Question about Yamaha DSP-AX1 10-Channel Amplifier
Unbalanced LEDs> amplification problem, or mere graphic drop out?
My newly acquired JVC AX-1 Amplifier does not show as much power level indication on the left LED. cannot really hear a difference when panning between channels, in stereo nor in mono modes. but i wonder if certain frequencies are not being amped as much on the left channel, or if somewhere in the circuit something is not as it should be. is it possible that the left LED is merely "lazy" and not as sensitive as the right LED or is what arrives definitely what is being shown on the level indicator? in which case there is not as much power arriving to the left channel?
  • 4 more comments
  • seehandler Apr 12, 2009
    i plugged in an external tape deck (actually a 4 trk) and measured the outgoing signal with it and it checked out as balanced. (i switched the left and right input signals from the cd player into the amp to check as well). after trying to sum the L and R channels by switching to MONO on the amp and not noticing any difference, i realized that the input from cd to tape player (through REC out) might not even be going through the amp. in any case i did not feel as confident with the result as i did before trying the mono signal. but at this point i am also not as confident in the things i thought i might not be hearing in the left channel. good to hear that it is possible the metering circuit is a possibility and that it does not necessarily mean the actual power level on the left channel is lacking.
  • seehandler Apr 13, 2009
    i downloaded the repair manual (which shows the circuits) from this website, but am not fit enough to be sure of what i am looking at. checking the meter reading externally does not do any good if when monitoring through the tape out (which is the way i did it) the amp is bypassed, which is my suspicion since the MONO function on the amp had no effect on the readings on the external UV meters, which it should. this is similiar to the fact that tone adjustments on the amp do not usually alter recordings being made onto tape (on consumer products). realizing this, i thought that getting a reading externally through the line out is perhaps not the best way. cannot think of another way at the moment, save measuring individual components on the circuit board which is beyond me. also, my interest is to find out if the meters or the amp itself are broken. i do not want to use it constantly if it is, which would be the equavalent of walking around with a patch punched with holes over one eye. the balance could obviously help adjust the left channel, but would alter the stereo image produced on some reordings.
    no sorry, i downloaded the manual from here:http://diplofix.com/thread-0/114470
    sorry!
    better yet herehttp://diplofix.com/forum-JVC/A-X1
    the 2nd link above is for the service information, which is all i have. it shows diagrams of the different circuits. thanks for your input up to now..............
    ok still need to get to this, but
    A)R903 and R904 are listed as having 62 K, if i read from the list correctly. they are there and look the same, more i cannot say. four identical stripes on each of em,
    B)C904 does not look leaky, replacing it will be a task for me
    C)cannot find the TA7318 on the board, diagram, or in the list of parts. where is it located, approx?
    do not have an oscilloscope. might know someone that does, will take some time.
    D) the first thing i did notice when i opened the case was that around the C621 C622 area on the board there is a darker area of brown, which looks to be caused from heat. thought something on the other side of the board may have overheated, but checked and there is nothing down there! it looks fine from the other side as well. can the board discolor from regular wear after years of use? the amp does get warm after all. nothing in that area looks to be damaged and a quick check of some parts with a volt meter showed those parts checked to be ok.
    thanks again!
  • 4,234 Answers
This could be a defect in the metering circuit. In order to verify this, you should measure the output externally. Get that external measurement and post the results here. We'll continue from there.
Dan
Posted on Apr 12, 2009
  • 2 more comments
  • ABRsvcs Apr 12, 2009
    Unfortunately the metering circuits are different for different manufacturers and models. Some take the reading from the pre-amp section others from the output section. In any case, these are run through resistors to drop the signal level and compared and divided to get the meter readings internally inside ICs. Unless you can actually hear a difference, use the centering indent on the balance control to center the unit and leave it alone.
    Dan
  • ABRsvcs Apr 13, 2009
    If you have measured the output from the tape-out connections and the balance is correct, you have eliminated part of the front end. The tape out is independent of the volume control and tone circuits.
    The link you provided will give access to the owner's manual not the service information. If you have a copy of the service information, please provide a link and I'll take a look and indicate where to test the balance.
    Dan
    Ok there are a number of things to check:
    1) Compare R904 to R903. They should both be 27K resistors.
    2) Check C904 or just replace it. If it leaky, it could be the problem. This is a 1ufd 50V cap.
    3) If you have an oscilloscope, look at the signal levels when the unit is in Mono mode at pins 4 and 6 of the TA7318. These are the input pins and should read identical at this point.
    4) Check pins 2 and 8 of the TA7318. If these are different levels while pins 4 and 6 are the same, the TA7318 is defective.
    5) If #4 checks out OK, then the meter itself is the problem and you can try adjusting R908 to compensate.
    Keep me posted.
    Dan
    Locate page 5 of the manual. Look up and slightly to the right for the TA7318 IC which is an in-line IC with 9 pins. You will probably see R908 first on the board as a round part with 3 pins. Check the items listed above from there.
