Question about Car Audio & Video
Performance teknique icbm 4500 harness
I need the wiring harness to hook up my performance teknique icbm 4500 to my car, but I can't find nothing online to get it even on the perfomance teknique web site. I send a fax with my information to them because is the only way I can contact them, but I have no answer I don't know if you know where could I find the harness
  • 631 Answers
SOURCE: Performance Teknique wont work!!
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible problems, do the following. I'll assume that you've checked the amplifier's on-board fuses.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp almost certainly has shorted output transistors and will need to be repaired.
If you want to try to repair it yourself, read through the following page:
Basic Amplifier Repair Primer
Let me know if you have any other questions.
Posted on Jul 02, 2008
  • 2427 Answers
SOURCE: problem with my Performance Teknique ICBM-9472T 10.4 in. Car Monitor
any eletronic shop has the wires you can use, may not be the same exact one needed but it will work, you can take a pice with you so the guy can get the propper guage. If its a ribbion type wire, let the electronic technician handle that for you since its easily broken and rather difficult to solder.,,
Parts are aviable for both standered wires and ribbion typem from
1.)Electronic shops
2.) Radio shack
3.) manufacture of the product
4.) old equiptment and appliances.
Posted on Jul 17, 2008
  • 631 Answers
SOURCE: performance teknique icbm-896 stick on diagnostics
If it's in protect mode, it probably has shorted output transistors. To eliminate other possible problems, read through the following page:
Amp in Protect Mode - Troubleshooting
Posted on Sep 11, 2008
  • 631 Answers
SOURCE: performance teknique icbm 892 1200 watt amp
DD, JL and pioneer in that order. I don't recommend any particular size but 12s are a good compromise.
Posted on Sep 22, 2008
  • 108 Answers
SOURCE: icbm-7071 performance teknique alarm remote starter wont work
what type of vehicle and year is it in? Also, most remote start alarms have a neutral safety wire that needs to be grounded and a hood-pin wire that needs to be connected. If the start system was working and has since failed, it is pointing at the hood-pin wire. If it never started remotely, then you may look to the programming on the alarm. Make sure that the tachometer wire is connected and that the tach setting has been programmed. This should take care of it. If not, I would recommend visiting a local stereo shop to have them diagnose what is wrong with the system.
Posted on Sep 28, 2008
I need a user manual for a performance teknique ICBM- 136
Try Googling (Performance Teknique)(ICBM- 136)(manual) without parens.
Aug 15, 2017 | Performance Teknique Car Audio & Video
Need pin out for a Performance Teknique icbm-9706 i lost my harness
It should be a standard 12 pin wiring harness used in many products.
I suggest getting a harness off another set.
Jan 14, 2017 | Performance Teknique Car Audio & Video
Installation-wiring
Performance Teknique might be able to supply a manual and/or wiring instructions.
Jan 01, 2014 | Performance Teknique Icbm-7348 Cd Mp3 Wma...
I needed the conector for performance teknique icbm 9778
i have the whole stero but if you want to we can talk ...mine works perfectly but the monitor doesn't flip up cuz i rip the wire that's connected between the stero and monitor..call me at 562 480 7084 thanks
Jan 01, 2013 | Performance Teknique ICBM-9778
Hey I just recently buy a performance teknique
good luck finding one, check ebay, or call Teknique directly.
Feb 13, 2010 | Performance Teknique ICBM-9794 Car Video...
Keeps on diagnostic after i turned it on and had it completely wired what should be the problem
have you checked the power ant wire? usualy oarnge this needs to be hooked to a power source that is not on when the power of your vehicle is not on (usualy a fuse block)
May 11, 2009 | Performance Teknique ICBM-895 Car Audio...
I lost user manual for Performance Teknique ICBM-9493TV Car Video
Yo I have a icbm 5254 in dash monitor and in order to bypass the parking brake security, splice the wire that's marked "park brake"(mine is Pink, yours may be Orange,but it'll be the oddball colors) into the acc or aux wire(usually yellow) and it'll play dvd while moving. Hope this has been helpful.
Feb 28, 2009 | Performance Teknique ICBM-9493TV Car Video...
Performance teknique icbm-896 stick on diagnostics
Sep 10, 2008 | Performance Teknique ICBM-896 Car Audio...
Performance Teknique ICBM-9550 Amp Problem.
one of the power transistor of your unit shorted check use a tester
Aug 27, 2007 | Performance Teknique ICBM-782 Car Audio...
Car Audio & Video Logo
370 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
