Question about Akai PDP4294 42 in. EDTV-Ready Plasma Television
Our tv will not turn on
Hi there. We were watching tv the other night and all of a sudden it turned off. we tryed to turn it back on, the little red light flashed to turn on but wouldn't turn on. Would this be a bulb?? This model is an Akai HDTV 1080i projection (I think) The models that come up don't seem to be the right ones. I hope you can help.
Our AKAI was just 14 months old. A few days ago, it died also. Blank screen, no sound, but the timer light will flash on a couple of times when you try to power it up. It even sounds like it wants to turn on. I paid a tech to come to my house $65 and it turns out to be the power supply $385. I checked other chat boards and many people are having this same problem with their AKAI 42" (PT4298HD) televsion. A real piece of junk this model! Sorry for the bad news!
Posted on Sep 21, 2007
SOURCE:
TV just turned off while watching it - red power light flashing now and burning smell
The flashing red light means there is a problem that cannot be fixed on it's own. there is a good chance it is shot. You may have to take it in but most likeley it will cost close what replacing it would cost.
Sep 27, 2012 | Televison & Video
My 32" Element LCD tv is broken. One night I was watching tv and all teh sudden there was blue, red and yellow lines running horizontally across teh screen, audio was fine. I turned it off and unplugged...
Yes!
It has suffered a breakdown in the power supply and the damage has also spread as far as the sustain boards that control video and convergence. This is not a DIY and the repair for parts is $300 + labour. However, get a few quotes. At least a 32 in is a little more transportable than a 6' model
Please rate my help++++Thanks for using FIXYA
Jun 28, 2010 | Element ELC-HS321 32 in. LCD TV
My sony trinitro wont turn on, the stand by light flashes 4 times
the four flash is a signal, it means either faulty power supply or deflection circuit trouble.
Jul 27, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
36" toshiba suddenly turns off and the little red light flashes
Some el.components are loose on tv circuit board.I have removed the back cover,supported tv picture tube 45 deg.against wall.This tv is heavy!One screw on left holds the circuit board to bottom case.Removed and supported this board on few heavy books.Turned tv on and gently probed all the componets on top of the board with plastic drinking straw.In my case transistors Q-830 and Q-421 needed resolder loose joints.These components are mounted on flat aluminium heat sink strips located sligtly left of center of the circuit board.Also blobed bit of silicone into base hole and foot of alu.heat sink to support it.
Apr 15, 2009 | Toshiba 36A50 36" TV
Status light just flashes red and will not turn on
Firstly, unplug your tv for at least 4 hours. Over night is better. This is what we call a Hard or Master Reset.
This should solve your problem. If by chance it doesn't, then more than likely your power supply board is shot.
Very common in the newer tv's
Jan 16, 2009 | Polaroid FLM-3225 32 in. LCD Television
Flashing red light
Same problem with my Sony. Unplugging for 36 hours solved the problem
Oct 05, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
RCA 32V434T Flashing Red Light
Flashing led..in protect mode..internal shorted component.
Aug 14, 2008 | RCA F32450 32" TV
Tv wont turn on
TV STARTS UP AND GOES BLANK SOUND NO PICTURE
May 16, 2008 | Philips 32PF5321 32 in. HD-Ready LCD...
Power button Flashes
For the first one, please list the model number and count the blinks. Also, can you please post each problem separately. It will get too confusing trying to address 3 sets with different but similar problems.
Thanks,
Dan
Mar 18, 2008 | Televison & Video
Bad Convergence circuit , replace 2 STK392-110 & fuse will take care the problem
Jul 18, 2007 | Hitachi 43FDX15B 43" Rear Projection...
Akai PDP4294 42 in. EDTV-Ready Plasma Television Logo
183 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
