www.fixya.com/support/t1595282-olympus_fe_310_battery_problems), with very slight modification.
First I just placed the capacitor across the terminals and closed the battery door. It increased my shots per battery from about 10 to about 50. (Not great, but probably because the connection wasn't even as good as a 'cold solder'.) But it was enough of an improvement, and as the battery door never closed properly with this 'fix', I decided to go with soldering. Afterwards, I went through two battery sets in testing. Both times I got in excess of 300 images, with flash on all photos and zooming in and out while the flash charged!
Instructions:
Accessing the terminals was easy. Just remember, it is the thin front panel of the camera that comes off (after removing 6 screws). Facing the lens, the 4 long screws need to be returned to the right side and bottom of the camera. The 2 short screws need to be returned to the left of the camera. Measure and clip the wires on the capacitor. Have a hot iron. (Initially I didn't have it hot enough and singed the plastic trying to get a good join. Hotter for a shorter period makes a better solder and won't melt the plastic.) Tin the terminals. Grip your capacitor wire with needle nose pliers, hemostats or some other heat-sink when soldering. Do it. (Mine is far from a pretty piece of work, but functionally it is perfect - and you can't see my goofs once the face plate is back on.)
Parts:
I ordered the capacitors from Talon Electronics. I got Axial, instead of Surface Mount, with the same specifications blackduk provided. A quantity of five, Item Number TNC0019, 2.2uF 10V Molded Axial Tantalum Capacitors, cost me $7.23. That included shipping (they were .25¢ each). I ordered through www.talonix.com.
Good Luck,
Andrew
Illustration:
Hi, I have buy Olympus fe-310 in oct 2008, from - 12_31_2011_12_25_16_am.jpg
Posted on Dec 31, 2011
  • 3 Answers
You need to bend the metal tabs on the battery door so they make good contact with your batteries. Good Luck.
http://www.youtube.com/watch?v=97yJX4dYmSg
This video shows how to fix your camera.
Posted on Jan 07, 2011
SOURCE:
I need an owners manual for an olympus FE-310
You can download a PDF version of the manual and/or order the printed one from the manufacturer's web site at http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=1351
May 13, 2010 | Olympus FE-310 Digital Camera
Fe-310, only used a few times, kept protected, one
Short answer - yes.
Manufacturers have become very good at making products that are reliable for exactly 1 year.
Usually it's small components that have a deffinate shelf life.
I would first check that you are using the correct battery for it. Even if it looks like it takes standard AA's - they often will only work for original spec rechargable blocks.
If this does not solve it - write a letter to Olympus saying how dissapointed you are with their product.
They may offer you a good deal on a repair hopefully.
Unfortunately Sony and HP are even worse - HP and lexmark printers now stop working after a period of time - telling you to buy more ink - even though you still have plenty.
Oct 01, 2009 | Olympus FE-310 Digital Camera
Hi. i have a new olympus fe-340 8,0 digital camera and my computer isn't taking the download cd. is there a way to download it off the internet,so that i can use my camera today?
yeah there should be software on the olympus site.
In fact I have the 310 and dont use any software.
Go to my computer > onto your cam > and copy your files off manually.
Jan 08, 2009 | Olympus FE-340 Digital Camera
Olympus FE-310 will not turn on
Bring your camera to your vendor so that you can avail warranty.
melnavz
Jan 06, 2009 | Olympus FE-310 Digital Camera
BLACK SCREEN WHEN TURNED ON
This is either a bad CCD or the lens aperture not opening. You could send it to mackcam.com or to olympus for an estimate. Might be looking at a $125 repair
Dec 31, 2008 | Olympus FE-310 Digital Camera
Today I bought a camera Olympus FE-310. i'd like to know how i can set the shutter speed and the optimum aperture. and I'd like to know if cn take black and white pictures with this camera. Thanks guys,...
Hi - You can download the manual by clicking the link underlined in blue below:
FE-310
Other info here.
This is a fully automatic camera and you cannot directly set the speed or aperture. Try using the "scene" modes.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 16, 2008 | Olympus Cameras
Olympus FE-310 Digital Camera Logo
183 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
