Question about Franklin BATH UNLIMITED RESIDENTIAL GRAB BAR
Shower grab bar has rusted
I have a Franklin shower grab bar which is white metal.
Some of the finish has chipped away allowing the metal to rust.
The mount brackets are fine. I need a replacement rod approx. 18 inches long.
  • 4 Answers
U could always repair the rod, its cheaper and easier, first of clean the rust off with viniger, white works best, then go buy some enamel paint, a small jar of whatever colour it is make sure its water prof, i suggest u do this in the morning then it will be dry for u to use at night, and there u go, if ur lazy however spend the money and change the bar, gd luck!
Posted on Apr 12, 2009
What can my neighbor lady use to add a back to her shower caddy?
I would recommend cutting a vinyl shower curtain to fit. Otherwise, if you'd prefer a hard back, you can usually find some relatively thick plexiglass that should do the trick nicely. It wont rust, because it isnt metal, isnt likely to mold or mildew up too bad, and it's pretty easy to clean and resists alot of different cleaners pretty well. Hope this helps
May 09, 2016 | Home
Paint inside microwave is chipped and blistered. How do you fix it?
HI,
If you are able to spent money for a new Microwave then go for a new one.
If you are interested to repair and reuse the existing Microwave then keep on thing in mind, if you paint it then also it will not lasts for a long time as the metal underneath is rusted.
Ajin
Jul 14, 2012 | GE Microwave Ovens
Floorboard is rusting in my 94 geo metro
There's not a whole lot you can do about a rusted out floorboard. If it's just rusting a little bit, you can probably get away with cleaning off the rust with steel wool or a wire brush and treating it with some naval jelly, then painting it with a good rust converting paint or underbody coating.
If it's already weakening the metal, the only solution is to weld a new piece of sheet metal in place.
Dec 31, 2010 | 1994 Geo Metro
Bathtub chips
To fix small porcelain bathtub chips, you can use acrylic nail polish that matches the bathtub color. Just get some fine sand paper to remove any rust, then clean with alcohol, let it dry, and then touch up with the nail polish. Use a hair dryer on high heat to help dry faster, but wait several hours after to use.
Jan 14, 2010 | American Standard Cambridge 5' Americast...
How do I keep the Escutcheon on my Moen shower faucet from rusting yet keep it clean? How do I get the stains from the rust off my shower stall wall?
http://www.jelmar.com/CLRbasic.htm
This is the best stuff for that rust,it's strong stuff,so wear gloves while using.It's available just about everywhere,shopping centers,hardware stores,even your local Wall-Mart.
Jan 02, 2010 | Moen & One Handle Tub & Shower Faucet
On the bottom of my microwave, the coating started "chipping" off and now there is a fairly large area that appears to be rusting and makes where the turntable wheels rest look really dirty. Is there...
This is often caused by spills and condensation.
The metal will have to be sanded smooth and clean.
You can use a wire brush and naval jelly to get rid of the rust.
If any rust remains, you can use Rust Reformer paint to stop the rust process, then sand it smooth when it's dry.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart or Lowe's.
Nov 23, 2009 | Emerson Microwave Ovens
Motorbike sitting in shed unused for a year. Chrome has little rust spots all over. How may I get the rust spots off without damaging the chrome? I live within about one kilometre of the ocean and at times...
you'll need some steel wool, use fine if the rust is not bad. No need to scratch the metal too hard for nothing.
Second you'll need some metal polish to lubricate, and polish while you rub with the steel wool. Liquid polish works better..
you'll need a clean rag to buff out everything after you've removed the rust.
Rub the metal-polish-loaded steel wool on the part until you see the brown rust pits vanish. Don't do a circular motion, go in a back-and-forth motion instead to match the length of the part. Circular scratches will show even if they are very small.
Once you've made all the rusty spots go away, take your polishing rag, a clean cotton t-shirt can do the job, and buff the piece until you are happy with the result.
You can always finish with a regular application of metal polish without the steel wool after you're done.
Nov 08, 2009 | 1996 kawasaki VN 1500 Vulcan Classic
1994 acura integra--Paint job.
Surface rust can be worse than it appears so then in that case, the bad spots will have to be cut out and new metal welded in its place. (Look at the rust from underside of the panel--moisture gets there and rusts from the inside out) Paint chips can be sanded down. As far as a quote, here in southeast Missouri ...it would be $1600-$1700 for a full body paint job.
Mar 28, 2009 | 1994 Acura Integra
Rust on stainless handle charbroil
stainless steel ??? rust??? technically s/s should never rust. however particles on the finish will rust and stain the metal. heres a solution that i use and works real well. look closely at the handle you should be able to detect a grain in the metal ( just like wood s/s has a grain pattern) with a scotchbrite pad sprayed with wd-40, wipe handle WITH the grain, slowly at first applying even long strokes,, it will come clean, as well as leave a protective finish so as not to happen again
Mar 13, 2008 | Kitchen Ranges
Franklin BATH UNLIMITED RESIDENTIAL GRAB BAR Logo
701 people viewed this question
Top Franklin Home Experts
Donni Steen
Tom Chichester
Are you a Franklin Home Expert? Answer questions, earn points and help others
