Question about Honeywell Programmable Thermostat Heater
Honeywell thermostat reads ''-AC'' what does this mean?
We had a power outage and then it returned about 20 minutes later. Since then the thermostat reads -AC and won't kick the heat or the Air Conditioning on. It won't alllow me to program anything either.
  • Honeywell Expert
  • 252 Answers
-AC means no power to thermostat from furnace.
Posted on Apr 12, 2009
Honeywell TH9421C1004 blank screen after power outage
We'd love to help resolve this. Please give us a call at 1.855.733.5465 and our customer support team will be happy to troubleshoot with you.
Sep 01, 2014 | Honeywell TH9421C1004 VisionPRO IAQ Total...
Honeywell Chronotherm iv Plus power cuts on and off
There's a trouble shooting guide here, you need to check for the presence of 24V when it goes blank, and trace back to where it's disappearing (I assume it is losing the 24v, if not you'll need to go through the installer setup or read on...
My first thought would be to check the wiring which has been touched last if it started doing that after you had coil replaced.
As an aside I'm not sure which model you have but if it has batteries you should replace them (I don't think it does have batteries but not seen a model iv so I'm unsure)
https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-1410.pdf
May 12, 2014 | Honeywell Programmable Thermostat Heater
Reset after power outage
Most programmable thermostats have batteries to keep the program from being lost in a power outage. If you thermostat has dead batteries or no batteries a power outage will cause the thermostat to revert to a default setting and it will have to be reprogrammed. Hope this helps.
Dec 22, 2013 | Honeywell Heating & Cooling
Ac won't turn on it just clicks.
Hitachi DC Inverter Scroll Compressor have a startup problem. when i start the unit the compressor start a voice of " Tak, Tak , Tak rasie and after 30 Second the compressor trip, after few minutes the compressor again try to start and again Tak, Tak, raise and compressor trip. please somebody help me about this issue.
Jul 29, 2013 | Honeywell ER150B Air Conditioner
I have the same problem.
transformer going bad or bad connection check for 24v ac from red to common batteries only for mem storage and if no common used at stat to hold program red to g fan red to y comp
Jun 09, 2009 | Honeywell Programmable Thermostat Heater
My Honeywell Thermostat Mdel # T8011R displays all the icons at the same time. This occured when returning from an electrical outatge.
After being disconnected from the expert, whom wasn't of any help, I called our AC/Heater maint. person for service. Upon hearing the problem he told me to turn the power source off for at least 30 minutes. After restoring the power source everything worked fine. The secrret is leaving the source off for at least 30 minutes. Your expert advised to turn the source Off and then back On which didn't solve anything. This remedy may work with other Honeywell models as well.
In all due respect, I hope I'm not charged for the lack of results which your expert provided.
Frank Mooney
Jan 27, 2009 | Honeywell Programmable Heat Pump...
-AC appears in the display of chronotherm III
I have had the same problem- twice. It was a similar but different problem each time. The -AC means the ac control voltage isnt making it to the thermostat. In my case both times it was a switch in the control circuit that wasn't closing properly. The easiest was the front cover switch. If the front cover is removed from the furnace or has vibrated loose, the switch will open, preventing the furnace from running. The other instance I ran into was a flow switch on the exhaust blower which ensures the there is flow OUT the chimney. The switch wasn't functioning, so the furnace wouldn't start. The blower would come on for a short time, but the burners wouldn't light.
Hope this helps,
Dec 12, 2008 | Honeywell Programmable Thermostat Heater
Honeywell T8001C
Hi, take a look on amazon for replacement, here: Defy Mother Nature with our Best Buy. I hope this was helpful. Cheers
Apr 04, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
1,642 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
