Question about IBM Lenovo ThinkPad T61 Notebook
Spacebar on IBM Lenovo ThinkPad X61 came off.
The spacebar key cap on my IBM Lenovo ThinkPad X61 came off and I cannot determine how to put it back on.
I took mine off to clean under it and had a similar problem. After a bit of struggling I figured it out. I will try to explain it as best as I can, but forgive the non-technical language:
There are two gray plastic pieces on the space bar that must be that must be latched to the two white plastic pieces on the computer. The gray pieces pop off the space bar easily. Take them and put them on the white pieces on the computer so that the white arms lay across (and snap into) the top and bottom of the gray piece. The middle of the gray piece will sit in between the two arms that are not "holding" the gray piece. Then take the space bar and put the metal part into the hole on one side (outside of the plastic pieces) and then push it over so you can put the opposite metal part into the other side. Then push the space bar straight down and it will snap into place.
Posted on May 30, 2009
I can not find PrtSc key
The PrtSc key should be in the first row of keys between Insert and Delete.
Jan 09, 2014 | Lenovo ThinkPad Edge E530 325978U 15.6"...
Key on IMB Lenovo ThinkPad X61 came off.
If the small plastic hinges are still attached to the keyboard, then place the key over these hinges, align it with the others keys and press down on the key until it click onto these hinges.
Aug 23, 2012 | IBM Lenovo ThinkPad X61 Notebook
Fn spacebar
Angie,
Try using Shift+Fn+Spacebar, to see if that reverses the situation.
Cheers!
-a.
Apr 25, 2012 | IBM Lenovo ThinkPad T400 7417 Notebook
I broke my spacebar off my laptop gateway computer! How do i fix this?
Of all the keys on the keyboard, replacing the SPACEBAR is probably the most difficult. The SPACEBAR is kept even by a metal wire that is inserted into slots on each leg of the plastic bar key. However, you have to get the wire into the slots without depressing the wire. If you push the wire down, you compress the wire and installation becomes impossible. As a general rule, do not remove the SPACEBAR unless absolutely necessary. If you remove the SPACEBAR, remove several surrounding key caps also. This will let you get some tools under the SPACEBAR wire later on. Once the SPACEBAR is reinserted, you can easily replace any of the other key caps.
Jan 19, 2011 | Gateway 2520915 Keyboard
Power on password problam plz help me
For IBM/Lenovo Password
there is solution for all IBM/Lenovo laptop
check this site... http://ja.axxs.net/x61_s_t.htm u need to buy this device Key maker pro...
OR
there is one more way to break password for many laptop ..u need to make com port or printer port and there is software for it ...
check this site http://www.lancos.com/prog.html
Thanks
Sep 10, 2010 | IBM ThinkPad X61 Tablet PC
How do I put my spacebar back on?
Firstly ensure you have all the parts - there may be one or two sets of small plastic hinged brackets. These go on first to the laptop - then the key should snap in.
Be careful to check the brackets are not broken or worn first!
May 13, 2010 | IBM Lenovo ThinkPad T61 Notebook
Ibm t43 spacebar popped off, how can i fix it ?
if the small components were not broken or lost and the metal spring and key are fine, take it into an IBM/Lenovo Service center and they can fix it or replace the whole keyboard for about $50-100.
Feb 15, 2010 | IBM ThinkPad T43 Notebook
Problemwith spacebar
If you take all those tiny screws out of the bottom of the keyboard you'll see a circuitboard with three copper "design" spots(usually 3) under the spacebar..........the ones NOT in the center of the spacebar are dirty. You could use some alcohol or acetone to clean the outside "designs".....(warning) Acetone will damage plastic!!!!!!!!
there are a lot of rubber caps that WILL fall out of place when you turn it over) (the actual keys could fall out too) (Be careful when you take off the bottom of the keyboard!!!!) Clean the ones that align with the SPACEBAR!!!! Dont touch or clean anything else that wasn't working....... Gently place the bottom back on and screw down the bottom cover with a cross pattern.....(left>right...top>bottom).....If this dosn't work....the best part is that a new keyboard........is fairly cheap....mtg
Apr 14, 2009 | Computers & Internet
Took spacebar off to clean up a pop spill...metal bar NOT attatch
There might be a metal wire if it is missing, which snaps to the keyboard, you may need a new keyboard.
If you are unsure, you should probably thake it to your local computer repair shop.
Good Luck.
Mar 15, 2009 | IBM ThinkPad T42 Notebook
Open Questions:
See all IBM Lenovo ThinkPad T61 Notebook Questions
IBM Lenovo ThinkPad T61 Notebook Logo
3,439 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
