Question about Rokenbok Rc forklift W Bonus Warehouse by
Rokenbok control pad problem
When we plug rokenbok control pad into tower, it lights up but doesn't allow us to choose our newly purchased forklift. the lights on the forklift continue to blink even after we insert the key...regardless of which number we choose
I have a TCM fg20 forklift that here lately seems like you have to give it more gas to move . It's propane powered. Any idea what to check ? Scott
all forklifts have an isolator valve in the drive system that stops the vehicle movement if the foot is on the brake
that area of control is where I would be looking at because if the valve is not allowed to neutralize properly then it stops movement or only allows partial movement
Dec 04, 2016 | Cars & Trucks
Tip
Different Types of Fork Lift Trucks Forklift trucks are very powerful...
Forklift trucks are very powerful industrial trucks that are used for
both lifting and transporting of materials.These days building
projects all use forklift trucks.
There are many different types of forklift truck. Here are some of the
most well known;
Electric forklifts - these forklifts are powered by lead-acid
batteries and includes scissor lifts, stackers and pallet jacks
Sideloader - this includes both Stand on End Control and Sit Down End Control.
Hand pallet truck - a pallet truck that is usually electrically powered.
Truck mounted forklift - usually a diesel run truck.
A small percentage of the forklift truck market includes high-end
speciality trucks.
In more recent years, Automated forklift trucks have been developed in
order to try and reduce the wages paid and operational costs of
running regular trucks. The popularity of automated forklifts has
grown massively.
on Nov 21, 2013 | Heavy Machinery
How do you repair the steering on model h150c forklift
Two thing could be wrong - one the steer wheel nut could be loose allowing the wheel to turn free or the second is that the steering control rod or shaft is broken.
Sep 05, 2014 | Cars & Trucks
New lasko heater keeps shutting down
fatly over heat switch or tilt switch some r very picky
Dec 10, 2013 | Lasko Heating & Cooling
Mattress pad not heating up
There must be a problem with wiring. You must contact with the manufacturing company or some electrician to go through the control box. Do not try to deal with it by yourself as it may cause damage.
Jack
Jan 26, 2013 | Canon Cannon Quilted Heated Mattress Pad
Forklift will not turnover
the fork lift has several safety devices that will not allow it to start until everything is set
you in the seat , foot on the brake , transmission in neutral and hand brake on
it is designed so that you cannot start it from the side where if it starts it runs away uncontrolled
check for all operational safety switches
Jun 08, 2017 | Cars & Trucks
The Plug is sending power to the air conditioner, but nothing lights up or moves..have opened it and see no damage and the correct volts are being pushed. What could cause this to not work at all even...
One of the control panel circuits may be at fault and doesn't allow the power past that point. If you have a multimeter, check the circuits in the control panel for continuity, until you find the right one.
Hope this helps & thanks for choosing FixYa.
Aug 17, 2011 | Comfort-Aire RAD-81 Air Conditioner
Need the instructions for conveyor belt
Here are the Rokenbok plans/manuals: http://www.rokenbok.com/hard-hat-area/building-plans-plan-books
Feb 16, 2011 | Rokenbok Conveyor Company Start Set
I cant find the manual on the Rokenbok website. it is not listed with all of the Old systems.
We just uploaded this building plan at http://www.rokenbok.com/hard-hat-area/building-plans-plan-books. Make sure to refresh the page if you don't see it.
Rokenbok Toy Compan
Jan 29, 2011 | Rokenbok Rc Fire and Rescue _
I have an old rokenbok sweeper truck that just will no longer work. I've changed the batteries and checked the connection on the radio control, but still nothing.
check and make sure there is no corrosion on both the truck and the remote.If thats not the problem,then you might have something that needs to be replaced inside the truck.
try it in a different area to make sure nothing is interrupting the signal.
Aug 28, 2009 | Rokenbok R/C Power Sweeper
Rokenbok Rc forklift W Bonus Warehouse by Logo
80 people viewed this question
Top Rokenbok Toys Experts
ray gallant
Are you a Rokenbok Toy Expert? Answer questions, earn points and help others
