Question about Mitsubishi VS-60705 60" Rear Projection Television
Power problem Tv will automatically shuts down when turned on. convergence amplifiers have been checked and swithched. Problem continues. Neone got ne Ideas
    Genius:
  • 1,153 Answers
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB
Posted on Sep 10, 2007
SOURCE:
Will not power up has constant on off flicker , when I turn it on the green light clicks off and turns red and the cycle repeats. I have checked the fuses and also resolderd the power board. is there any...
Hi Eric,
First of all, thank you for contacting Fixya.com regarding on your TV problem.
I've suspected a convergence chips failure not the power supply board issue in this kind of symptoms. To confirm it, locate the convergence board inside the set, it has a Sanyo convergence chip STK392-110 that are mounted on the large heat sink. This board has a LED (light emitting diode) that will light up once the board gone to malfunction. Turn on the unit and then check if the LED will lit after the shuts down. If yes, then I would advice you to replaced both convergence Chips and check the resistance of the resistors in line with the +25V and -20V supply of the chips.
Let me know if the LED at the convergence board does not lit to continue our diagnosis... Check also the LED at the power supply board and on the deflection board(this is where the flyback transformer is located)
Have a nice day!
Goodluck and take care!
Kind Regards,
Jdvillanueva
Dec 03, 2011 | Pioneer PRO-99 TV
Turn tv on,tv shut off then power light blinks 3 times,pause and continue to blink 3 times
Check the site www.TvRepairKits.com - your convergence may have shorted out causing the tv to power off.
Apr 24, 2011 | Panasonic PT-47WX53 47" Rear Projection...
McIntosh MC7106 Amplifier not powering up
It can be a variety of reasons but I feel that your amplifier is shutting off after powering on. There is nothing that can be done from the outside but If you are familiar with basic electronics and can attempt to take a look I can try. Open the set after you have pulled off the power, then look into the set and tighten all the connectors and cords. Power on and see where the click comes and goes off. If the relay is not holding on then your protect circuit is shutting it off. Armed with a multimeter turn on the power and check if the main +B power is coming to the output stages.If there is momentary swithch on , then disconnect power and test the continuity in the output stages. If hsort open the leads to the output section and then power on. If the relay stays we have found the fault. you can go on to change the failed outputs. If however the outputs were tested ok, then your fault could be the relay or the protect circuit, Hold a rely for a moment to see if the amplifier powers on, if so check the relay drive transistor , the biasing to the stage. Try this out and I hope my advice helps. Good day
Jul 21, 2010 | Audio Players & Recorders
I have a RCA HD52W59 TV. Shuts off automatically.
Power supply is my initial thoughts, but then again it could be that one of the three CRT's tubes has an issue.
My thoughts is that it would be best to bring it to a good TV repair shop.
Why spend money on a power supply and then find out it's a CRT.
Blessings,
A/V Media Guy
Nov 20, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Hitachi 43UWX10B 43" Power Light flashes Continuously
I doubt if its the fuse. We just helped a customer with a very similiar problem. Its more likely that the convergence IC have failed and shorted out. When this happens one of the symproms is that the TV will shut down and chirp. Goto www.TvRepairKits.com and click the contact us button. They can provide you with more instructions on how to test if this is the problem.
Ed
Jun 16, 2009 | Hitachi 43UWX10B 43" Rear Projection...
TV won't turn on. Red power button flashes then shuts off.
Did the TV work but with a convergence eproblem before you changed the STK's.? If so it is very likely you have misplaced one of the several leads when reassembling the set. It is ususally a perfect cure. Power light flashing 4 times indicates this type of problem.
Feb 21, 2009 | Hitachi 43UWX10B 43" Rear Projection...
My philips tv won't turn on.
Very unlikely to be the switch. With the power supply shutting down, the problem is probably in one of the circuits that is supplied by it. Unless you know what you are doing, leave it to a technican.
Dec 30, 2008 | Philips Televison & Video
Shutting down problem
go to setup utility and load the setup default values.
Also go to desktop properties and select screen saver tab and then at the bottom a power tab then go to advance tab and select when i press power button select option shut down.
Jan 04, 2008 | Toshiba Satellite A20 Satellite A25 Series...
Tv shuts off but power light continues to flash
Unit is telling you something is wrong with circuit. LED pilot flashes when malfunction is detected. Power supply shuts unit down to prevent further damage and/or fire. Leave off and seek pro/tech check out
Nov 30, 2007 | Panasonic PT-53WX54 53" Rear Projection...
TV turns of automatically
could be noumerous things: 1. check power supply, too high or too low voultage may cause TV to shut down. measure it to detarmine if power supply is faulty. 2. check convergence board. If either of these 2 fuses on the convergence panel are open then replace the STK output devices PLUS check for any resistors in that circuit that may have overheated and changed value. Use actual fuse values, putting in a larger fuse, even to try and diagnose problem, will cause more severe damage. 3. Check for bad solder connects on the PC board in the area of the power cord and related components. good luck
Mar 26, 2006 | Sharp 27C-240 27" TV
Mitsubishi VS-60705 60" Rear Projection Television Logo
164 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
