Question about GE JTP20 Electric Single Oven
F3 message comes on after a minute or 2 on ge oven
Help
  • 6,784 Answers
Open or shorted oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Posted on Jun 25, 2009
F3 and F2 Errror messages on my GE convection oven
F2 & F3 are fault codes relating to the oven temperature sensor
F2 during bake means a temperature of over 630 deg has been reached
F3 means shorted oven temperature sensor
What it means is you will most likely need to have the oven temperature sensor (thermostat) replaced .
Dec 19, 2010 | GE Profile JTP56 Electric Double Oven
F3 mag current
well...seems that you have an early warning of a possible failure of a major component. Is this unit still under warranty, by chance?
Jun 20, 2008 | TurboChef TORNADO Electric Oven
F2 and F3 messages - shuts itself off. Any idea of what it is and how to fix it?
Hi
F2/F3 error message relates to the oven temperature sensor or thermostat faults.
The fix is normally to replace it.
This link may help if you want to do it yourself
www.wonderhowto.com/how-to-replace-cooker-thermostat-oven-250012/
Hope you get it fixed.
Dec 16, 2010 | GE JKP15 Electric Single Oven
What is an F3 message on a GE Profile JKP18 oven ?
Hi jmjburns,
The F3 fault code description is an open or shorted oven temperature sensor. Please check the sensor harness and harness connection between oven sensor and oven control. If the wiring is ok and still encountering the same error, please replace the temperature sensor.
Hope it helps.
Thank you for using FixYa.
Nov 10, 2010 | GE Profile JKP18 Electric Single Oven
How to Fix Code F3 on GE Oven
Hi
Thanks for using FixYa. Error F3 in your range/oven means oven temperature sensor circuit failure. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 03, 2010 | GE Ovens
F2 and F3 error codes in GE electric wall oven
Call GE answer center 1-800-626-2000 ask for tech help, Have you Model # off you data plate ready.
May 09, 2009 | GE JRP15 Electric Single Oven
Microwave
Hi my GE Advantium oven is displaying an error message and beeping. The Error is F3. Could you please help me with this.
Nov 02, 2008 | GE ZSC2001FSS Advantium Electric Single...
Oven turns off F3 flashes
Bob, an F3 error code denotes a failed oven temp sensor. See below.
F3 Open oven temperature sensor circuit Replace oven temperature sensor
The repair is pretty straight forward, but you should have the replacement part in hand before you begin. The part number is WB21X5301 and retails for about $95.00. I just found one online for $72.60!
The sensor is located inside the oven cavity mounted to the top of the rear wall. Remove the 2 screws and slide it out of there. The sensor has a plastic connector connecting it to the main harness behind the oven. Pull this carefully through the hole. If you can't get the plastic connector through, then you'll have to pull the oven and do this from the back... alot more work but still do-able. Simply disconnect the old sensor from the plastic connector and install the new one. Then feed the wires back into the oven and re-mount the new sensor.
If you don't have to pull the oven, the job should take about 20 minutes and all you need is a 1/4" nut-driver or socket.
If you have to pull the oven, re-post and let me know... I'll walk you through it.
There ya go!
Aug 22, 2007 | GE JGRP17 Gas Single Oven
GE Model JTP15 oven shows F3 error code
I have the same problem. I noticed that the oven gets to the selected temp ok. Then when the pilot attempts to RELIGHT, it gets the error F3. Did you get a solution? After other posts, I will see if the temp sensor is around 1100 ohm as suggested by others. Ken
Jun 14, 2007 | GE JTP15 Electric Single Oven
F3 code
It's your oven temperature sensor. It's a thin metal stick that juts into the oven. It is located on the upper right back wall of the oven cavity. Flip your breaker, slide out the oven. You install it from the back, very simple, two screws, i think. I'm a beginner at DIY and had no problem fixing it.
Feb 23, 2007 | GE Profile JK915 Electric Single Oven
GE JTP20 Electric Single Oven Logo
177 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
