Question about Nintendo Super NES Console
Snes video fault
Plug my snes into the tv using a standard rf cable the games load up but only display the characters properly and all other backgrounds and textures are scrambled up. What could be at fault?
  • 42 Answers
It may have something to do with the age of the console.
Posted on Sep 11, 2007
  • Anonymous Sep 12, 2007
    It could be to do with a fault on the circuit board which would require dissasembling the product. It could also be the rf cable.
SOURCE:
Snes red horizontal lines
When hooking a super Nintendo or an NES system or a sega genesis system to a digital tv you need av cables for it to work then instead of using an rf switch
Sep 30, 2012 | Nintendo Super NES Console
My Super Nintendo is working, but won't show up on my relatively new television, can some one help me please? is there a lead or something I need to buy? thanks
Do you have your TV set to the "TV" input? There may be inputs such as "Video 1", "Video 2", "HDMI 1", "HDMI 2", "Component 1", "Component 2", etc., but the input you will want to have selected is "TV" (this is usually done by hitting a button labelled "Input" or "Video" on the TV remote). Once you are on that input, go to channel 3 (type in "03" on the remote), then turn on the SNES. It should now display.
If this doesn't work, double check the plug you have connected to on the back of the TV, it should read something like "Cable In" (not "Cable Out").
If you have checked all of that and everything is setup correctly, it is possible that you have a bad RF adapter (the grey box that connects the SNES to the TV). If this is the case you can buy one online for around $5 - $10; just google "RF adapter SNES".
Apr 08, 2011 | Nintendo Super NES Console
I am trying to get my old snes to work I plug everything up and when i turn it on the tv goes to a black screen i am using the original rf adapter that came with it model no:nes-003 nintendo rf switch. I...
Try the game with another TV to see if you will have same problem. If you do not have that problem that means the TV you are using is faulty.
Thanks for contacting Fixya.
Jul 06, 2010 | Video Game Consoles & Games
Super Nintendo picture flashes in & out on my flat screen
Check your cables and connection, they could be worn or cracked, try using on another tv or use a different device in the same plugins to verify if what is wrong
Dec 04, 2009 | Nintendo Super NES Console
Hi i just bought a super nes system it came with RF switch power unit which i have connected to the appropriate connections, i have an LG TV with an golden eye and don't seem to be able to tune the...
Make sure everything's connected in the correct sockets. Turn the SNES on, change to one of the Analogue channels (one of the channels which you control with the TV remote) and start scanning for a signal. The RF cable has to be connected to the analogue port (where a TV aerial would plug in to get analogue channels) and the SNES needs to be switched on.
The alternative is to get a SCART-compatible cable that works with a Gamecube or an N64 and use it with the SNES, as Nintendo had the foresight to add an EXT port which'll let you play the SNES on an AV channel.
Jul 09, 2009 | Nintendo Super NES Console
SNES works but no color.
Sounds like your AV Multi-out port circuitry is shot. Yest it with an RF adapter, and if it works perfect with an RF adapter, that is the source of your troubles. I'm afraid that the cheapest solution is to buy a SNES motherboard (about $20.00), which is a lot cheaper than a repair shop soldering in new components to fix it. It's not something you can do on your own.. Google SNES Motherboards type 1 or 2
Apr 08, 2009 | Nintendo Super NES Console
I'm missing a cable for my SNES but I don't know which one
its an rf cable you can buy third party ones if you search on the internet. also if you happen to have a video cable for gamecube or n64 you can plug that into the slot on the back of the snes and it will work. Im not sure what that slot is called but its the only one that cable will fit into.
Feb 22, 2009 | Nintendo Super NES Console
Can't work SNES
Is the TV tuned to the same channel as the SNES ?
Both have to be set to channel 3 or both to channel 4.
Jan 18, 2009 | Nintendo Super NES Console
SNES doesn't display?
The CIC chip, also known as lock out chip, may have gone bad. Here is a quote from a site I found.
"Every SNES control deck has a regional lockout chip (known as a CIC), as does every original SNES game cartridge. Before a game is loaded, the console will attempt to communicate with the CIC chip on the game cartridge. If the CIC chip doesn't respond or does not correspond with the consoles CIC, the console won't load the game. In most cases, a black screen is displayed."
http://www.chronicgames.net/articles/snes-museum.aspx
Yea basically I am having the same prob with my system and I am trying to fix it. Ill let ya know if i figure it out
Jun 14, 2008 | Nintendo Super NES Console
Super Nintendo
I'll just tell you how to set it up with an RF cable.
1: Plug the power adapter in an outlet and plug the other side in the designated spot where it fits. Simple.
2: On the back of the SNES, there should be a switch that says channel 3 or 4. Whatever one the switch is at, it will be the channel to play it at.
3: From where it says "NES CONTROL DECK" on the RF switch, plug that into the SNES.
4: From where it says "TV" on the RF switch, screw it into the supplied ports on the TV. Note that newer TV's don't have this port.
You probably don't need to bother with the antenna port.
Enjoy the SNES! :)
Nov 10, 2007 | Nintendo Super NES Console
Nintendo Super NES Console Logo
269 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
