Question about Epson Stylus RX425 Multifunction All-In-One InkJet Printer
Epson RX425 Printer Scanner Copier
I have a blockage causing the paper to jam on the far left hand corner ( as viewed from the front )whilst trying to feed through. I suspect it is a bit of paper or something small like a staple, but it is out of sight which means I need to take the printer apart to find and remove it, but I cannot see how this is done. So far, I have : 1) Removed the Scanner lid, 2) Removed the back paper support, 3) Removed the screws at the bottom of the three holes ( bottom left, bottom right, top right ) on the the main scanner part of the machine, and which appear to hold it to the body of the printer, 4) Disconnected the right hinge of the scanner part. However, I cannot see how to release the left hinge. It looks like there is a similar screw to the right hand hinge, but I can see no way to get to it other than forcing a screw driver through the tiny gap in the plastic. I assume this scanner part really does have to come off, as I can see no other way of removing the plastic main upper body, which I think must have to come off to give access to the printer mechanism. However this seems to be held in place by a couple of tiny plastic pegs only a millimetre or two in diameter. Are these sealed in place or is it just matter of brute force? Next question is the control panel on the left hand side. Does this need to come off? I have found the plastic clips on the left and released them, but there is clearly something else holding the panel in place. Has anyone else had this problem? How do I get the scanner lid off, and how do I remove the plastic upper body of the printer? Any help would be very much appreciated.
  • Ray H Sep 12, 2007
    Just to say thanks to JACKBOY for his help.
    I was not aware of the fixyourownprinter.com site, and one of the articles there included the following :
    The hidden screws are on the button panel, unpeel the sticky label that covers the LEDs to reveal 3 screws.
    Remove the small panel top left to reveal the fixing screw for the left lid hinge (behind the white cable strip).
    Unplug all wires to scanner, remove upper screw on right lid hinge and remove scanner lid.
    This will allow access to the remaining 5 fixing screws.
    I have not had a chance to follow this through yet (time very precious at the moment ) but this does look like the solution to my problem.
    Thanks again,
    Ray H
    Genius:
  • 2,985 Answers
Try your luck at www.fixyourownprinter.com Are you sure it is a paper jam. this may be an indicators of another type of problem.
Posted on Sep 10, 2007
SOURCE:
While printing, the paper got jammed. I removed the paper completely, with out tearing the paper. The printer still states that an error has occured and to turn off the printer, check for jammed paper,...
my epson t13 doesnt feed any paper. when i was printing and run out of paper i put some paper on it but in dismay all of them feed all and it stopped. i tried to pull them out of the printer little by little. when i tried to continue my printing job it never feed any more. any help for this problem pls....
Apr 19, 2011 | Epson Stylus CX8400 Series
My Epson Stylus Photo RX425 printer will print ok then it flashes the red error light that there is a paper jam but there isn't one. I go through the procedure of pressing colour button and opening and...
Its simple Just move printer head to the right whereever it is .. Forcefully move to the right most of ur printer ..it will not damage ur printer but will solve ur problem...
Aug 17, 2010 | Epson Stylus RX425 Multifunction...
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Stylus CX9400 Photo Printer: paper jammed inside printer...
May 18, 2010 | Epson Stylus CX9400 Photo Printer
My Epson CX8400 is flashing and error message that says turn off printer, turn on and see your documentation.... Far as I can see there is no paper jam and the only thing outta the ordinary is the inkset...
Whne turn on, printer move to left and right for checking carriage track, and measure it. If "something" block carriage moving, printer error occured. Check left side of carriage track. Did you use CISS?
Apr 11, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Epson dx8400 printer paper
Look on the back of the unit, and you might see a panel that can be removed for just this sort of situation. try to bend or lift it out gently, and you may be able to see the paper from there. Also, make sure the cartridges are taken out before you try to dislodge the paper, they might be blocking the jammed paper from your view. Needle nose pliers work great for getting out paper if you can't reach it with your fingers.
Sep 22, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson printer problem
See if you can turn the printer upside down and shake it. sometimes the new ink is bad. go to epson.com and look around, you can call them. I would get the hand book for your printer and read it.
Mar 26, 2008 | Epson Stylus RX425 Multifunction...
Epson Stylus RX425 Multifunction All-In-One InkJet Printer Logo
213 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