    Dan
2 Suggested Answers
  • 4234 Answers
SOURCE: unbalanced LEDs> amplification problem, or mere
This is a repeated problem, please see initial proble for the complete solution.
Dan
I have a JVC ax 220 amplifier and there is no sound coming out at all.
Is the receiver even turning on? If it is, listening carefully to the top cover, with the room quiet. Do you hear 1 click, or two?
If you're interested in having your JVC repaired, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
Feb 16, 2015 | JVC Audio Players & Recorders
Jvc ax 444 amplifier
http://uk.jvc-service.net/webtemp/AX-V55.pdf?CFID=15017492&CFTOKEN=79974873
This model is the nearest one I can find, but most amps from the same manufacturer use common parts and circuits.
Jul 13, 2014 | JVC Televison & Video
Vox vt40 factory reset
Consider reading the Manual for this amp, it explains how to reset to factory with the VFS5 footpedal. Or with the power off ..hold down CH1 & CH4 then turn power on.. when the Bank & Channel leds start blinking.. then release the Channel buttons. Next press the Tap switch ... the bank & channel leds will change from blinking to lit. with in a few seconds it will enter preset mode.
Apr 12, 2014 | VOX Amplification Vox VT40+ Valvetronix...
HOW TO WIRE GEMINI GRAPHIC EQ 3000 TO behringer djx750 proffessional MIXER
Line level output of the mixer would go into the line level inputs of the EQ, and the EQ line level outpputs to the line level inputs of the amplifier. If you are faced with a mix of unbalanced inputs or outputs, to balanced inputs or outputs it gets a little complicated because you need to matrix the balanced signal to unbalanced load and vice versa. There is no single answer to doing this either.
RCA jacks are unbalanced, 2 conductor 1/4 inch connections are unbalanced most of the time. XLR and 3 conductor 1/4 inch jacks and plugs can be either balanced or unbalanced.If either are wired so left and right are a single ring or tip on the 3 conductor 1/4 inch jack, it is unbalanced and they would share a common ground lead. XLR wired with one pin common with shield and right and left have a single conductor on the plug or jack, that is unbalanced.
Apr 26, 2012 | Behringer Pro Mixer Djx750 Professional 5...
I am thinking of replacing my now very old JVC AX 330 amplifier with a Marantz PM7003 amplifier and want to know if this is a suitable replacement in terms of power output etc.
You, sir, are a rare adherent to stereo-only electronics. Are you replacing it for cause (showing its age)? The PM7003 is only 2 x 70 watts like the JVC but it also has separable preamp/amps so you COULD upgrade or augment the power output with external amps and still control it all locally.
Of course, any current AVR's do that too and bring digital sources and multichannel audio to the mix for as little as the PM7703 may cost.
Jun 23, 2011 | Audio Players & Recorders
When I turn the power off on my amplifier my speakers make a loud noise
This often normal to get a pop as the power goes down. The amplifier goes out of balance as the power drops and it drives current into the speakers. This is a design problem and most amps don't even TRY to avoid it. Very large amps have relays that disconnect the speakers an instant before the power collapses to protect the speakers.
Dec 12, 2009 | Music
JVC AX-66 Integrated Amplifier seems to be muted?
You need to have a jumper between the 4 standalone jacks on the right side of the column of stereo connectors. A stereo RCA cable would work for this.
Oct 14, 2009 | JVC Audio Players & Recorders
PXA-H700 optimum set up...
The way the EQ is hooked up is correct.
You set the factory radio to a set level, then use the volume on the EQ for everyday adjustments.
I believe your problem lies in the amplification.
Your BOSE amplifier was made to run a 4 channel 8ohm stero load.
Low powered - high in sound quality.
You have swapped the factory 8 ohm speakers (15W) for 4 ohm power hungry ones.
Now the amplifier is working harder to produce the same output.
You would be best served eliminating the factory amplifier and getting 1 good 4 or 5 channel amp to power your speakers.
a 4 channel amplifier could be used stereo (left and right) on channels 1 and 2, (2ohm stereo load)
and bridge channels 3 and 4 for your subwoofer.
For a true surround sound - a 5 channel amplifier could run each speaker individually, and the 5th channel is reserved for the subwoofer.
a small dedicated 75wx4 channel amplifier with built in crossover, and level gain controls - would blow your socks off. It is 200x better than the factory 12Watt amplifier. Your ears will love you for it :D
If you need more help - just let me know.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 23, 2009 | Alpine PXA-H700 Car Video Player
Unbalanced LEDs> amplification problem, or mere graphic drop out? my newly acquired AX-1 does not show as much power level indication on the left LED. cannot really hear a difference when panning between...
Dan
Apr 12, 2009 | JVC Audio Players & Recorders
Yamaha DSP-AX1 10-Channel Amplifier Logo
278 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
