Question about Hitachi 53SBX59B 53" Rear Projection Television
Hitachi 53SBX59B 53 in. Rear Projection Television white lines
I have thin white lines rolling down the screen horizontally. Does anyone know how I can fix this? I have some electrician skills and tools and experience. A digital multimeter, soldering iron ect. Any help in a positive direction on how I can correct this issue and what possible parts I may need to replace to correct the issue from the source as well as the cause.
Thanks,
Jim
Slinteriors
  • 8617 Answers
SOURCE: Skill Level
Its a fairly easy repair, However be careful where you get the ICs alot of places sell the cheap versions. You can get good quality ICs at the link I am posting I am one of their support techs plus they offer free tech support to help you. You will need to STK392-560 ICs for your model. The ICs arent that hard to solder getting them out is the hardest but if you grab some de-solder wick from radio shack its actauul alot easier. Heres a link where you can get quality ICs if youd like. They also have the service manual for your model if youd like one. They email the service manuals.
http://servicemanuals.vstore.ca/
Posted on Apr 18, 2008
  • 4234 Answers
SOURCE: hitachi projection 53" screen color off
Since this is a CRT based projection set, there is no "lamp" involved. Does the picture look like 3-D? If so, the problem is likely to be a convergence problem. There should be 1 or 2 convergence ICs marked STK392-110 inside attached to a heatsink. If you can solder, try resoldering the pins on those ICs. If that fails to resolve the problem, replace them.
Keep us posted.
Dan
Posted on Jul 14, 2008
ladywinn
  • 5138 Answers
SOURCE: Hitachi 53" projection (53UDX10B) line across screen
Replace STKS also it is a 6 hour job if you have to do a complete realinement of convergence so do not clear DCU ram module.
Posted on Nov 27, 2008
  • 132 Answers
SOURCE: i have hitachi 53
Check this site
http://www.partstore.com/
Posted on Oct 19, 2009
SOURCE: hitachi ultravision digital 65
my tv is green the colors say that there 100 percent but the yellow is at 0 does that mean i need a new lamp, bulb or what?
Posted on Nov 30, 2009
I have a 53" Hitachi Rear Projection TV, Everything works except the color. The 3 color projection lamps are functioning and all of the tv's focusing features appear to be functioning as well. It has a...
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 14, 2010 | Hitachi 53SBX59B 53" Rear Projection...
I have a hitachi 53sbx59b 53in tv
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
Sep 27, 2009 | Hitachi 53SBX59B 53" Rear Projection...
My mirror is broke in my big screen do you have to buy a special mirror or can you use any mirror?
The mirrors are specific to the unit as they have slight curves to bend the picture correctly so it aligns to the screen properly. To ensure you get the correct picture for your unit, you would have to order the manufactures original replacement part. You can order an new OEM replacement mirror for this model (53SBX59B) from a major Hitachi parts distributor at the link below:
Hitachi 53SBX59B Replacement Part Mirror / 53" Inner Mirror
Apr 13, 2009 | Hitachi 53SBX59B 53" Rear Projection...
HITACHI 53SBX59B, projection lights don't line up.
It sounds like bad solder connections in the convergence output circuit. It may also be an intermittant convergence output ic which will need to be replaced.
Jan 04, 2009 | Hitachi 53SBX59B 53" Rear Projection...
53 Hitachi Ultravison TV : Getting Horizontal lines rolling up
ok
this is called viedo noise
you will need to replace capisitor Cc10 its Value is 1000uf @ 16v the cap is a filter On Sw +9v Line , on pin 20 of Ic01, ( or corma Jungle IC)
Dec 30, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Need part number????
The Hitachi part number is: 2338313 and is available for $3.22 from tritronicsinc.com
Hope this helps,
Dan
Aug 26, 2008 | Hitachi 53SBX59B 53" Rear Projection...
Hitachi 53SBX59b Rear projection TV out of convergence
from you bought the tv and notice that it has that stain on the edge you should have taken it back as it was covered under warranty.now it is getting worse it will cost you to get it fix your tv has a factory defect.you will have to call the repair man to fix your tv.good luck.
Apr 26, 2007 | Hitachi 53SBX59B 53" Rear Projection...
Hitachi 53SBX59B 53" Rear Projection Television Logo
131 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
