Question about Parmak Solar Fence Charger
No shock from charger
Battery indicator showing red but has new battery
    An user who is expert in 3 categories / brands.
  • 1,001 Answers
14W Foldable Solar Charger with 2-Port USB Charger Build with High efficiency Solar Panel Cell for iPhone 6s / 6 / Plus, SE, iPad, Galaxy S6/S7/ Edge/ Plus, Nexus 5X/6P, any USB devices, and more
Posted on Dec 19, 2016
    New Friend:
When responding to a question. Read & understand the question. Question was no power from charger? Not the fence. I and hundreds of others would like to know the answer to the question???
Posted on May 30, 2013
  • 50 Answers
Did you make sure the fence isn't grounded or an insulator hasn't melted
Posted on Apr 13, 2009
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
My victory 4 mobilty wont charge the green light is very faint/the charger was tested why wont my scooter charge
make sure battery cables are secure at battery terminals and old are the batteries.If the batteries run down fast they are no good.a good way to test them is put scooter against some thing solid and go forward.If the battery indicator drops to o the batteries are no good.It takes about 10 hours to charge the batteries
Mar 15, 2013 | Pride New Mobility Victory XL 4 Wheel...
How do I know when an EN-EL! for the Nikon Coolpix 5000 is fully charged? what do the following conditions indicate? 1. Charger red light flashing 2. charger red light steady 3. charger red light...
Charger flashing red indicates the battery is still not full and is in the process of recharging.
Red light steady indicates your battery is fully charged and ready to operate with your Coolpix 5000.
When red light is off it indicates there is no battery inserted or the charger is not pluged in.
Mar 26, 2011 | Nikon EN-EL1 Battery + Charger...
Upon power up, 3 red LEDs flashing rapidly continously, no power.
The control systems on power mobility equipment have a "prevent" circuit that immobilizes the equipment while it is plugged into a charger, so folks won't take off with it plugged into the wall outlet. When you turn it on when plugged into a charger, the display will flash constantly, or sweep constantly, depending on the manufacturer. This is normal. Your off-board charger should have a red light to indicate power to the charger, and another light for the charge status. Yellowish means it is charging, when it turns green, you are fully charged. If the status light is green all the time, that is an indication that the charger is not functioning properly, or that the batteries are below a chargeable state. Check charger output, which should be 26-28 volts dc, and each battery should show at least a 12 volt reading, but around 13.5 volts with a full charge. If one or both of the batteries drops below 12 volts after a short period of time, it's time for a fresh pair. Fully charge new ones before using the chair.
May 31, 2009 | Pride New Jazzy 600 Power Wheelchair by...
Battery won't charge.
normally many cell phones requires 6-10hrs for its batter to fully charge up. also i have seen it where battery can be brand new but doesn't have enough juice to hold the charge.
now as far as red light on charger, remember even if you have 99% charged batter and you plug in the charger it will show you red light on phone/cradle.
FYI- all brand new phones are covered with 30 days of warranty replacement with new phone. after 30 days it covers upto 1 year from the date of purchase with refurbished phones.
In your case i think it is just the battery, try having your provider replacing new battery if no luck again then my suggestion will be to replace your phone with new battery with in 30 days.
Dec 22, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Battery indicator light blinks red
if it show fully battery also when u charge your battery it show from the red indicate only tht is not a problem... u need to charge the battery fully ... untill the msg shown as charge complet .. so need not to worry about the Red blinking battery indicator when you plug in charger.
Apr 28, 2007 | Motorola Mobility RAZR V3
Parmak Solar Fence Charger  Logo
718 people viewed this question
Top Parmak Electrical Supplies Experts
Craig Butler
Craig Butler
Steve Pack
Steve Pack
Are you a Parmak Electrical Supply Expert? Answer questions, earn points and help others
