Question about Nokia 7373 Cellular Phone
Nokia 7373 bluetooth problem
My nokia 7373 wont receive any bluetooth items from my friends with samsung phones, it just says that "sending failed" i can send them stuff but they cant send me anything. please help xxxx
Re: nokia 7373 bluetooth problem
My nokia 7373 has a memory card of 256, inside there are 4 folder: Themes, tones, videoclips and video, when i connect bluetooth with my PC I have a problem: I can not access to this 4 folders I got a message error connections, but to the others folders in my memory cards is easy to access. Can anybody help me please?
Posted on Mar 24, 2008
I had the same prob recently.. but i managed to solve it by formating my memory card directly using my nokia. After that everything was ok! :)
Posted on Jan 05, 2008
0 characters
3 Points
How to send a item via bluetooth from telefunken instructions
If your phone type(Nokia,Samsung, LG,or any smart phone contain Android System):
1st select file who need to sent it via Bluetooth.
2nd request from your friend to make his Bluetooth in his phone (ON).
3rd send the file.
If your type phone is (I-Phone) you can just send to same phone type:
1st select the file who need to send it and see this picture.
must your friend press on the bottom in red cycle and then
2nd show this picture.
must your friend press the bottom in red cycle shown in below pictures.
6ea915c2-39dc-4e3a-9e9d-40414bf35c33.png 78e875e3-9721-43e4-ba8a-bcf8f2b971f1.png 09dd3f27-8631-4a8d-980d-b8588f644d9e.png
then your AirDrop available like this picture below:
then you friend's name appears instead of the AirDrop and he must apply you to received file
Jul 16, 2014 | Cell Phones
I cant recieve any music it keeps saying operation failed.
when i send music with my mobile via bluetooth on my phone it says "operation failed"..
Mar 16, 2010 | Nokia 6300 Cell Phone
Okia 3110c i cannot receive any files from
blue tooth IC is malfunctioning u will need to replace it. Also check if u can send through bluetooth if u can then u need to dump all items into folders and then check
Oct 13, 2009 | Nokia 3110 Cellular Phone
Not able to receive .wmv files to my mobile throug bluetooth. Shows 'Operation failed'
hello friend through blue tooth u cant send big files its cant make it MWV files means big files like so check it .
Jul 14, 2009 | Nokia 6300 Cell Phone
Blackberry 8110 - cant receive bluetooth stuff
with a blackberry you have to go to the media player, go to music for music and then hit options receive using bluetooth
Dec 03, 2008 | RIM Blackberry 8110 Cellular Phone
Non transfer of music files via bluetooth
i've lost the usb lead for my 7373, and wanna know if there is something i can download that lets me send things from my comuter to my phone. does anyone know of anything?
Jul 13, 2008 | Nokia 7373 Cellular Phone
Go to;
Bluetooth, again select ON,
My Phone Visibility, select SHOWN TO ALL,
My Phone's Name, give it a Name ie. mine is Goliath,
It should work after that. The order of the menu might not be the same on your phone as above, but it gives you the idea of where to find Bluetooth settings.
The name you give your phone is the name that other people will see when you send a file/pic etc...
Dec 31, 2007 | Nokia 7373 Cellular Phone
Bluetooth ;; samsung
hey buddy if u have allready tried with another phone than the diffrence might b the versions of BT's in both of the handset however there is no hard and fast rule that it can't be send from 1 v to another version try to send some data from ur side to samsung handset if it works than there is someh\thing wrong with samsung BT...... Best of luck
Nov 06, 2007 | Nokia 7373 Cellular Phone
Nokia 7373 memory card
the phone memory is full thats why you cant receive anythink.try to delate some messages and move some of your pictures,videos songs on your mmc.
Sep 05, 2007 | Nokia 7373 Cellular Phone
Nokia 7373 Cellular Phone Logo
398 people viewed this question
Top Nokia Cell Phones Experts
IT Solution
IT Solution
