Question about Lexmark X4650 InkJet Printer
Paper jam in Lexmark printer
Hi, just trying to sort my mums x4650 printer out, it has a paper jam and I have no idea how to free it. Can anyone help please.
  • iris835 Apr 12, 2009
    Just to add it keeps saying out of paper.
    Scholar:
  • 54 Answers
First turn the printer off then back on:
1 Make sure:
• You use paper designed for inkjet printers.
• If you are using photo, glossy, or heavyweight matte paper, you load it with the glossy or printable side facing
you. (If you are not sure which side is the printable side, see the instructions that came with the paper.)
• The paper is not used or damaged.
• If you are using specialty paper, you follow the instructions that came with it.
• You do not force paper into the printer.
2 Before loading paper, slide the paper guides out toward the edges of the paper support.
3 Load the paper vertically in the center of the paper support, and adjust the paper guides to rest against the edges
of the paper.
Note: To avoid paper jams, make sure the paper does not buckle when you adjust the paper guides.
Posted on Apr 14, 2009
Paper will not feed
Hi, maybe there is still a little bit of jammed inside that you can\'t see. Try to see if there is and clean it. If you\'re sure there is no paper jam whatsoever, then there is a conflict with your feeding sensors or your cartridge isn\'t properly installed.
kind regards
Apr 17, 2013 | Lexmark X4650 InkJet Printer
Paper won't feed
You may refer to this article on Paper Jam and Misfeed Troubleshooting in the Lexmark X3500, X4500, X4600 & X4800 Series All-In-One. You may contact Lexmark technical support for additional assistance. Thanks.
Jan 19, 2011 | Lexmark X4650 InkJet Printer
Printer say paper jam but no paper how do I fix it
Hi, if your printer says paper jam, thet means that there is some paper that block it, so you have to look all around, and be sure that there is some paper blocking it.
Good luck
Nov 27, 2010 | Lexmark X4650 InkJet Printer
Paper jam inside lexmark x 4650 - how to get paper out of machine
If you can't get the paper jam out from the feeder, open the cover to see where the cartridges are. See if you'll have a better hold of the paper stuck in it. Hope this helps.
Jul 26, 2010 | Lexmark X4650 InkJet Printer
My printer keeps giving the error "paper jam". I cannot find any kind of paper jam in it. Any ideas to fix this?
these printers will give this error if the main motor drive fails to initiate. its probably cheaper to buy a new printer
Nov 02, 2009 | Lexmark X4650 InkJet Printer
My lexmark x4650 keeps on getting paper jams and i think its something to do with the roller so any info please help :D
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Sep 13, 2009 | Lexmark X4650 InkJet Printer
False paper jam message
Look for tiny pieces of paper shreds that might stuck up with the rollers.
Jul 30, 2009 | Lexmark X4650 InkJet Printer
PAPER JAM IN MY LEMAX X4650
Have you really checked the printer, there may be a small piece of paper jamed inside the printer, this is a common fault and common fix for most printers.
Jun 03, 2009 | Lexmark X4650 InkJet Printer
Lexmark X4650 ink jet printer has paper jam
Please follow these steps to set your printer to defaults:
1. Please make sure your printer is set in Copy Mode.
2. Press the "setup" button, you will find "Maintenance" displayed.
3. Use your arrow keys to locate "Set Defaults" and press "OK".
4. Press the arrow key to find "Use Factory" and press "OK"
This process would reset your printer to Factory defaults.
Apr 28, 2009 | Lexmark X4650 InkJet Printer
Lexmark X4650 InkJet Printer Logo
450 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
