Question about Black & Decker Garden
Can anyone advise how to wire the motor on my Black ans Decker GK430 chainsaw? There are 4 wires and I'm not sure which connects to where. Cheers PRR
erpaalai
  • 999 Answers
SOURCE: wiring a 220v single phase motor and capacitor
Black and white are usually power. an ohmmeter will confirm. Brown are for capacitors. There is almost always a diagram on the motor someplace. Eric
Posted on Jun 17, 2009
  • 574 Answers
SOURCE: top element not working all wires are connected
Very possible the element on top has a break some where but maybe small enough you cant see it or could be hiden. If you have access to a multimeter put it to ohms and with it unplugged from the outlet take the wires off the element and check the element itself if the multimeter reads OL the element is bad.
Posted on Mar 08, 2010
  • 351 Answers
SOURCE: Replacing a pull chain 3-way ceiling fan light switch
OK .. the thick black and white are the power for the fan , are there also white wires on the lamp sockets ..??
The thick black wire should connect to the black wire on the switch.
The small black wires connect to the red and blue wire on the switch .. two small black wires each .. that should give you a position for 2 lights , and 4 lights, on the step switch .. but there should be white wires from the lamp sockets connected to the thick white from the fan .
please respond .
Please Vote !!
Posted on May 25, 2010
Testimonial: "I appreciate the response, which reinforced my thought process and it worked - Thanks!"
  • 4088 Answers
SOURCE: Electric Chainsaw - chain stops when you try to cut!
Remove the bar and chain--check the sprocket and shaft for any mechanical damage. Try to turn the sprocket by hand in a CCW direction, does the shaft move with it? Does it seem to turn the motor? If the sprocket and shaft seem ok, then you may have a damaged gear (likely plastic) within the gearbox. Hope this helps!
Posted on Jul 09, 2010
SOURCE: mm850switch for black decker wher do wiring go
Here is a picture of where the wires go on the switch.
Posted on Jul 22, 2010
Black and Decker Logbuster 26.2 CC 2 stroke Model CS26012 chainsaw
Have you checked BD's web site , they have lots of manuals for free. Call a shop near you an ask the fellow there, or better yet go in an purchase something from him an ask. More than willing to help.
Feb 27, 2014 | Heavy Machinery
Need help wiring a 5HP 1Phase motor on Powermatic 66
As you only have 4 wires from the motor it should be straight forward as two would be from the start winding (Black and red) and the other the run winding (White with yellow stripe and Blue). You should be able to check this with a tester as there should only be continuity between the wires as mentioned above.
Reference the thermal switch, I am not 100% sure on the color codes but have attached a diagram which should help but will advise as best as I can on the connection. The diagram is for a high/low voltage but you can disregard the winding on 3 and 4 but should help on the understanding.
Join the blue and black wire from the motor together and connect to the black wire from the supply. You should be able to run the motor (Excluding the thermal switch) by connecting the White with yellow stripe and the red wire together along with the white from the supply. To include this switch I would presume that you would connect the red wire from the motor to the brown wire from the thermal switch, the yellow wire from thermal switch to the White with yellow stripe from the motor and finally the white wire from the thermal switch to the white from the supply.
Jan 29, 2014 | Powermatic Saws
Jul 09, 2010 | Black & Decker Garden
Battery powerd chainsaw will not start
It's possible that one of the motor brushes may have been damaged--also check their spring tension. The battery may be charged, but have no capacity. You will need to measure the battery voltage directly when trying to start the motor. If it falls to zero, then you either have a poor connection at the battery, or it needs to be replaced (under warranty?). Hope this helps!
Jun 29, 2010 | Black & Decker Black Decker Lp1000...
Electric Lawn Mower Doesn't start - Pwr supply ok - No burnt Moto
this mower has a dc motor and the brush on the black wire to the motor usally wears down
Mar 03, 2010 | Black & Decker 19" Electric Lawnhog...
BLACK AND DECKER HANDI SAW ISNT WORKING
there are several trouble shooting you can perform:
1. Check the plug particularly teh wire attached on it.almost all of the wires of a power tools got damage on the wires itself due to a continous moving when working.
2. Somtimes there is a built-in fuse or breaker.
3. Check the Switch.sometimes the spring materials of a switch is malfuncioning and it couldn't connect the conductor to run a power.
4. Check your carbon Brush.You must replace it if it is already below 1/4 inch long.
5.Can you feel a little vibration when you switch the unit?if that so,check the bearing because it is surely the bearing has damaged because the armature and core of the motor is already touching each other thats why it will not rotate anymore..
Oct 30, 2009 | Black & Decker Cordless Handi Saw
Have an old sears craftsman 1/4 hp grinder model 397.19501 wires have been disconnected. I want to rewire and test. Does anyone know how to connect the wires? There are 2 copper tabs under the on/off...
the two copper tabs under the on off switch are to break the power source.connect incoming power to one of these(black) then a short piece of wire from the other tab under switch to one of the three tabs under plate that is marked hot or l1 is probably #2 but you need to be sure. the white is the nuetral or l2 which is most likely #3 and the green is the ground most likely #4 I would definately look online for a wiring diagram to be sure if they are not marked with L1 L2 and GND
Oct 10, 2009 | Black & Decker 3/4 Hp, 8" 205MM, Heavy...
Black and Decker MM525 hard wiring diagram
the connection the are not right. top left side is for white wire.buttom left side is for red wire. top right side is connected to black wire from motor. buttom right side is for is going to the
extension terminal. good luck
Jun 02, 2008 | Black & Decker 19" Electric Lawnhog...
WIRING DIAGRAM? FOR BLACK AND DECKER ELECTRIC LAWN MOWER
the pic says the connection are not right.all left side connection are for brake which is the red & white wire. all right side connection are two black wire.
Feb 06, 2008 | Black & Decker 19" Electric Lawnhog...
Garden Logo
77 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
