Question about Reddy Portable Forced Air Propane Heater w/ Variable Heat Ouput
My heater wont stay lit
I turn it on the pilot lite comes on the gas val opens the heater lites goes out in a few sec got plenty of gas
    Scholar:
  • 192 Answers
Chanches are the thermal couple a safty divice is gone bad. they don;t cost a big bunch and the parts store at a local propain dealer may show you how to install it. its no biggie. Good luck. DFD
Posted on Apr 13, 2009
Why it doesn't stay lit
Replace the gas valve or thermocoupler.
Oct 15, 2013 | Coleman 5040-751 BackHome Open Flame Patio...
Jandy lite 2 pool heater will not stay lit.
I'm having the same issue as the above user with Jandy Lite 2 (which from what I can tell stands for the number of times that you can get this POS to work annually)!
The unit LIGHTS OFF, but WON'T STAY LIT! Igniter engages, gas valve opens, unit lights, burns for 10 seconds, and flames out. Error code FL 2, after third attempt, already replaced the flame sensor....
May 12, 2013 | Pool & Spa
Teledyne laars xe pool and spa heater
look inside on panel directions if not turn to pilot setting hold down button light under where small silver line goes under while holding down button when lit keep holding for about a minute then turn to on should stay lit if wont stay lit need new pilot generator
Jun 09, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
My Kozy heater turns off after a few minutes, I then have to re light it and when it kicks on again after a few mins it turns off again. It will stay lite if I turn it down but when it goes on agin it will...
If you have a standing pilot that wont stay lit and you have to keep relighting it, it can only be a couple of things that will do this.
1. Try tighting the thermocouple at the gas valve. (this is a thin copper line that goes from the gas valve and goes to the pilot light.)
2. Make sure that the tip of the thermocouple is in the pilot light flame.
3. Make sure that the thermocouple is clean.
Mar 22, 2011 | The Companion Group Kozy World Portable...
Pilot lites; but, as soon as I turn on gas flame
sounds like your thermacouplar is going out and needs replaced. Sometimes these will act like they are working fine , but when the pilot stays on for awhile and later goes out it is a sure sign that it is bad
Nov 08, 2009 | Procom ML300TBA Heater
Laars Lite 2 LG - pilot light will not stay lit. As long as you hold down the pilot light once it is lit it stays lit but when I turn the nob to the "on" position (release the pilot light button) the flame...
It sounds like a thermocouple has gone bad. this is a very common problem with gas powered things ie; water heaters, furnaces, hot tubs. The telltale sign is when you release the pilot light button it won't stay lit. This is a safety feature and is relatively inexpensive and easy to repair.
Aug 08, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
No able to lite pilot
make sure gas supply is there also clean the thermocouple, if it is fowled or dirty the pilot wont stay lit nor will the main gas valve open
May 24, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Pilot stays lit, but burners underneathe do not light up or burn.
Check pump is working, if so could be stuck flow switch or gas valve fault get unit serviced
Aug 31, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Reddy Portable Forced Air Propane Heater w/ Variable Heat Ouput Logo
239 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
