Question about Troy-Bilt Pony Garden Tiller
Changing the drive belt
I have a troy built pony rota tiller
I need to know how to change the drive built without a lot of problems
thanks
norma
  • Anonymous May 08, 2009
    I have a troy built super bronco i need to change the belt. How do i do that?
  • 3 Answers
Remove plastic belt cover
remove the guard,belt/pulley
work in the right side first:
remove the rigth-side wheel
remove the screws of the bumper
remove 2 screws on bracket/transmission assembly
pull the bracket
install the new belt
reinstall the right side screws and wheel
do the same in the left side
Ps: remove the belt guide, and reverse return spring
http://www.partstree.com/parts/?lc=troy_bilt&mn=21A-634K766+7HP+FRT+Roto-Tiller+(2005)&dn=0079200009
Posted on May 13, 2009
I WAS JUST GIVEN A TROY BILT 5 HP REAR TINE PONY ROTA TILLER. THE DECAL WITH THE MODEL NUMBER ETC. ON THE TINE CASING IS UNREADABLE. DO YOU HAVE ANY IDEA WHAT MODEL THIS MIGHT BE? I WOULD LIKE TO GET A...
The serial # of the tiller should be stamped directly above the right wheel on the transmission housing. This should give you more info to work from.
May 02, 2011 | Troy-Bilt Pony Garden Tiller
Owners namules
http://manuals.mtdproducts.com/mtd/Public.do
Go to this website and type in Horse for your model number.Just put thenumber 1 in for your serial number and it will bring up several horse tiller manuals. If yours is a 1976 then it should be
a Horse I model. This should be a two speed tiller and have two drive belts.
Frank
Jun 01, 2010 | Troy-Bilt Pony Garden Tiller
Need belt diagram for Troy bilt Pony. The drive belt just broke and I need to 1, buy one and 2, replace.
hi im having trouble on my troy belt riding mower it is a 42 inch im tring to change the belt we have it on but it not right please help me
May 15, 2010 | Troy-Bilt Pony Garden Tiller
My troy built is several years old and recently the tires went flat. I know there is a transmission disconnect but the only manual I got with it was a Briggs and stratton motor guide. I never paid...
There is no actual transmission disconnect on the mower. If you put in neutral the belt would need to slip on the pulley in order for it to be pushed or roll freely. This usually doesn't happen.
Apr 10, 2010 | Troy-Bilt Pony Garden Tiller
What is the easyist way to change belt on older troybilt horse tiller without pulling motor
You dont need to pull the motor ... in fact if you do , that will not help you. We are talking about a genuine Troy, right? Bujilt in Troy not Cleveland.
At most, you will have to remove th reverse disk.
Take off the off the old belt(s) (mine 6 hp Horse is a older two belt drive). You must be in neutral. Pull the belt off the back of the engine pulley and down to give you slace to get it off the transmission pulley then pull it away.
It is very easy to say and a llittle harder to do but not as hard as you think, believe me. I have 2 belts and have replaced them several times.
YOU CAN DO IT>
Oct 08, 2009 | Troy-Bilt Pony Garden Tiller
My troy built keeps eating the forward drive belt?
Had one do that not long ago. The problem was the idler pulley that pushes against the belt when you pull the engage lever on the handle was not lined up with the belt. I just bent the idler bracket to line up the pulley with the belt. Maybe this will help, assuming you have the same model.
Jun 29, 2009 | Troy-Bilt Pony Garden Tiller
Changing Drive belt On Troy Built Tiller
You have to remove the engine (4 bolts, no big problem), then remove the bolt in the center of the pulleys, then remove the pulleys. Slip the belt(s) (2 if you have the Super Bronco model) onto the pulleys, re-attach the pulleys with the bolt, re-mount the engine, and you're home free.
May 20, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
How to lock drive shaft to change reverse disk?
I just changed the belts on my tiller, and had the same problem..The manual says to be on the left side of machine and with a box end wrench on the bolt, "hit with a hammer"..use a brass or lead hammer..
This sometimes works, but you still have to tighten it when you are done!
My tiller has electric start, so the easy way was to remove starter and position a piece of wood against the ring gear.
John
May 09, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Replace belts
It is pretty easy to change the belts. The correct size is the problem. I bought some replacements for mine and found they didn't just quite fit. I finally got them from Troy Bilt so they fit correctly. Remove the two fly nuts to the safety shield over the belts. Next remove the cotter pin that holds the idler pully to the control shaft. This will now allow you to swing the idler out of the way so the belts can be removed. A little twisting and turning and they will come out and go back in without a problem. Reconnect the idler pully and pin and make sure it is adjusted properly for operation then replace the safeth cover. Good Luck, RAC
Apr 02, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Troy-Bilt Pony Garden Tiller Logo
1,013 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
